Good SD/OC cap installer?
Discussion in 'Southern California' started by GroovyGeek, Apr 13, 2020.
  1. Apr 13, 2020 at 1:19 AM
    GroovyGeek
    GroovyGeek [OP] Member
    Any recommendations for a good cap installer in SD/OC, maybe even LA area? Total Taco noob. Despite the great off-road handling, I am getting tired of my Wrangler's "feautres" (crazy wind noise above 65 mph, piss poor handling) as a daily driver and long road trip transport. Looking for some more space and contemplating a Taco extended cab with a 6ft bed and a cap. Have spent the past 12 hrs reading and watching Youtube videos, and it seems that the difference between A.R.E., LEER, and SnugTop is largely determined by the skill of the installer. - more so than the brand. Is there someone who has consistently been doing high quality work in SoCal? Thx
  2. Apr 13, 2020 at 7:57 AM
    Narty
    Narty Well-Known Member
    Orange County
    1998 Black Tacoma ext cab 4x4 A/T
    OME nitrochargers, Dakars+AAL, JBA UCA 285/75/16 Nitto Ridge Grapplers on TRD baja "beadlocks" Flippac
    pretty simple to do yourself with another friend. if you're adamant about getting it done at a place, i used discount camper shells in long beach when the previous owner ripped the wiring out of my shell and needed them to wire it for the 3rd brake light for me. super nice dudes and do good work, right off the freeway too.
    GroovyGeek[OP] likes this.
  3. Apr 13, 2020 at 8:24 AM
    FishN'Taco
    FishN'Taco Well-Known Member
    lucas
    San Diego, CA
    18 TRD OR DCSB
    Fox 2.5 Ext Travel w/ Adj Reserviors (3") ACCUTUNED Camburg Uniball UCA Deaver u402 stage 1 Leer 100XQ Front Runner Slimline II Rack Baja Designs Onx6+, SQ-Pro, SQ-Sport Switchpros 9100 285/70/17 Falken AT3W on 17 Method 305 NV RIGd Ultraswing Powertank 10lb
    leer truck accessory center on engineer road. do a VERY thorough inspection of the shell before and after it goes on your car. bring up any imperfections in the shell. in my opinion the leer mounting system (speaking from experience) is complete dogshit. comes loose, just use a bolt that cannot fit flat/flush with the camper which bends the bolt and allows camper to come loose very easily.
    Speed Freek and GroovyGeek[OP] like this.
  4. Apr 13, 2020 at 8:38 AM
    GroovyGeek
    Thanks, I was assuming, perhaps incorrectly, that whatever warranty is there is void if I self install. I realize that the process is no more complicated than putting a hardtop on a Jeep - a couple of brackets, some gasketing, an electrical disconnect, and you are mostly good to go. Will look into Discount Camper Shells - they are a SnugTop dealer.
