Good quality touch up paint.
Discussion in 'Detailing' started by Fabulous, Aug 10, 2011.
  1. Aug 10, 2011 at 10:14 AM
    Fabulous
    Fabulous [OP] Well-Known Member
    Fabian
    Calgary, AB
    2017 Tacoma double-cab TRD Sport
    TRD Pro grill and fog lights, Toytec Boss lift, 265/70-17 Duratracs on 17 x 8.5 FN Verge wheels, LEER canopy, 30% tinted front windows.
    I have a couple chips on my truck I want to fix, and I'm looking for a better solution than the crap Toyota touch up pen system. Can anyone recommend a place to get a good quality paint that will match my white Tacoma perfectly, and comes in a bottle? Any help is appreciated.
    Thanks.
  2. Aug 10, 2011 at 10:16 AM
    darkgreentaco
    darkgreentaco XXXL Member
    NorCaL
    Timberland Rocket
    King RR C/O's, Extra mustard, All-Pro expdtn Leaf, sesame seed bun, Icon UCA's Fox Resi's BAMFsliders, sweet candy coating, LCAskids, diffcover 17" Addicts Yukon 4.56 Mt/r kevlar
    Did you try the brush applicator?
  3. Aug 10, 2011 at 10:24 AM
    Fabulous
    Fabian
    Calgary, AB
    Only one available here is the pen type and it sucks. Comes out all watery with almost no coverage.
  4. Aug 10, 2011 at 10:25 AM
    rbeezy
    rbeezy Well-Known Member
    Ron
    Bay Area
    2011 Tacoma SR5
    walmart carries it. they have the touch up pen with a brush on the other end. my dad has a white taco also... and the white i got (specifically for Toyota vehicles) is pretty darn close, if not exactly, to matching the factory paint.
  5. Aug 10, 2011 at 2:18 PM
    daggertats
    daggertats Well-Known Member
    arden nc
    2010 tacoma 4x4 reg cab
    undercover tonneau ,bug deflector, removal of all tacoma emblems added a set of component speakers behind the rear seat egr in channel window visors
    the one i have from toyota is both a pen and a brush,you can use either or but ill agree with you..the pen sucks
  6. Aug 10, 2011 at 2:20 PM
    t4daddy
    t4daddy Well-Known Member
    North Alabama
    2008 PreRunner Double Cab
    Be sure to shake it up very well, makes a huge difference.
  7. Aug 10, 2011 at 4:24 PM
    Fabulous
    Fabian
    Calgary, AB
    Did that...still inadequate. I'll check out Walmart. I remember reading on here once about a place on line that has hood stuff, but couldn't find it with search...
  8. Aug 10, 2011 at 4:34 PM
    dexterdog
    dexterdog My pee parts itch
    Oly WA
    2012 F150
    It's all in the prep and technique. If you want to do it properly you need to sand the chipped area with a fine grit paper. Use a tooth pick to apply the paint to the chip. One dab will usually fill in the chip. A brush is too much.
    This is crucial. Let the paint harden for at least a few days before doing anything. Wet sand with a high grit paper. Polish with a PC 7424 or comparable and wax.
    These are just rough instructions on what to do. You can probably find a youtube video or go to autopia.org.
  9. Aug 10, 2011 at 8:47 PM
    Fabulous
    Fabian
    Calgary, AB
    I know how to do it, I just need better quality paint than the Toyota touch up pen.
  10. Aug 10, 2011 at 9:29 PM
    PR45
    PR45 Well-Known Member
    Los Angeles
    PreRunner SR5 4cyl
    If it's down to the metal, like mine, and rusting under the surrounding paint, like mine, you will need sandable filling primer, also available from this company which has the matching paint. (they had MGM, but I haven't done mine yet so can't tell you the results)
    http://duplicolor.com/products/perfectMatch/
