Good quality fog lights, need a recommendation
Discussion in 'Lighting' started by SCSPerformance, Jan 23, 2015.
  1. Feb 3, 2015 at 9:34 PM
    Chas of MRT
    Chas of MRT Total Automotive Performance
    Chas
    Las Vegas, NV
    06 Tundra V8
    Airaid Bilstein
  2. Feb 3, 2015 at 9:53 PM
    NightProwler
    NightProwler Well-Known Member
    Harlan
    Maricopa, Az
    '01 Prerunner, '16 trd4x4, '03 cbr954rr, '03 rc51
    Yeah I saw that. But again, all these lights are, well, off road lights. Not really "fog" lights. Just led lights in the fog light location. I think OP was looking for lights that actually penetrate fog. And I was hoping that maybe the amber covers would work, but don't think so on these smaller lights... The diffused amber cover really blocks the light, unfortunately, and the output was considerably low. I think these are best suited for spot lights alone with no cover except maybe a clear cover, or clear amber spot cover. Do you have any "spot"/"clear" amber covers for the 6" ones? I think those ones would definitely be better and with the increased output, the covers would be able to be used more effectively... But in the end, I think these lights will be solely used as spot lights on my end. I was just hoping these would work for people that want/need fog lights, and could have both with the easy snap on covers.
    Oh and even though these are 'narrow' spot lights, they do have a pretty wide beam at the end where they "stop". One light pretty much lights up the entire road at the end. So I ended up aiming them outwards a tad. That's why I thought these would be great for fog lights with a narrow beam, being able to penetrate and see far down the road as possible in fog/dust.. But idk, fog sucks, and snow sucks, and dust blows, you can't hardly win against mother nature, lol. That's why I love az (the valley), she tends to leave us alone for the most part. ha.
  3. Feb 3, 2015 at 10:21 PM
    Chas of MRT
    Chas
    Las Vegas, NV
    06 Tundra V8
    Airaid Bilstein
  4. Feb 3, 2015 at 10:54 PM
    PLC721
    PLC721 Well-Known Member
    Patrick
    Chandler, Az
    2017 Toyota Tundra Crewmax ProKiller
    Kings, Toyos, Baja Designs, TC, SDHQ
    Amber Rigid's do wonders in Fog!
  5. Feb 3, 2015 at 10:59 PM
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    Armour: All-Pro Skid plates - IFS, transmission, and transfer case. Pelfreybilt rear standard plate bumper, Metal Tech Sliders w/ kickout and dimple die filler plates. Front Suspension: OME 885 + NitroCharger 9000 shocks + 1/2" spacers for a 3" lift. Superbumps replacing stock bumpstops. Camburg ball joint UCA SS braid brake lines Future: ADS Extended length, extended length UCA BJ to increase droop capability Rear Suspension: All-Pro Expedition rear leafs, Walker Evans 27" rear shocks, extended rear brake lines (Wheelers Offroad), U -bolt flip kit, rear Timbren bumpstops. Future: Hammer Hangers, Shock relocate, ADS 12" or 14" shock. Interior: Weatherteck floor liners - front, Wet Okoles- front, ScanGauge, LED interior & map lights. Power moonroof. Exterior: Raider Cobra canopy, retrofit headlight by Insight, LED bulbs all around, modified flasher unit for LEDs. Rear diff breather mod. Front diff vibe problem, driver's side needle bearing replaced with ECGS bushing. yet to install: HID Blazer Fog Retrofit, LED Flood & Spot, + switches, fuse panel. swaybar relocate blocks (build my own)
    :thumbsup:
  6. Feb 3, 2015 at 11:02 PM
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    If you're set on amber color for Fog, and LED, then I would recommend actual Amber LEDs, rather than just a filter. This is because of the color wavelength that the Amber LED produces is just the amber, not a range of other colors combined, where as a filter still allows much of the other colors in the spectrum through.
  7. Feb 4, 2015 at 9:30 AM
    Chas of MRT
    Chas
    Las Vegas, NV
    06 Tundra V8
    Airaid Bilstein
    This is true and good advice. The Amber LED chips themselves work a lot more effectively than covers do.
