Good old timing belt question
Discussion in '1st Gen. Tacomas (1995-2004)' started by sirsaechao, Jan 26, 2012.
  1. Jan 26, 2012 at 8:31 AM
    sirsaechao
    sirsaechao [OP] Well-Known Member
    Tim
    Commifornia
    2002 Toyota Tacoma SR5 TRD 3.4L 4X4 V6
    To much to list...see sig for more...
    This isn't about how much and how to do it myself. This is a question about if I should do it yet or not. I have a 02 Tacoma with 82XXX miles on the odometer. With tax return right around the corner and it is approaching 90K soon...I was wondering if I should wait till I hit 90k (which will be approx this time next year or later cause I don't drive my truck much) or just do it now because its been 10 years since I got my truck from the stealership lot when it new? I know everyone says 90k to 110k or even longer for some but I was wondering if time will deteriorate the belt too.
  2. Jan 26, 2012 at 9:14 AM
    classic42
    classic42 Well-Known Member
    14 Baja AC
    The thing about timing belts is that there is no warning before they fail. Pull the upper timing belt cover off and get a mirror under the idler pulley in between the camshaft pulleys. If you see any cracks between the teeth, definitely replace it. Or if you see any oil or antifreeze on it. Belt technology has come a long way. On mine truck and car, I replace them on or before the recommended mileage. But, I tend to be proactive instead of reactive on the things that will leave me on the side of road.
  3. Jan 26, 2012 at 6:26 PM
    cory02taco
    cory02taco Well-Known Member
    Cory
    Maine
    2013 trd super sport
    id do it. for the peace of mind, if not anything else. when my wifes 4runner hit 100k, i did the t belt, but mostly because i didnt know the last time it had been done.(she bought it at 70k.) Although the belt looked fine, the water pump turned out to be junk, so i trashed all of it and now i dont have to worry about it. i think its that ounce of prevention thing.
  4. Jan 26, 2012 at 6:30 PM
    Jdaniel1274
    Jdaniel1274 Well-Known Member
    Daniel
    Orange County, Ca
    01 DC TRD 4X4
    PIAA lights, OMD leaf spring mod, magna flow muffler, oil filter relocation kit
    Replace both timing belt and water pump! It will be done as a previous post said Peace of Mind!
  5. Jan 26, 2012 at 7:25 PM
    AlTaco
    AlTaco Member
    Mark
    Tuscaloosa,AL.
    03 D-Cab 4x4 TRD
    Grey Wire Mod,3 inch lift,Westin Brush Guard,Westin Running boards,Rear Tail Light guards,2 Hella 500's, 35W HID conversion,weather tech floor mats,LED interior lighting,Indash DVD/CD player with IPOD hookup,LED third brake light conversion,Hella floods for additional backup lights
    IMO If I had the money and the time for the vehicle to be down(half day-full day at dealership)I would do it because almost every 5VZ-FE (3.4 liter with 80-100K) I put a timing belt on the waterpump was leaking.
  6. Jan 26, 2012 at 7:30 PM
    wildjerseyfirefighter
    wildjerseyfirefighter I sell fishing and fishing accessories
    Joe
    NJ
    05 Tacoma TRD Sport
    stock, for now
    its pretty involved. I had a guy I work with do mine, and it took a couple hours. Not something to tackle if your not mechanically inclined.
  7. Jan 27, 2012 at 11:06 AM
    lil J
    lil J Well-Known Member
    Jacen
    Louisville
    99 Tacoma 4wd V6 Horizon Blue
    Old Man Emu Suspension
    99 tacoma with 150k+ still original timing belt and running strong
  8. Jan 27, 2012 at 2:41 PM
    02sr5trd
    02sr5trd Well-Known Member
    Donnie
    Ohio
    02 SR5 TRD 4x4
    Deckplate Mod, AFE Pro Dry filter, Xcelerator 14'' muffler, AAL, 5100's @2.5, Kenwood DD HU, Alpine speakers.
    I also have a 02 3.4 with 84,000. I am changing the timing belt, water pump, and the idler pulley's next week. IMO not worth the risk of having it break and costing alot more in the long run...
  9. Jan 27, 2012 at 8:49 PM
    gdstock
    gdstock Member
    Glenn
    Eastland, TX
    96 4X4 Tacoma, xtra cab
    CAI
    I have a 96 with over 270.000 on the clock, and orignial timing belt. Started gathering parts today. Not having problems, but almost afraid to let it ride too much longer. Gotta get my other truck painted so I can tear down my daily driver Yota.
  10. Jan 27, 2012 at 8:52 PM
    joes06tacoma
    Joe
    Central Coast, CA
    I believe Toyota also has a time interval in addition to the miles. At ten years, I am sure you are due by time alone.
  11. Jan 27, 2012 at 10:06 PM
    gdstock
    gdstock Member
    Glenn
    Eastland, TX
    CAI
    (Sorry - got distracted and did not finish post)
    Is there a DIY thread here somewhere on this that I can read (as well as FSM) so I get a better idea about what I need to do on this? Also, in addition to the water pump, what else is recommended to be done while I am doing this job?
    Thank you.
  12. Jan 28, 2012 at 3:17 AM
    02sr5trd
    Donnie
    Ohio
    02 SR5 TRD 4x4
    With the mileage you have I would do the belt, water pump, idlers pullys, and the hydraulic tensioner if the 96 has one.
  13. Jan 28, 2012 at 3:38 AM
    JDMcQ
    JDMcQ Well-Known Member
    The Mushroom Capital of the World
    2006 Toyota 4Runner SR5 V8
    It is not a particularly difficult job to do one's self with some basic tools (and one special one). If you have the time and funds to do it now, get it out of the way. No telling what might come up in the next year.
  14. Jan 28, 2012 at 4:53 AM
    02sr5trd
    Donnie
    Ohio
    02 SR5 TRD 4x4
    I bought the gates timing belt component kit with belt, water pump and pulleys for $190. If you have a car parts warehouse near you I recomend buying from them, its where most parts stores and shops purchase parts from around here and the price is way cheaper.
