Good lift kits that won't break the bank?
Discussion in 'Suspension' started by Southernbella, Sep 29, 2014.
  1. Sep 29, 2014 at 10:12 PM
    Southernbella
    Southernbella [OP] Member
    Isabella
    Coquitlam
    2014 Toyota Tacoma TRD
    Bilstein 3" lift with 31s and pro comp alloy wheels
    I've got a couple questions actually. I want to put a 6" lift kit in however, I do not want to break the bank. Is there a good lift option that isn't too expensive and won't break my truck?
    My other question is, do all 6" lift kits need to be welded and are they permanent?
  2. Sep 29, 2014 at 10:24 PM
    doubleroses
    doubleroses Well-Known Member
    Joe
    Whats your price range? Any 6" lift is going to be relatively expensive since you normally buy larger tires and possibly rims as well.
  3. Sep 29, 2014 at 10:28 PM
    TashcomerTexas
    TashcomerTexas My truck is a whiner
    2003 TRD DC Supracharged
    If you plan on doing any wheeling you might reconsider getting a 6" lift altogether. Nothing good comes from those and you're not gaining any ground clearance due to drop bracket opposed to a 3" suspension lift.
    Not trying to steer you away from a 6" lift but just making you aware that there are problems associated with them.
  4. Sep 30, 2014 at 8:01 AM
    Southernbella
    Isabella
    Coquitlam
    I really don't want to spend anything over $1800 honestly and that's just for the lift.
  5. Sep 30, 2014 at 8:03 AM
    geekhouse23
    geekhouse23 The "Liftman" - @DrFunker
    2GMGMDCSB4WDTRDFTMFW!! TL;DR
    mostly stock, grocery gettin' Prius
    What use is the truck going to see? Streets? Or wheelin? Is this more for looks rather than function?
  6. Sep 30, 2014 at 8:05 AM
    Southernbella
    Isabella
    Coquitlam
    Yeah, I've definitely taken that into account. However, I don't wheel as much as I did back in the day and if I do, it won't be nothing hardcore.
    Do they break more easily?
  7. Sep 30, 2014 at 8:06 AM
    Southernbella
    Isabella
    Coquitlam
    This is my daily driving vehicle. I pretty much drive it to work and back. I want it for looks as well as clearance. I go camping a lot.
  8. Sep 30, 2014 at 8:10 AM
    geekhouse23
    As stated above, with the drop bracket, you won't gain anymore clearance over a 3" suspension lift.
    My fiance's brother recently bought a 2004 Silverado with a 6" DB lift and a 3" body lift. I have 3" suspension lift and I have more clearance than him. Granted he is on 37's and I have 33's we put him on 35's as that is typically the tire people run on 6" lifts just to test and the DB hangs too low.
  9. Sep 30, 2014 at 8:20 AM
    Warputer
    Warputer Dirt Road Inspector
    Lake Murray, South Carolina
    2011 TRD Off Road
    9" of Super Bro lift
    Is your truck 4x4? If so, some kits require partial removal of the front cross member (cutting the frame). It is reinforced with their new bracket. And not all kits require welding.
    Pro Comp & Fabtech have been building 6" kits for the Tacoma longer than anyone else ....both stage 1 basic kits are $1500 to $1800.
    RCD, BDS, Rough Country & Zone offer 6" kits also.
  10. Sep 30, 2014 at 10:17 AM
    Southernbella
    Isabella
    Coquitlam
    Yeah, my first choice was Pro Comp. I had a lot of people tell me about Fabtech but I found their prices were ridiculously expensive. Rough Country I heard is terrible lol apparently it brakes a lot of things.
    I do not want to weld anything on either and I don't want it to be permanent as I've heard from a few people.
