Good place for Dallas engine swap
Discussion in 'New Members' started by Liftedtaco5, Dec 26, 2014.
  1. Dec 26, 2014 at 12:07 PM
    Liftedtaco5
    Liftedtaco5 [OP] Member
    Denton texas
    02 tacoma 5" lift 35" general grabbers
    5" fox suspension lift , 35" general grabber red letter tires, 15x10 american racing rims, pre runner bumper, aftermarket headlights, limo tint, tool box with 4 marine grade kicker speakers, rhino line bed liner
    I have a 2002 Toyota tacoma on general grabber red letter 35" tires... I want to do a engine swap... It's currently a 2.7 4cyl motor.... I won 4000$ on a 1$ scratch off ticket on christmas... That's my budget... Id want it done as fast as possible ... I Live in lewisville , denton texas area... Ideas?
  2. Dec 26, 2014 at 12:29 PM
    BulletToothTony
    BulletToothTony You’ll have that on these big jobs.
    You can call me Susan if it makes you happy.
    What motor are you wanting to swap into it?
  3. Dec 26, 2014 at 12:33 PM
    Liftedtaco5
    Denton texas
    Not really sure... Anything not a 4 banger... Top speed is 60 mph.. If im spending 4,000$ out the door, I want to be able to Dailey drive and go above 70mph.. And be able to tow small trailer when needed and not struggle or fight my tire weight... Suggestions on easy less expensive swap and shop location , wouldn't mind a small Diesel engine either
  4. Dec 26, 2014 at 12:37 PM
    hetkind
    hetkind Well-Known Member
    Howard
    Johnson City
    2011 SR5 Access Cab, white with Leer Cap
    bilstein set at 1.75, Racho 5000 rear with 4 leaf kit, floor mats, high lift jack, pull hook in hitch, bed rail corner braces, severe duty brake pads and devil horns on the grill....
    not going to do a diesel conversion on 4k unless you get a used 4BT. Got a buddy in Canton, used to run a Pontiac/GMC dealership, who does one off stuff like this.
    Howard
  5. Dec 26, 2014 at 12:40 PM
    Clearwater Bill
    Billy
    Largo Florida
    Do you already have a motor sitting ready to go? If it's not a direct replacement, do you have the ancillary parts that will need changing to make it all compatible?
    If the answer is no to either of those, chances are you'll need a bigger budget.
    And if I was the shop, and you as a stranger toted in a motor of unknown heritage, I'd be reluctant to guarantee the results of the job unless you were willing to let me do a fair amount of pre install diagnostics. Bring me a crate motor and we'd be good.
    And I'd be real careful about a shop that says 'I can start tomorrow'. To me that would mean they don't have enough work to keep them busy, so the question becomes 'why?'
  6. Dec 26, 2014 at 12:43 PM
    TashcomerTexas
    TashcomerTexas My truck is a whiner
    2003 TRD DC Supracharged
    Best case scenario is swapping in a 5vz, über reliable and practically bulletproof. Might be able to put some money into a supercharger as well..
  7. Dec 26, 2014 at 12:45 PM
    Clearwater Bill
    Billy
    Largo Florida
    I'm thinking there is something wrong with your current motor. Any ideas what?
    You may have a much cheaper cure available.
    Two things that pop to mind regarding higher RPM restrictions (ie higher speeds) is a clogged fuel filter and/or injectors, a cat that is starting to fail causing a partial restriction, or even a muffler that has its guts causing an obstruction.
  8. Dec 26, 2014 at 12:48 PM
    Clearwater Bill
    Billy
    Largo Florida
    He can source a reasonably decent v6, the ancillary bits needed for the swap (like an ECU, wiring, exhaust, etc) AND pay someone else to do all the work for less than $4k?
    Wow, parts and labor rates in Tx must be really low...........:eek:
  9. Dec 26, 2014 at 1:01 PM
    Liftedtaco5
    Denton texas
    I have nothing wrong with my current motor other then the slowness of it fighting my 35" in tires... I may look into regear... Just wanted a bigger motor and I don't know if they have a supercharger really for a 2.7 liter 4cyl... I can find ebay and craigslist motors all day that are from company's or wrecked vehicles that have the tested and can prove it runs and ready for swap motor and tranny combo for 12-1500... Leaving my install fees to 2500 or so...
  10. Dec 26, 2014 at 1:04 PM
    Liftedtaco5
    Denton texas
    Is there a shop where I can get a quote wrote up around Dallas area. I've been researching , would really prefer a big new engine compared to a regear. It's still a 4cyl at the end of the day......
  11. Dec 26, 2014 at 1:06 PM
    hetkind
    Howard
    Johnson City
    How about a regear and a freshened motor? Your budget should support that...
  12. Dec 26, 2014 at 1:09 PM
    Liftedtaco5
    Denton texas
    Oh thanks! That would be a good solution !
  13. Dec 26, 2014 at 1:19 PM
    Liftedtaco5
    Denton texas
    What's the install price of supercharger and where can I get it done at then?
