good remote resi rear shocks
Discussion in 'Suspension' started by 650H1, Aug 14, 2012.
  1. Aug 14, 2012 at 2:18 AM
    650H1
    650H1 [OP] Well-Known Member
    NH
    2010 Tundra TRD OR C/M 5.7l 4x4
    what is everyone using for remote resi's with Dakar leafs? pics would be great!
  2. Aug 14, 2012 at 2:43 AM
    Dirty5Thirty
    Dirty5Thirty TW's BAD MF'er Squad
    Dean
    Auburn, CA
    2003 4Runner SR5
    Dog hair
    Unless you Pre-Run, stick with monotubes. You will be paying several hundred more for a part that you will not ultimately use. The is used to cool whatever is inside the shock absorber, which is not necessary under normal driving conditions.
    Otherwise, if you're super gung-ho on the resi's, Check out the Fox 2.0's... made with the same quality components as the King shocks, and in some aspects, better. Steel braided line inside of rubber. Ribbed reservoir instead of a solid body. Not to mention several hundred less.
  3. Aug 14, 2012 at 4:32 AM
    Pugga
    Massachusetts
    '13 Ford F-150 SCREW
    F-150 Mod
    Talk to Johnnym, he's running Icon RR's with his Dakars and seems to like them.
    I agree with Dirty5Thirty though. Unless you need the high speed dampening, remote resi's aren't necessary, the standard shock from Icon, Fox, King or even OME or a higher end Bilstein will be more then sufficient and a lot less money.
