Good lift combination or not?
Discussion in 'Suspension' started by Uhaul-n-azz, Jun 14, 2009.
  1. Jun 14, 2009 at 7:43 PM
    Uhaul-n-azz
    Uhaul-n-azz [OP] Well-Known Member
    fayetteville,AR
    4Runner Stock
    I think that I have settled on Camburg Ball-Joint Upper Control Arm Set,OME 885 Tacoma Front Coil Set, and icon add a leaf for the lift. I have a few questons icon add a leaf will work even if I do not have the TSB spring right. Has any one used the Camburg ball-joint upper control arms an how do you like them. Will the 885 springs give me a 3 inch lift up front with the arb bumper or do I need to get the 886 springs also i already have 5100s. Sorry if this subject has been covered searched did not find anything. Thanks
  2. Jun 14, 2009 at 10:05 PM
    sincitytaco
    sincitytaco Well-Known Member
    Las Vegas
    2021 TRD Off-Road 2wd Cement Grey
    Bilstein 6112/5160 set at notch 2/3, OEM TRD Pro Wheels, 275/70/17 Falken Wildpeaks, OEM TRD Pro Grill, Debadged, Ceramic Tinted Windows
    Um the ball joint upper arms should not squeak at all, they are ball joints. Yes they are a great arm, many have had great success with them.
  3. Jun 14, 2009 at 10:06 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    X2
  4. Jun 14, 2009 at 10:12 PM
    AR_Taco
    AR_Taco Well-Known Member
    Jacksonville Ar
    07 DC 4x4
    3" lift, Flowmaster exhaust, K&N filter, URD short throw shifter, ScangaugeII
    Do you have a winch? If yes go 886. If no go 885.
  5. Jun 15, 2009 at 10:36 AM
    Uhaul-n-azz
    fayetteville,AR
    4Runner Stock
    Go to know the camburgs dont squeak. Has anyone installed these on there own? Was it very hard to do?
  6. Jun 15, 2009 at 12:32 PM
    Uhaul-n-azz
    fayetteville,AR
    4Runner Stock
    Also I wont need to replace the 5100s when I add the ome springs right? How had is it to install an add a leaf?
  7. Jun 15, 2009 at 1:18 PM
    sincitytaco
    Las Vegas
    Pretty straight forward. Just undo the ball joint and take out the bolt, which some people cut out if they can't squeeze it out. The dealership sells new bolt for like $20.
