Good Shop To Install ARB Front Locker, South Bay?
Discussion in 'Northern California' started by tacomtn, Jan 16, 2012.
  1. Jan 16, 2012 at 3:37 PM
    tacomtn
    tacomtn [OP] Well-Known Member
    TRD OR,OME,Deaver AAL
    I'm thinking of having an ARB front locker installed and wanted to know if anyone has some recommendations for good shops. This seems like a fairly complicated, time-consuming job for a weekend garage attempt, unless someone has done it with good sucess.
    Anyone?
  2. Jan 17, 2012 at 4:53 PM
    tacomtn
    Someone's got to have info on this...anyone, someone....
  3. Jan 17, 2012 at 4:58 PM
    JLee
    JLee The Man! Vendor
    Jerry
    Bay Area NorCal
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    The first question I have is why are you thinking of getting a front locker? I can't see you on a trail where front lockers would be needed. I've ran plenty of trails around here with a open front diff that I don't see you taking your truck on. No offence but front lockers = trails that cause body damage. I would buy a bunch of armor before you get a front locker.
  4. Jan 17, 2012 at 6:43 PM
    t4r4life
    t4r4life poptard and protein farts
    Eric
    East Bay Area
    1998 Toyota 4runner
    panty dropping mod
    x2
    hit the nail right on the head, when your rig looks like a crushed beer can then its time for front locker lol im getting there.
  5. Jan 17, 2012 at 9:23 PM
    tacomtn
    I'm looking into it because my front diff bearings are shot and guess what, dealer is not covering it. Guess what again, they don't sell just the friggin bearings. No, you've got to replace the whole diff!! Toyota quoted me $3100 to replace it, and from what I've read, the problem might just return. The ARB has better bearings and bushings and should last longer even with the excessive axle angles, at least that's what I understand. Correct me if I'm wrong.
    So, you're correct. I don't need a front locker. But it'll cost me less than a factory diff with a likelihood that the bearings will go bad again vs. ARB which should last longer.
    Or maybe just replace with an aftermarket open diff, remove the lift, and not run the chance of recurrent diff bearings, axles, CV boot and joint problems and funky, annoying VSC ABS activation when driving 20mph on frwy onramps.
  6. Jan 17, 2012 at 9:30 PM
    IndianTaco
    IndianTaco Well-Known Member
    Sounds like its a great time for a S.A.S.:eek:
  7. Jan 17, 2012 at 9:41 PM
    TACWUT
    TACWUT Well-Known Member
    San Diego
    12 prerunner DC
    Flowmaster turndown, 5100 up front/5150 rear, maxtrac spindles, 2" tuff country add a leaf+TSB.
    South bay san diego?
  8. Jan 17, 2012 at 9:42 PM
    TACWUT
    San Diego
    12 prerunner DC
    My bad i thought i was in the so cal thread! Bye
  9. Jan 17, 2012 at 9:51 PM
    MonkeyProof
    MonkeyProof Power Top
    SoCal- SGV
    hold off on everything!!!! Chase from East Coast Gear Supply is working on a solution for the bearings and especially the weak bushing..here is what he is working on..
    http://www.tacomaworld.com/forum/2n...l-bearing-vibration-thread-4.html#post4240041
    http://www.tacomaworld.com/forum/2n...l-bearing-vibration-thread-4.html#post4302808
  10. Jan 17, 2012 at 9:54 PM
    MonkeyProof
    SoCal- SGV
    but to answer you original question..you can send everything down to Marlin Crawler which is in Fresno.
    or you can go with the number one person for the install which is Chase from East Coast Gear Supply but he's in NC so you woul have to ship it to him but will worth it!!
    removing and installing the front diff is fairly easy, you can do it yourself..installing the ARB..thats something that should be left for the experts haha
  11. Jan 17, 2012 at 10:46 PM
    tacomtn
    Yeah, I've been following the thread with Chase's videos. I hesitate on his bushing because it's experimental, not proven on/off road yet. He's still looking for a truck to install it on and put miles on. Then I'd have to send it in. I can't have downtime since it's my DD. Downtime, labor to install/remove, costs to ship back and forth. All for an experimental design and material. At least the ARB is proven with already.
    Now I'm thinking, even with an ARB I still have the steep angles on the axles, which leads to potential CV problems. Oh no! To keep a lift maybe an RCD kit is in order. This kit allows for straight axle angles. BUT the minimum lift is 4" and....Ouch, yet another $1900 plus install costs and time. And then I still might have driveline issues!! Oh, and I'd have to cut the crossmember. There goes the factory frame warranty!
    Hmm, maybe better forgo the whole lift idea instead, this is getting expensive and more headaches
  12. Jan 17, 2012 at 11:08 PM
    MonkeyProof
    SoCal- SGV
    oh i hear ya..it all adds up, one thing affects the other and so forth..
    one thing about Chase is he IS the world renowned gear and differential man..so he knows his stuff! the down time sucks, i know all about that!
    i would skip any drop bracket lifts, especially just to maintain CV angles. there are plenty of peeps here on TW with a good quality mid travel kit that dont have any problems with the CV's. and a few with the ARB in the front as well. and those that do are only having problems with the boots. it's a rare occurrence that you'll hear that someone broke a 05+ CV joint. All Pro Off Road sells CV boots that are awesome! i have not had any problems with ripped are torn boots with their version.
    just a little something to take into consideration.
  13. Jan 17, 2012 at 11:13 PM
    tacomtn
    Ok, well maybe those AP boots would be in order if/when mine blow. But still the downtime would get expensive in itself. I'd have to rent a car. after a few days rental, that adds up $$$$$.
  14. Jan 18, 2012 at 4:48 AM
    rbeezy
    rbeezy Well-Known Member
    Ron
    Bay Area
    2011 Tacoma SR5
    contact George at SWAT Customs in Fremont. i've dealt with him before and he does good work
  15. Jan 18, 2012 at 7:27 AM
    JLee
    Jerry
    Bay Area NorCal
    Are you talking the needle bearings? Because that's not that bad we have done those at my mod days and its way less then a ARB that you would never use.
  16. Jan 18, 2012 at 5:21 PM
    tacomtn
    Yeah, after talking with Chase at ECGS I'm going to wait. His new bearing might be the answer-all. And you're right, Jerry, I'll break out the mountain bike before I use that locker on a trail. Plus the $$$$ of said ARB, yikes! That's a new bike frame right there:D
    When I do get the new parts, I could use help with install. Next mod day?
    George @ SWAT. Doesn't he do lifts only? Or is he a do-it-all shop?
  17. Jan 18, 2012 at 7:12 PM
    rbeezy
    Ron
    Bay Area
    2011 Tacoma SR5
    ^^ good question. he did all my suspension work on my past rides, so as far as that, hes good. for what you need, you might need to give him a call and ask him
  18. Jan 20, 2012 at 1:41 PM
    daPitbull
    daPitbull Member
    Oakland
    2008 4runner 8-banger
    Get with Jeff at Toy Connections in Santa Clara. He did my lockers and others I know.
  19. Jan 31, 2012 at 7:23 PM
    tacomtn
    Great. What did that cost, if I may ask?
  20. Feb 5, 2012 at 10:33 AM
    ian408
    ian408 Well-Known Member
    Ian
    Santa Clara, CA
    09 Tacoma
    3" lift, custom rims, snug top shell, shrockworks bumper, warn winch.
    Superior 4Wheel Drive in San Jose. Troy does good work and more importantly, stands behind the work he does. He was also reasonably priced too.
