good solvent for engine oil
Discussion in 'Technical Chat' started by takoashihaisen, Mar 27, 2018.
  1. Mar 27, 2018 at 7:56 PM
    takoashihaisen
    takoashihaisen [OP] Well-Known Member
    island, WA
    2015 AC 4X4 4cyl M/T SR MGM
    successfully installed 3 windshield cracks
    Hello,
    I recently did oil change on my Tacoma by myself. I used a graduated cylinder and I would like to clean the inside. What is the good (and cheap) solvent to clean it up?
    I plan to change the differential oil and transmission oil in the near future. Ideally, the solvent should work on all these oils.
    I might have left over mineral spirits. Does it work?
    Thanks
  2. Mar 27, 2018 at 8:00 PM
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    Brake cleaner, or carb/choke/throttle body cleaner
    takoashihaisen[OP] likes this.
  3. Mar 27, 2018 at 8:51 PM
    Sprig
    Sprig Well-Known Member
    Ken
    N. Calif. The Twilight Zone
    Tacoma TRD double cab 4x4, Barcelona Red
    Why in the hell do you want to use a solvent??? Why do you think you need to use a solvent??? I’m just curious, I’m sure you have a good reason.
  4. Mar 27, 2018 at 9:04 PM
    takoashihaisen
    island, WA
    I want to remove the residual engine oil inside the graduated cylinder so that I can use that graduated cylinder for another purpose - for example, changing the differential fluid, though some might say you do not need to use a graduated cylinder.
    I thought about wiping the inner wall of the graduated cylinder with cloth, but it is hard to reach the bottom of the graduated cylinder and it might leave some fiber/filament. I do not need to use solvent as long as the inner wall of the graduated cylinder is cleaned.
  5. Mar 27, 2018 at 9:05 PM
    taco2010trd
    taco2010trd Cyber Bully
    Tampa, Florida
    2010 Silver TRD OR DCSB
    I believe he wants to clean the container he used to do oil change. :notsure:
  6. Mar 27, 2018 at 9:14 PM
    Sandman614
    Tim
    '06 SR5 Off Road
    Solvent = cleaner
  7. Mar 27, 2018 at 9:25 PM
    bliznack
    bliznack Well-Known Member
    Jake
    PNW
    '13 2.7l 5-speed 4x4
    Use a good dish soap, a brush, and hot water. Rinse the hell out of it and let dry. Get a graduated cylinder brush, or a bottle brush (homebrew shop) to reach the bottom.
    If there is still residual oil, you can use hexane to dissolve it.
    Just curious, why are you using a graduated cylinder for oil changes?
  8. Mar 27, 2018 at 9:49 PM
    Sprig
    Ken
    Thanks for the clarification. Wasn’t clear why you wanted the solvent.
  9. Mar 27, 2018 at 9:51 PM
    US Marine
    US Marine Semper Fi
    Chuck
    Gallatin Tennessee
    02 Pre Runner supercharged 4cyl
    TRD supercharger , Doug Thorley header , K&N CAI 265/75-16 Toyo open country mud terrain , 15x8 Method Racing wheels , Rancho 3" lift , 4.88 gears , Detroit Locker
    Use the dish washer when the wife isn't around !!!
  10. Mar 27, 2018 at 9:52 PM
    ppham444
    ppham444 Well-Known Member
    Phuong
    Portland, OR
    2023 White TRD Off-Road doublecab
    Brake cleaner is very good at cleaning grease and oil.
  11. Mar 27, 2018 at 10:06 PM
    takoashihaisen
    island, WA
    Thanks. Okay, hexane!. Well, I did not know the engine oil plastic bottle has a scale until I started the oil change work. Since I have already bought a graduated cylinder, I had to use it!
    I probably should have used the term "cleaner". As a chemist, I am more used to say "solvent".
    Um, the engine-oil flavored plates:eek:
  12. Apr 2, 2018 at 10:10 AM
    Armkb
    Armkb Well-Known Member
    Hudson Valley, New York
    09 TRD Sport DCLB
    Bilstein 5100, OME 885X, LR UCA, ARB/EL095R, ES LCA Rack & Sway Bar Bushings, Yellow Wire Mod, ABS Switch, TPMS Mod, Scanguage, Toyota Bed Mat, WeatherTech Floor Liners, Extang Trifecta Cover, Fumoto Drain Valve
    Kerosene
