Good off road air compressor recommendation?
Discussion in 'Off-Roading & Trails' started by JonnyRiptide, Apr 8, 2016.
  1. Apr 8, 2016 at 9:56 AM
    JonnyRiptide
    JonnyRiptide [OP] New Member
    2013 Tacoma double cab long bed sport package
    3 inch lift
    Been a Tacoma owner for about a month now and have took it cautiously off road a couple times now but haven't put together a good off road kit to go further and deeper yet. My question is can anyone recommend a good portable air compressor that'll plug into the 110v outlet to re inflate the tires after lowering the psi for off road use? Thanks!
    Protosimian likes this.
  2. Apr 8, 2016 at 9:59 AM
    deeezy
    deeezy Well-Known Member
    Dana
    Hawaii
    2013 4x4 DC, 6 spd, TRD Sport
    ADS ext travel coilovers with clickers, Icon tubular UCA's Rear-ADS 2.5's, Allpro Expos, TRD cat-back, Hurst/Core short shift kit, etc...
    Viair or ARB makes portable compressors. I use a 10 lb Co2 tank. Way faster than a compressor but the down side is that it's not "unlimited air". It's good for a lot of tires but you still need to refill the tank when it's empty.
    Chocks likes this.
  3. Apr 8, 2016 at 10:05 AM
    US Marine
    US Marine Semper Fi
    Chuck
    SoCal High Desert
    02 Pre Runner supercharged 4cyl
    TRD supercharger , Doug Thorley header , K&N CAI 265/75-16 Toyo open country mud terrain , 15x8 Method Racing wheels , Rancho 3" lift , 4.88 gears , Detroit Locker
    Why not use your AC compressor , they make kits to convert your compressor into a 120 psi air pump . It will be powerful enough to run air tools and easily inflate tires in seconds
    All of my old rock crawling jeeps I had GM style AC pumps converted over and it was the best thing I ever did
    Typical setup uses a semi truck air tank and hoses going to the front and rear of the vehicle for easy access
    Medina33 likes this.
  4. Apr 8, 2016 at 10:11 AM
    mwc273
    mwc273 Nothing is as it seems.
  5. Apr 8, 2016 at 10:16 AM
    Ihatetacomas
    Ihatetacomas Because tacomas hate me
    Dylan
    Reno NV
    '12 White LB TRD Sport
    Used @ 23,283 Volant Intake (w/ scoop)(removed August 2016), BAKFlip G2 Tonneau Cover, (drain tube mod), Pop & Lock Tailgate Lock, Stampede Vigilante Premium VP Series Hood Protector, 5lb Extinguisher, Shovel & Axe mounted in bed, Shok Industries Sound Deadener, Mercury: (K62, MGR-1200, MGR-495) Triton 8" Subs, Custom-Made: Sub Box, Speaker Templates, Vapor Barrier, All-Pro Bumper w/Kickouts, hidden trailer hitch, wooden cup-holder Misc: Knukonceptz RCA, speaker, and power wires, Big 3 Upgrade, a very full Husky technician tool box
    Can you put up a link to this?
  6. Apr 8, 2016 at 10:20 AM
    mwc273
  7. Apr 8, 2016 at 1:32 PM
    US Marine
    US Marine Semper Fi
    Chuck
    SoCal High Desert
    Yep those are very informative and tells you exactly what's involved . When I did my last one that was the late 90's and it worked very well . The secret is to get a good quality inline oiler for inlet side and then a good oil / air separator for the outlet side
  8. Apr 8, 2016 at 3:04 PM
    BlindingWhiteTac.
    BlindingWhiteTac. Well-Known Member
    Thomas
    Vancouver, WA
    07 LQ4 4L80E
    Just the essentials and no extra fluff.
    I use a Viair 400P. You're not going to find anything worth using that will plug into the 110v outlet. The Viair has battery clamps for connecting directly to the battery. Get a tire repair kit and an air down gauge too.
    Pirhett likes this.
  9. Apr 9, 2016 at 2:42 PM
    Ihatetacomas
    Dylan
    Reno NV
  10. Apr 12, 2016 at 1:47 PM
    pray4surf
    pray4surf Well-Known Member
    Rick
    Oceanside, CA
    98 PreRunner conv to 4x4
    F&R suspension, OBA, Custom bed rack, RTT, rear frame plates, 4x4 conversion from prerunner, many other
    12v Air Compressor
    This is a decent product at an affordable price (I remember when Pep Boys was clearing these out for $30)
    Although I have an on-board Viair system, this portable rides along as a backup. Easily modified to accommodate standard QR fittings.
    dtaco06 likes this.
  11. Apr 14, 2016 at 10:19 PM
    Nirvana
    Nirvana Tesla Auto
    Kris
    Morgan Hill, U.S.A
    2006 Off Road 4X4
    Icon ext. travel 2.5RR in front, Icon ext. travel 2.0RR in rear, BuiltRight uniball UCAs, Wheelers Superbumps, Goodridge steel braided brake lines, BruteForce front plate bumper w/ Warn M9000+synth line, American Auto Horns ACDF, Pelfrey Bussman mount+Sandman bussman fuse block (soon), 255/75R16s on painted stockers...because I'm not paying $800 to rock rash new wheels you scrubs. Shok Industries 2/0 big 4 upgrade and sound deadener.
    I refitted the hose with a standard coil hose and better air chuck from the auto parts store, the attached hose is certainly garbage. I also upgraded the wiring to larger gauge and put in an auto reset breaker as opposed to a fuse. There are several tutorials on boring out the intake and exhaust ports/replacing the reed valves but that wasn't as big of a deal to me. For $50 you can't go wrong with the MV50!
  12. Apr 14, 2016 at 10:30 PM
    Nirvana
    Nirvana Tesla Auto
    Kris
    Morgan Hill, U.S.A
    2006 Off Road 4X4
    Fixed! I think their connects are all proprietary or are industrial vs automotive. I ran a tap down the threads just to clear them and a 1/4 thread air fitting fit no issues.
    pray4surf likes this.
  13. Apr 14, 2016 at 10:38 PM
    Nirvana
    Nirvana Tesla Auto
    Kris
    Morgan Hill, U.S.A
    2006 Off Road 4X4
    The gauge I've yet to find a fix for. I've found mine bounces to about 10PSI over what the actual pressure is so I just verify with a pencil gauge after and call it good. A liquid filled gauge might work but I don't feel like dropping that kind of change on a $50 compressor.
    Under $10 at Harbor Freight should have your hose upgraded.
    http://www.harborfreight.com/1-4-quarter-inch-x-20-ft-coiled-air-hose-97923.html
    http://www.harborfreight.com/tire-chuck-with-lock-on-lever-68267.html
    http://www.harborfreight.com/14-in-Male-Steel-Automotive-Plug-68174.html
    I did see on a forum where someone mentioned HF had a similar compressor to the MV50 but appeared to have a better motor though I haven't seen one in the stores so I'm not sure if they were discontinued or not.
  14. Apr 14, 2016 at 10:51 PM
    Protosimian
    Protosimian Headbanger.
    Roger
    Where the Wild Things Are
    2012 MGM Sport
    Dents and scratches, and other stuff.
  15. Apr 14, 2016 at 10:52 PM
    US Marine
    US Marine Semper Fi
    Chuck
    SoCal High Desert
    Anyone remember the Dick Cepek Engine air tire inflator ?? . The nylon /rubber hose that you would thread I to a spark plug hole and use the engines compression to inflate the tires
  16. Apr 15, 2016 at 10:29 AM
    yeos
    yeos OCD Member
    Renton
    2011 AC TRD OR 4X 2007 Lexus GX
    The gauge on my mv50 was consistently 7 psi above the actual pressure. It didn't bother me too much, but I ended up removing the gauge and drilling and tapping the hole to 1/4 npt and installing an interstate pneumatic gauge. I haven't tested it for accuracy yet, but I'll report after I do.
  17. Apr 20, 2016 at 10:38 AM
    Mikelax20
    Mikelax20 Well-Known Member
    Michael
    Salida, CO
    2014 Supercharged Sport
    Supercharger, trd exhaust, short shifter, OME Lift, RCI Skids, 33's, trd sport rims, CB, are topper.
    Big fan of the co2 setups. Source your own tank slap on a reg and good to go for awhile. My opinion the less moving parts and electricity the better.
    Chipskip likes this.
  18. Apr 20, 2016 at 11:21 AM
    Mikelax20
    Michael
    Salida, CO
    I'll be able to let you new in two weeks, I'm headed to Moab on Tuesday for 6 days so I should be able to get a pretty good idea how many a 20# tank fills. The guy I wheel with has used his on his jeep all last summer and fills 35" tires every weekend, just refilled his for the trip.
  19. Apr 20, 2016 at 11:23 AM
    crashnburn80
    Kirkland, WA
    2015 DCSB TRD OR MGM
    Go Hawks!
  20. Apr 20, 2016 at 12:02 PM
    Mikelax20
    Michael
    Salida, CO
    image.jpg And $54 to fill. I added a 50' hose and tire gauges so I'm probably $425 with everything including the mounting hardwear and strap etc. it's also portable if needed. there are way cheaper regs out there but the powertank reg is worth the money imo.
