Good Place Buy Tundra 2012 Brake Booster ??
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TacoBell07, Jan 26, 2025.
  1. Jan 26, 2025 at 12:23 PM
    TacoBell07
    TacoBell07 [OP] Well-Known Member
    Four door 2wd Taco
    Probably going to upgrade brakes with a Tundra master cylinder and brake booster. Any suggestions on good place to get a TUndra brake booster ?
    Looks like there are no aftermarket ones and auto parts charges 500 for them.
    Rock auto brake boosters are out of stock.
  2. Jan 26, 2025 at 12:27 PM
    AllTacosFloat
    AllTacosFloat If yours sank you’re entitled to compensation
    Boston ish
    Has lockers, a skewp and a bit of droop.
    Only good luck I’ve had getting them is junk yards close to me where they are not shipped. Never had luck with a shipped unit. eBay might be good for it too, at least returns are easy enough.
  3. Jan 26, 2025 at 2:43 PM
    TacoBell07
    Four door 2wd Taco
    Was the shipped unit damaged or the rubber bad on it ?
  4. Jan 26, 2025 at 3:03 PM
    AllTacosFloat
    Boston ish
    Both were either broken before they shipped or maybe could have broke in transit. That booster is pretty common at a junk yard. They probably won’t try to give you a broken one in person.
    Also, cash is king at most.
  5. Jan 26, 2025 at 7:25 PM
    TacoBell07
    Four door 2wd Taco
    All 2012 + Tundra boosters are dual diaphragm correct?
