Good Stock Shocks for my 2020 Tacoma
Discussion in 'Southern California' started by TerryTaT, Mar 4, 2024.
  1. Mar 4, 2024 at 6:54 PM
    TerryTaT
    TerryTaT [OP] Active Member
    Terry
    White 2020 Tacoma TRD Sport
    Lot's of subtle things along with All Terrain Tires. Just enough to keep it very clean but subtly different than any others I've seen.
    For years I customized everything but I've reached a point where I just want to keep my truck stock aside from upgrading to a more aggressive tire.
    Where is the best place to get new shocks for my truck. I have no problem ordering them online.
    I Love the way the truck sits now and simply want a great stock shock.
    What is the best place to buy them and what would be the part number?
    2020 2 wheel drive TRD Sport..
    I already have my own mechanic.
    Thank you all in advance!
  2. Mar 5, 2024 at 11:26 PM
    TacoTuesday1
    SD CA
    Stock on an old 4runner pro is 6112/5160. That is or is similar to stock travel.
    So is Fox on Taco Pro
    then there is 4600 and 5100, basically same thing
    one for no lift, one for lift
    both skinny and not that good
    or if you want skinnier and worse than that for more money, factory.
    Your shocks are likely not worn on a 2020. Putting the same shock would not change anything.
    There is no great stock shock. It's not an M5.
    TerryTaT[OP] likes this.
  3. Mar 6, 2024 at 12:29 AM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    KYB gas adjust or KYB GR2 are great affordable shocks.
  4. Mar 6, 2024 at 6:48 AM
    TerryTaT
    Terry
    Thank you both for your kind response! I appreciate the insight and suggestion !!!!
  5. Mar 6, 2024 at 6:54 AM
    Clinch Mountain Preacher
    Clinch Mountain Preacher Serpent handler
    3rd gen AC SR5 4x4
    5100 and be done with it
