Good interior cleaner?
Discussion in 'Detailing' started by nick772, Apr 21, 2012.
  1. Apr 21, 2012 at 8:27 AM
    nick772
    nick772 [OP] Active Member
    Nick
    2012Magnetic Gray Double Cab Trd Sport 4x4 v6
    Hey guys I was just about to go and clean the inside of my truck and remembered I'm out of the toyoguard interior cleaner.. I really liked that stuff and was wondering what products you guys are using.. I have armor all but I don't reall want a shiny surface. I just want something to clean it and keep it looking factory clean.. None of the shiny non sense
    Thanks- nick
  2. Apr 21, 2012 at 8:40 AM
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    303 Aerospace protectant
  3. Apr 21, 2012 at 9:29 AM
    nick772
    Nick
    Where can I get it?
  4. Apr 21, 2012 at 9:30 AM
    DEEVON911
    DEEVON911 Semi-Pro
    Dave
    Bethel Park, PA. Burb of da Burgh.
    2010 MGM Mostly Stock Off-Road 4x4
    TRD Cat-back Exhaust. Semi-Debadged. Trimmed down stock Antenna. Weathertech vent visors. TRD FJ Cruiser Center Cap Wheel Mod. 265/75/16 Firestone Destination A/T,s . Inverter tapped into for outlet in cab. Tacomaworld sticker which adds 5 hp.
    I assume your talking about the dash? How dirty is it? I usually only have dust on my dash, so I just wipe it down with a damp towel.
  5. Apr 21, 2012 at 9:32 AM
    nick772
    Nick
    The whole interior. Dash, steering wheel, door panels etc.
  6. Apr 21, 2012 at 9:39 AM
    nick772
    Nick
    The guy here at auto zone said the f21 works good but I rather take someone's word off of here
  7. Apr 21, 2012 at 10:04 AM
    DEEVON911
    DEEVON911 Semi-Pro
    Dave
    Ya dash, I just wipe off the dust, It still looks new. I also vacuum off the dust around the radio,vents, steering wheel with a brush attachment on my shop vac. Door panels, if for some reason get more than normal dust, I just use some windex Multi surface, and than cleans it pretty nice. I'm sure anything will work fine. Since you don't want shine. I don't like the shine either.
  8. Apr 21, 2012 at 2:01 PM
    Madjik_Man
    Colorado Front Range
    This ^
    By far the best product I've used
  9. Apr 21, 2012 at 2:15 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    +1 for 303.
    I used to buy mine online... need to get more, I haven't messed with detailing in years.
    Armorall does make a non-gloss formula now.
  10. Apr 21, 2012 at 3:44 PM
    OffroadToy
    As far as cleaning the plastic of the gauge cluster i highly recommend Meguiar's Mirror Glaze 17 Clear Plastic Cleaner on a micro fiber towel. If you touch the plastic with a regular rag i guarantee it will scratch.
  11. Apr 22, 2012 at 1:32 PM
    12Tac
    12Tac Well-Known Member
    Colorado
    2020 Double Cab, Long-bed TRD Off Road.
    SnugTop, FN Wheels, Meso Custom, Tacos4Cheap
    Has anyone had problems or noticed the color coming off your interior side panels or dash when applying any of this 'protectant?'
    12Tac
  12. Apr 22, 2012 at 1:40 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    Unless someone has painted the parts, most are molded color-through. This would be the case for the tan, grey, and charcoal parts.
    The silver parts are painted, and some of the black buttons are (the hazard button is actually red, with a coat of black, and then a thin coat of silver on the silver-trim trucks).
    303, Armorall, and other protectants won't soften or remove paint. You have to be careful with other cleaners such as Simple Green (generally pretty gentle)... 409 WILL tear up the silver, and I've had "Fantastik" permanently spot a windshield on my '69 Buick.
    For 90% of interior grime, all you need is something wet with a mild surfactant to break the surface tension of the water. Most of what we encounter is simply dust, and the occasional sneeze or cough "residue"... and those clean up just fine with a damp cloth.
    The areas that will need a bit more, such as the door panels, arm rests, sill plates, and kick panels, are molded through and are going to be impervious to anything that won't melt the plastic. Simple Green, or Dawn are good, safe detergents.
  13. Apr 22, 2012 at 1:49 PM
    Madjik_Man
    The 303? Never.
    All I do is moisten a microfiber towel with 303 and wipe down all the interior trim, weatherstripping, etc...
    Looks brand new
  14. Apr 23, 2012 at 2:49 PM
    yotacoma12
    yotacoma12 Active Member
    MIKE
    sd
    v6 dcsb 2nd gen
    avid offroad lightbar avid step rails
    i use meguairs natural shine on my plastics and......... Baking soda on my floor boards!!!! believe it or not lightly powdering the floors and letting it sit for 15 minutes really deoderizes the interior!!! just dont sprinkle in to much or it can be a pain to get out!!
  15. Apr 23, 2012 at 3:08 PM
    boshak
    boshak Well-Known Member
    AG
    CA
    2003 Manual 4x4 5VZ-FE
    Good thread. What do you all use on the carpets and seats?
  16. Dec 17, 2012 at 10:15 PM
    WiscTaco
    WiscTaco Well-Known Member
    Wisconsin
    Sr5 Trd 23.42 mpg
    Grey Wire, AFE Pro Dry S
    Tuff Stuff -multipurpose foam cleaner works well. Great for seats, carpets, seatbelts, pet messes, etc.
  17. Dec 17, 2012 at 10:20 PM
    monsterkx2fiddy
    monsterkx2fiddy Well-Known Member
    Birthplace of Davy Crockett
    Don't use armor all. I used it for about two years on a truck and it made a little of a yellowish tint on the gray plastic.
    Although it was a ford ranger bahaha
  18. Dec 18, 2012 at 6:38 AM
    spiralout462
    spiralout462 Well-Known Member
    Eastern Shore VA
    2015 4x4 dclb
    Icon suspension '15 toyota nav TRD FJ SE anthracite wheels Weathertechs Trd pro pieces
    Meguires Natural Shine! Last and last and last......not a greasy shiny finish. One application of natural shine then dust it when needed. I hear great things about 303 as well. I wouldn't let Armour all near my truck.
  19. Dec 18, 2012 at 6:53 AM
    Av8er
    Av8er Well-Known Member
    Taylor
    Formaly Houston, now Tampa, FL.
    09 Prerunner SR5/TRD DC, LB, w/ Tow
    303
    x10 or whatever. Great results on my 09 showing signs of aging on the outside rubber.
    I use the "303 vinyl and fabric cleaner" on the interior maybe once to twice a year as a general deep cleaning and then use the "303 protectant" at every general cleaning (two weeks) after wiping away dust/loose dirt. I use a very little amount of the protectant inside with a micro fiber cloth only.
    Bought mine (best price at the time) at a local West Marine shop. I also, and this is just personal practice, use color coded microfiber cloths with each having it's dedicated purpose. ie. blue ones are used for windows/glass, orange ones for protectant, green for cleaner, etc. That way I'm not risking bringing in outside harsh particles from protecting the outside which may scratch up the interior surfaces.
    I had a general picture or two on my build page of a "before" and "after" of the external of my truck (rubber areas) from the first time I used the 303 protectant.
  20. Dec 18, 2012 at 11:47 AM
    neonlazer
    neonlazer Mechanically Goofy
    Lafayette, LA
    '23 DCSB 4x4 SR5
    303 all the way :)
