Good Mechanic Good Price in (West) LA for 1999 stickshift 4x4 with 163k miles
Discussion in 'Southern California' started by tacolol, Oct 25, 2024.
  1. Oct 25, 2024 at 4:29 PM
    tacolol
    tacolol [OP] New Member
    1999 2.7L 4 cyl single cab 6 ft bed 5 spd 4x4 163k miles
    Hello,
    I just picked up a dream Tacoma off an aging craigslist grandfather - it's a 1999 4x4 stickshift with 163k miles. It's in great shape - I took it into the Toyota Dealership after I bought it for an inspection and they gave me the following list of repairs with these prices
    engine valve cover gasket with spark plugs $989
    front struts $1,299
    rear shocks $950
    transmission oil change $350
    transfer case oil change $350
    front differential oil change $365
    rear differential oil change $365
    I was into them for $250 bucks for the inspection, which they'd roll into the price of repairs, so I just had them go ahead and do an oil change (transmission) and skipped the rest
    the taco does turn a bit before starting up, so I believe him on the spark plugs, but I think I can find a much better price than what a Toyota dealership is going to charge me. Also I don't know if I %100 believe them on the rest of the stuff
    So, I was wondering if Taco world could recommend a solid, honest mechanic in LA who does good work at good prices
    Thanks
  2. Oct 25, 2024 at 4:35 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    I think @Superdave1.0 is out that way.
    He's a good guy. Maybe see if he can work with you.
    Superdave1.0 likes this.
  3. Nov 1, 2024 at 10:29 AM
    gstodd
    gstodd Well-Known Member
    2005 2wd base 5-lug
    Not on the westside but Nightwerks up in Santa Clarita does good, honest work and is a Toyota certified mechanic. He's been working on all of my, my kids, my ex, my fiancee and her kids cars for years.
    https://www.nightwerks.com/
  4. Nov 1, 2024 at 8:54 PM
    IEsurfer
    IEsurfer Well-Known Member
    Socal
    I too recommend @Superdave1.0 he’s in Downey so not too far from you
    MGMDesertTaco and Superdave1.0 like this.
  5. Nov 1, 2024 at 9:44 PM
    Ricardo13x
    Ricardo13x YT: @UrbanOpsOffRoad IG: @urban.ops.offroad
    Upland, CA.
    05 OR DCSB ProRunner(4x4 conv.), Chevy 63”s, NWF EcoCrawler, 35”s
    Random stuff. Oh! and converted to non ADD 4x4.
    Are you physically capable of wrenching? If so a couple of YouTube videos , Amazon reclaimed transfer case gasket kit, few beers and a run to Walmart will get you everything you need to knock it out in a couple of hours.
  6. Nov 1, 2024 at 11:26 PM
    MGMDesertTaco
  7. Nov 19, 2024 at 4:49 PM
    Mach
    Mach Well-Known Member
    2022 Lunar Rock DCLB TRD Off-Road
    Did you get things sorted? That is all easy stuff to sort yourself for a fraction of the price. I am in Culver City and might be able to lend a hand and a wrench sometime if you need it.
  8. Nov 19, 2024 at 4:53 PM
    Mach
    As far as what should be done all those fluids should definitely be changed because most people don't bother and they should have been done many times by now. Same with the spark plugs. The valve cover gasket is something you swap if it is leaking, shouldn't be hard to tell but also not a super urgent thing to tackle as long as its not horrible. Just make sure your oil is topped off regularly. Are their signs of leaks on the shocks/struts? That or poor handling would be an indication they should be done but unless things are way out of wack nothing major is going to happen from waiting on that other than poor handling.
