GOOD FOR NOTHIN 2WD SPORT MINIVAN SILVER SLEEPER BUILD
Discussion in '2nd Gen. Builds (2005-2015)' started by TommyG, May 24, 2016.
  1. May 24, 2016 at 9:03 PM
    TommyG
    TommyG [OP] Around
    Grouch
    MELTING POT
    21 MAX
    No mods
    exhaust chop with 4" tip
    ChadsPride likes this.
  2. May 24, 2016 at 9:04 PM
    TommyG
    TommyG [OP] Around
    Grouch
    MELTING POT
    21 MAX
    No mods
    I had these lights before I did the flush mounts
  3. May 24, 2016 at 9:08 PM
    TommyG
    TommyG [OP] Around
    Grouch
    MELTING POT
    21 MAX
    No mods
  4. May 24, 2016 at 9:22 PM
    TommyG
    TommyG [OP] Around
    Grouch
    MELTING POT
    21 MAX
    No mods
    I made this hood light kit myself. I put a switch instead of a pop up on.
  5. May 24, 2016 at 9:23 PM
    TommyG
    TommyG [OP] Around
    Grouch
    MELTING POT
    21 MAX
    No mods
    Stock style switches
    Nate87, ChadsPride and Bot_Chu like this.
  6. May 24, 2016 at 10:29 PM
    Bot_Chu
    Bot_Chu Du Ma
    Nate (Bot)
    Corona, Ca
    2007 ACLB Prerunner
    Enkei RPT-1, ADS 2.5 F/R, 4" Spindles, Toyo RT 315/75/16
    Super awesome build thread! actually starting mine very soon after classes are over. Pretty much following this since i have alot of similar components. were the brake lines a pain in the butt to install on the front end?
    ChadsPride and TommyG[OP] like this.
  7. May 24, 2016 at 10:34 PM
    TommyG
    TommyG [OP] Around
    Grouch
    MELTING POT
    21 MAX
    No mods
    Not to bad. If you have the right tools. Messy though.
  8. May 24, 2016 at 10:36 PM
    Bot_Chu
    Bot_Chu Du Ma
    Nate (Bot)
    Corona, Ca
    2007 ACLB Prerunner
    Any tips to a beginner such as myself approaching it? I know i need some flare wrench as to not stripping the bolt but other than that im still researching o_O?
  9. May 24, 2016 at 10:43 PM
    TommyG
    TommyG [OP] Around
    Grouch
    MELTING POT
    21 MAX
    No mods
    They shouldn't be too bad, if you got the tools. The bitch was those pinch nuts for the lower ball joint bolts on the maxtracs.
    ChadsPride and Bot_Chu[QUOTED] like this.
  10. May 24, 2016 at 10:44 PM
    Bot_Chu
    Bot_Chu Du Ma
    Nate (Bot)
    Corona, Ca
    2007 ACLB Prerunner
    .___. thank the lord i have almost two weeks to work on it!
  11. May 24, 2016 at 10:45 PM
    TommyG
    TommyG [OP] Around
    Grouch
    MELTING POT
    21 MAX
    No mods
    Good luck
  12. May 24, 2016 at 10:46 PM
    Bot_Chu
    Bot_Chu Du Ma
    Nate (Bot)
    Corona, Ca
    2007 ACLB Prerunner
    :thumbsup:
  13. May 24, 2016 at 11:01 PM
    Medina33
    Medina33 Well-Known Member
    Erik
    Lax
    2010 dcsb 4x4
    How did you install that 30 in the lower val. ???
  14. May 25, 2016 at 7:05 AM
    TommyG
    TommyG [OP] Around
    Grouch
    MELTING POT
    21 MAX
    No mods
    Piece of angle iron bolted to the crash bar. It's pretty easy. It's also behind the grill. I still have your bracket. I'll save it for you.
  15. May 25, 2016 at 1:21 PM
    #35
    MancationJeep
    MancationJeep Member
    what sliders are those?
    ChadsPride and Shmellmopwho like this.
  16. May 25, 2016 at 2:31 PM
    #36
    Zac of all trades
    Zac of all trades FWP Fabrication Vendor
    Zac
    fwpfab.com
    2013 4x4 Locked DCLB
    886/5100s/AAL/UCAs/360 armor/RTT/295 17s
    Where did you purchase the center caps? Also can you tell me what size they are? 60mm, 50mm?? Thanks
  17. May 25, 2016 at 4:06 PM
    #37
    TommyG
    TommyG [OP] Around
    Grouch
    MELTING POT
    21 MAX
    No mods
    Ryan @Shmellmopwho fab a local TW member. He has multiple threads on here.
  18. May 25, 2016 at 4:13 PM
    #38
    TommyG
    TommyG [OP] Around
    Grouch
    MELTING POT
    21 MAX
    No mods
    Those are the caps that came with the wheels. They are 2 piece, so I popped the end caps out. However they are slightly too small so I wrapped the edges with 3m 2way tape then cover with black duct tape to make a tight fit. Then pop them on. I used Trd brake caliper stickers from Amazon. Haven't lost one yet. They won't even spin. But will pop in and out. :thumbsup: I get lots of inquires on them. They think they are actual Trd wheels. Haha.
    ChadsPride and Pirhett like this.
  19. May 25, 2016 at 4:15 PM
    #39
    Shmellmopwho
    Shmellmopwho Well-Known Member Vendor
    Lomita CA
    2013 White DCLB TRD sport
    Bunch of stuff
  20. May 25, 2016 at 4:16 PM
    #40
    zth25
    zth25 Well-Known Member
    Zach
    Atlantic County x Philly
    2005 DCSB TRD OR 4X4
    887 1.5 AAL JBA UCA's 285/70/17 Trail Graps 17x9 Fuel Hostage Custom Headlights
    Sub'd cause my truck will look similar soon. Nice rig!
    ChadsPride, Bot_Chu and TommyG[OP] like this.
