Good height to lift my Taco.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by DirtyTacos, Apr 25, 2011.
  1. Apr 25, 2011 at 2:48 PM
    DirtyTacos
    DirtyTacos [OP] Well-Known Member
    Dino
    So Cal
    2011 4x4
    I have king 2.5 coils and right now they are at stock height. They are amazing in the desert and will soak up almost anything i want em' too, however driving on the freeway can get a little wobbly. I also want a little more clearance so because i have a 4x4 and i still want my coils to preform in the desert im thinking to lift em' about 1.5", as far as CV boots go is 1.5" ok?. The shocks are new so i don't know much about them. can someone help me out.
    Stock Height
  2. Apr 25, 2011 at 2:50 PM
    97yota4wd
    97yota4wd Well-Known Member
    Eric
    Mesa, AZ
    alot of metal, small engine, decent travel.
    caged, camburg long travel, 50t leafpack (soon to be installed) light rack over cab, 5pt harnesses etc
    i know 1.5 inches are fine on your cb boots, when you go to 2.5-3 inches is when you need a diff drop. im sure someone can chime in on your other questions
  3. Apr 25, 2011 at 2:51 PM
    mxnborder
    mxnborder Well-Known Member
    Santa Barbara
    05 4x4 sport - black on black on black
    DR coilovers AAl 285 kelly safaris lightbar/skidplate need more!
    I've seen people go like 2-2.5" and not have a problem so i think you are definitely in the clear with 1.5". will look good too,rear stock?
  4. Apr 25, 2011 at 2:53 PM
    DirtyTacos
    Dino
    So Cal
    2011 4x4
    I have stock leafs, so the rear shock is staying put for now. I could mess with the PSI and lift em' a bit, but maybe in the future ^^^^
