Good or Not?
Discussion in 'Suspension' started by vtman 908, Jun 2, 2010.
  1. Jun 2, 2010 at 12:24 PM
    vtman 908
    vtman 908 [OP] Active Member
    4x4 Tacoma TRD
  2. Jun 2, 2010 at 12:29 PM
    mjp2
    Milton Juevos Portimous II
    NJ
    '06 TRD Access Cab, v6, 6-speed
    Scaffolding and a painted grill
    Don't run spacers in the front. Harsh ride and you run the risk of snapping a coilover on a pothole when the shock bottoms out before the suspension hits the bumpstops.
    It's happened to folks on this site. Do it right and go with some aftermarket adjustable coilovers.
  3. Jun 2, 2010 at 12:35 PM
    sirsaechao
    sirsaechao Well-Known Member
    Tim
    Commifornia
    2002 Toyota Tacoma SR5 TRD 3.4L 4X4 V6
    To much to list...see sig for more...
    There are people who run spacers and never had a problem. If you are on a budget I would check around for some 5100's made by Bilstein or save up for some coil spring lift by ToyTec/OME.
  4. Jun 2, 2010 at 12:37 PM
    Jigzor
    Jigzor Well-Known Member
    Pennsylvania
    17 DCSB Silver Sky
    Don't waste your money..
    Listen to this guy.. He knows a thing or two!
    or three or four.. :p
  5. Jun 2, 2010 at 12:59 PM
    mjp2
    NJ
  6. Jun 2, 2010 at 1:18 PM
    08pretaco
    08pretaco Almost there
    Oliver
    az
    2014 Tundra 4x4 CM 5.7L SR5
    AFE pro dry s, Husky X-act Contour
    naa i dont think he knows anything about tacomas....:D
  7. Jun 2, 2010 at 1:25 PM
    Scarab21
    Scarab21 Well-Known Member
    Tint, tinted tails + 3rd brake light, shaved tailgate, painted calipers. TSB Leafs+ AAL, PA/CB, 5100 Bilsteins set @ 2.5 up front. Satoshi line-x'd grill.
    just get a set of front adjustable 5100's get u about 2.5 max lift. and do a aal in the back... should cost around 400.. for parts.. then install on a mod day.. or get someone on here to help u.
  8. Jun 2, 2010 at 3:23 PM
    JasoTaco
    JasoTaco Well-Known Member
    Salt Lake City, Utah
    09 Tacoma TRD Off Road
    ToyTec Ultimate 3" Lift -TSB Rear springs - TRD Cold Air Intake - TRD Skid Plate - Total Chaos Upper Control Arms - 2 Hella Rallye 4000 lights (130W Bulbs) - Clear Bra - Under Coat - Bed extener - Toyota Bed Mat - Weathertech floor mats - Tailgate hose clamp & washer mod - PIAA Fog Lights - ScanGauge II - Beefed Sliders - Differential Breather Mod - Heated Seats - All-Pro Bumper - Warn M8000 Winch with wireless controls - Boztec Diff Skid - ATO skids
    X2
    IMO this is the best lift option for the money.
  9. Jun 2, 2010 at 3:28 PM
    vtman 908
    4x4 Tacoma TRD
    So i should get what scarab said to get?
  10. Jun 2, 2010 at 3:32 PM
    Scarab21
    you can do whatever you want.. thats what i did cause im on a budget.. i got the rear leaf springs done by Toyota TSB... (free) adds about and inch.. and i got the 5100's set @ 2.5 up front.. stock rims and tires. i installed myself on ALL-PRO mod day.. cost me $200 total.. shazam!
    not much.. but with bigger tires (coming soon) and another leaf in the back and i should be alright.. then when i have the $ im definatly going with some real coilovers or some spindles.. really want the 4" out of the spindles.. and the look with the prerunner!
  11. Jun 2, 2010 at 3:32 PM
    YotaDan
    YotaDan Dan
    Dan
    Oregon
    Give us a call and we can help you get setup with what will fit your budget, or needs.
  12. Jun 3, 2010 at 7:12 AM
    mjp2
    NJ
    ^ Wheeler's is an excellent vendor that's always taken care of the Tacoma community. They won't steer you wrong.
    I figured I'd throw in the endorsement since vtman 908 is new and probably unfamiliar with who's treated us right over the years. :)
