Good Setup?
Discussion in 'Suspension' started by 0BlackTaco6, Sep 24, 2010.
  1. Sep 24, 2010 at 4:00 PM
    0BlackTaco6
    0BlackTaco6 [OP] Ive got tiger blood
    New Hampshire
    06 BSP DC SR5 4x4 6 speed
    Color matched and satoshi grille, hella 500ff behind, bhlm, sockmonkey bedsides, 17" sports 265/70 grabber at2's.
    I have a 2006 sr5 DC 4x4, planning on buying a lift to put it up about 3" and I think this is where im at......
    Bilstein 5100's all around
    OME 885 coils possibly with the top plate spacer.
    2" AAL Toytec
    4x4 Diff Drop Kit
    I do just minor off roading, your typical trail stuff. Is this a decent set up or would it be better to go with a longer travel shock? If so on the longer travel shock which ones? Thanks in advance for any advice or criticism.
  2. Sep 24, 2010 at 4:07 PM
    10PreRunner
    10PreRunner Well-Known Member
    Kevin
    Knoxville, Tennessee
    2013 SR5 4x4 Double Cab
    I'm wanting to do the same thing but if you put a 2 inch AAL in the rear how do you get a 3 inch lift?
  3. Sep 24, 2010 at 4:18 PM
    0BlackTaco6
    New Hampshire
    if ive done my reading correctly the back sits a bit higher than the front to begin with. So i believe with this setup it should sit fairly close to level. I could be wrong but im sure someone else would be able to answer it better.
