Good news! Update about my Tacoma’s rough ride
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Nazareth7, Apr 3, 2023.
  1. Apr 3, 2023 at 5:25 PM
    Nazareth7
    Nazareth7 [OP] Well-Known Member
    2007 Tacoma 2x4
    Actually I found that it was the tires that were aired up to 65 psi lol from a tire shop. After I dumped some air out to make it 42psi, I now have comfortable ride . My Tire size is 245/75/16
    update : I dropped the air more to 34 psi . Thanks all
  2. Apr 3, 2023 at 5:38 PM
    TegoTaco
    TegoTaco Well-Known Member
    Ontario, Canada
    ‘13 SUPERCHARGED DCLB TRD SPORT
    Even 42 is high…
    gotoman1969 likes this.
  3. Apr 3, 2023 at 5:53 PM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    Drop another 10lbs at least. Your teeth will love you.
    Logger and TegoTaco like this.
  4. Apr 3, 2023 at 6:03 PM
    Nazareth7
    2007 Tacoma 2x4
    how much should it be
  5. Apr 3, 2023 at 6:03 PM
    Nazareth7
    2007 Tacoma 2x4
  6. Apr 4, 2023 at 5:55 AM
    Geeves77
    Geeves77 Well-Known Member
    Mark
    Northeast
    2011 Tacoma DCSB
    3 inch Icon lift with UCA’s
    I ride with 35 in each tire
    Your way to high
    Look at PSI suggestion on tire itself
  7. Apr 4, 2023 at 7:35 AM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    There is no "psi suggestion" on the side of the tire. Only a "psi maximum" that is put there for legal/liability reasons.
    Best place to start is the tire info/pressure sticker on the driver's door jamb and adjust from there. Sticker indicates around 29-33 I believe..
    Personally I'm around 33-35 in summer on pavement/highway. In winter I'll go down into the high 20s for highway snow conditions. On dirt/washboards I'll go low 20s. I rarely "offroad" but when I do ill go high teens. I have LT 255/80/17
    I highly doubt the experience level of "tire shop" employees that send a compact pickup out the door with 65 psi :facepalm:
    gotoman1969 and Too Stroked like this.
  8. Apr 4, 2023 at 7:42 AM
    outdoorgb
    outdoorgb (.)(.)
    Burbs of Oregon
    2014 DCSB TRD Sport Silver Sky...
    I think it's a "guy thing" where more is better... and I'm guilty as well.
    My 2014 was a "wanderer" on some rutted freeways and express ways (265/65-17). I was running 36, 35, 34 psi then tried 37... still not good. Went to 31/32 last weekend and it really tamed my ride. Smoother and less grab in the rutted, neglected, burned, pooped-on Portland roads. I'm fine with the lower psi, I just don't tell anyone and have kept my man card without guilt.
    BigCountry762x39 likes this.
  9. Apr 4, 2023 at 1:17 PM
    gotoman1969
    Start with the recommendations on the door jam sticker. Chalk test always works well too.
  10. Apr 4, 2023 at 4:37 PM
    Nazareth7
    2007 Tacoma 2x4
    It wasn’t professional tire shops like discount tire, Walmart , or Costco etc.
    it was just one of those small Mexican owned tire shops .
  11. Apr 5, 2023 at 8:39 AM
    knottyrope
    knottyrope Well-Known Member
    Knotty
    Bahstun
    09 Taco CCLB 4x4 SR5 4.0
    Pads, rotors, ujoints, 5900K Super White Xenon HID Halogen Bulb Fog Light
    do a chalk test
    PSI is just an indicator
  12. Apr 5, 2023 at 1:51 PM
    Pinatacoma
    Pinatacoma Well-Known Member
    Vancouver Island, BC
    2020 ACOR
    jaymac10 likes this.
  13. Apr 5, 2023 at 2:27 PM
    CrippledOldMan
    CrippledOldMan Well-Known Member
    David
    Salisbury North Carolina
    2003 TRD Crew Cab
    None
    That's a much better number for those tires. I keep my 265/70/16 at that pressure, no problems.
  14. Apr 5, 2023 at 2:35 PM
    ToolCat
    ToolCat Active Member
    Greg
    I always run a pound or two more PSI in the front tires, to account for the extra weight of the motor. Helps even out your wear with the rear tires between rotations, and it just makes sense from a weight-carrying standpoint for the tires.
    Of course if you're hauling a lot of weight, you can add some PSI to the rear. Never exceed the maximum PSI always molded into the side of the tire!
    ToolCat
  15. Apr 5, 2023 at 5:01 PM
    jaymac10
    jaymac10 Well-Known Member
    Kelowna, BC
    2013 TRD Sport
    OEM Baja Kit
  16. Apr 5, 2023 at 5:48 PM
    Pinatacoma
    2020 ACOR
    I looked at the original cringe-worthy thread this is following up. The OP was asked multiple times about the new tires' load rating but no answer was given.
    Clearwater Bill likes this.
