good suspension lift
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Ry44, Dec 16, 2015.
  1. Dec 16, 2015 at 7:05 PM
    Ry44
    Ry44 [OP] New Member
    What is a good 6 inch lift to put on that will still kind of keep factor ride? I want bigger tires but don't want to spend money on new rims. My stock rims are 18". Can my stocks fit on a tire size of 285/70/18?
  2. Dec 17, 2015 at 12:38 PM
    eldedo
    eldedo voted most likely eaten by a bear
    Mojave Desert
    '16 DCSBOR 4X4
    2888/5100/Dakars 285's/Camburgs
    stocks rims are 16 or 17" so no on the tire size. Read a bit and you'll learn.
  3. Dec 17, 2015 at 12:41 PM
    geekhouse23
    geekhouse23 The "Liftman" - @DrFunker
    2GMGMDCSB4WDTRDFTMFW!! TL;DR
    mostly stock, grocery gettin' Prius
    Why do you want a 6" lift?
    moe2o4 likes this.
  4. Dec 17, 2015 at 12:44 PM
    crappie man
    crappie man Well-Known Member
    I know bds is adapting their lift and some have modified the ones for the 15 model to work. If you get full kit with coils and everything it will ride better than stock depending on tires you choose because you usually go to an e from a b or c. I called bds and I suspect we should see the modified lift for the 16 pretty soon. not sure about toy tech but their build 16 looks good. Not sure on lift size
  5. Dec 17, 2015 at 12:49 PM
    dakotasyota
    dakotasyota Just a Fringe of the Ging in your Minge
    Dakota
    Ellensburg, WA
    06 Access Cab, Manual, V6, 4x4, TRD Off-Road
    Total Chaos +2 LT w/ 2.5 x 8 Kings, 700 lb coils, Chevy 63s, BAMF Shock relocation, 12" King Smoothies, Locker Anytime Mod, 5% Tint All Around, 4xInnovations full skids, Custom Made Rock Sliders, 4xInnovations HC Rear Bumper w/ Tire Carrier, SOS Original Plate 2 Front Bumper, 130 w KC Slimlites, Homertaco Raptor Grill, Bestop Supertop, Smittybilt 9500 lb winch, Flowmaster 40 series, JVC deck w/ 12" Rockford Fosgate T1 in custom box, and lots more!!
    All 6" lifts will be drop brackets, so your factory suspension angles will remain the same = stock ride.
    No your factory wheels won't work with 285/70/18 cause that takes an 18" wheel... You either have a 16" or 17"
  6. Dec 17, 2015 at 12:51 PM
    dakotasyota
    Dakota
    Ellensburg, WA
  7. Dec 17, 2015 at 12:53 PM
    Toyota Kawasaki
    Toyota Kawasaki Seasons Beatings
    2016 TRD OR
    First. What do you want to do with the truck? Are you going to hit the trails? Or is it a pavement princess? Drop kits aren't really the best setup for offroad.. Either way, you can do Icon's front and OME leaf pack rear for approx. 3" which should clear 285's depending on wheel choice/offset etc.. Then add a 1" body lift if necessary but I would skip the BL imo.. Just a thought.. J.
  8. Dec 17, 2015 at 12:54 PM
    Ry44
    Just want the lift for looks and my stock rim size is 18" cuz I got the limited.
  9. Dec 17, 2015 at 5:48 PM
    knhorn
    knhorn Well-Known Member
    San Diego
    2016 TRD Sport DCSB Quicksand
    Icon Stage 5 set at 3", Toyo ATII, Fuel Throttle
    Limited models come with 18" wheels..
  10. Dec 17, 2015 at 5:49 PM
    dakotasyota
    Dakota
    Ellensburg, WA
    Ew I forgot about that. Then yes.
