Goodbye Axle Wrap Mod
Discussion in '1st Gen. Tacomas (1995-2004)' started by iDigTulsa, Aug 14, 2010.
  1. Aug 9, 2012 at 3:05 PM
    #181
    monkeyface
    monkeyface Douchebag, or just douche if we're friends
    Colorado
    '90,'97,'12,'05 Tundra 4.7,'07 T4R 4.7,'08 T4R 4.7
    Does this mod reduce the articulation off-roading, the drop the rear suspension needs to keep both rear tires on the ground?
  2. Aug 9, 2012 at 3:57 PM
    #182
    austinramsay
    austinramsay Well-Known Member
    Austin
    Yuma, Arizona
    2001 Tacoma TRD Doublecab
    Not sure about how it affects flexing but it does make the back stiffer, so im guessing it will affect it.
  3. Sep 18, 2012 at 4:28 PM
    #183
    Agk007
    Agk007 New Member
    Austin
    '12 Tacoma 4x4 TRD Offroad
    Bone stock........for now
    Hey everyone, i have a 2012 Taco that has the 3 leaf set. Since off the lot it squats bad on acceleration and feels kinda weak in the rear. I want to stiffen up the rear with this mod, but i also noticed some guys said it helped with shudder? my truck has the dreaded shudder on acceleration and braking. Would this mod help that as well? i can only think the shudder is exacerbated because of axle wrap since it changes driveline angles. since its mostly on acceleration i feel this vibration, would it be right to put the clamps behind the axle instead of the front since when you accelerate the axle turns up so the springs fan at the back?
  4. Sep 18, 2012 at 5:22 PM
    #184
    kingston73
    kingston73 Well-Known Member
    North eastern Ohio
    09 SR5 4.0L 4x4
    I know this is the 1st gen section but I have a 2nd gen also and added my old set of under-leaf helper springs to the front and a set of overleaf helpers to the back. It definitely makes a difference without making the ride harsh.
  5. Sep 18, 2012 at 8:41 PM
    #185
    FailRated
    FailRated RTO
    Evan
    Maryland
    03 Double Cab TRD
    5100's w/ Eibachs, Front sway bar in trash mod, Diff drop, 265/75-16 Duratracs or 33x10.50 KM2's on 15x8 wheelers steels, ARB front bumper, Warn VR8000 winch, Trailgear sliders, Allpro rear bumper, Sky Offroad E-Locker guard, Sky Offroad weld on differential guard, Savage skid plates w/ Budbuilt cross member, e-locker rear, ARB air locker front, 4.56 gears, bought it from my mom who bought it new :-D
    I always wondered why I didn't have the horrible axle wrap everyone always talks about and I have 1" lift blocks:eek: on stock springs:eek::eek:
    I installed similar helper springs about 6 years ago when I was pulling a heavy trailer everyday. Only difference is mine seem to be a little more vehicle specific and are mounted behind the axle and on top of the leaf spring(see photo below). They are now loosened up almost completely since I don't really tow much anymore but they are still on there and I still have zero axle wrap.
    Mine seems to do pretty well and my shocks are too short as well.
  6. Oct 10, 2012 at 10:18 PM
    #186
    austinramsay
    Austin
    Yuma, Arizona
    thats probably your drive shaft
  7. Oct 12, 2012 at 9:52 PM
    #187
    BamaToy1997
    Bill
    Navarre, FL
    Just an FYI, you never should use a flat washer with a lock washer. It defeats the purpose of a lock washer. The lock washer edges are designed to bite into the nut, and the surface you are tightening against. If you put a flat washer under the locking washer, then the lock washer will bite into the nut and the flat washer....which is simply pressed against the surface. This would allow the POTENTIAL (Re-read that word, I did not say guarantee) that a nut installed this way could loosen up.
  8. Oct 15, 2012 at 5:46 AM
    #188
    BamaToy1997
    Bill
    Navarre, FL
    Step 1, move mouse to upper right corner or browser tab
    Step 2, place cursor over little "X"
    Step 3, close eyes
    Step 4, Just say "click!"
    lol
  9. Feb 17, 2013 at 6:48 PM
    #189
    wannabe92z
    wannabe92z Member
    K&N air filter
  10. Feb 17, 2013 at 8:18 PM
    #190
    TacoDell
    TacoDell Truck ~n~ Tow
    SoCal
    '00 Tacoma SR5 4X
    Donahoe CO's, Deaver leaf paks, Lockright Locker, All Pro body armor ( sliders, front and rear bumpers ), All Pro under belly skids, Warn M8K w/Masterpull synthetic line, Dual Optima battery system, 4 ea LightForce Striker 170 offroad lights, 8 ea wired rock lights, and plenty more I'm sure
    This U bolt clamping of the leaf spring pak
    is the worst bandaide idea I've read of.
    possibly even unsafe
    mfg'r designed leaf spring u bracket clamps are not U bolt clamps...
    and do not sandwich (clamp) individual leafs together.
    usually the lower U bracket is riveted to a lower leaf in the pack
    and the upper closure of that is a roller (bolt w/roller sleeve)
    individual leafs that are clamped cannot flex properly during compression.
    this can cause a bouncier ride at the rear.
    because the individual leafs in the pak are binding.
    when individual leafs in a pack are compressed...
    not only do they bend (flex)...
    but they also shift outward of the center of the leaf pack.
    installing U bolt clamps to limit leaf spring movement...
    isn't a proper correction for axle wrap.
    I had Deaver custom build me some 9lf paks...
    with consideration of the common axle wrap issue.
    What was engineered, eliminated axle wrap to nearly nonexistent.
    and with minimal compromising of the leaf paks full flexibility.
    Generally most axle wrap occurs at the forward end of the leaf pak.
    There, the leaf pak will twist and arch when under load.
    Stiffening up the forward side of the leaf pak will help
    in combating axle wrap.
    Too stiff tho' and it could degrade compression/droop travel some.
  11. Feb 17, 2013 at 8:30 PM
    #191
    jandrews
    '09 FourDubDee TRD OR
    Spring clamps will work. They're not unsafe, they are cheap, and they will likely wear out your spring pack quicker than other options.
    A traction bar is the best fix for the axle wrap issue; understandably many people may not want to go to the cost and trouble of having one done up right. Unless you're working the truck hard offroad or regularly towing heavy loads, it's probably not needed.
  12. Feb 17, 2013 at 8:42 PM
    #192
    TacoDell
    SoCal
    '00 Tacoma SR5 4X
    ^ X2 ...but not the more common ladder type traction bars.
    more similar to this single trac bar...
    ^ edited for replacement pictar
  13. Feb 17, 2013 at 8:51 PM
    #193
    jandrews
    Nah...you need the ladder frame type. A single bar heimed at each end won't effectively limit axle housing rotation. Putting one end on a less flexible joint (say, just a bolt and bushing) might be adequate, but will likely bind with suspension articulation.
    Ladder-type bar rigidly mounted to the axle housing with a heim/shackle connection to a frame crossmember is ideal on these trucks.
  14. Feb 17, 2013 at 9:00 PM
    #194
    TacoDell
    SoCal
    '00 Tacoma SR5 4X
    I typed single... meaning... only one
    Not a single bar (tube)
    yes I suppose a "A" frame could still be considered a ladder bar
    so that was a poor choice in wording on my part.
    that is why I put the picture up.
    tho' maybe not a perfect example... it brings it closer.
  15. Feb 18, 2013 at 4:43 AM
    #195
    jandrews
    Ah I gotcha now...yeah, A-frame/ladder are often used interchangeably.
    Just FYI, your picture is not showing up for the rest of us.
  16. Feb 18, 2013 at 10:10 AM
    #196
    TacoDell
    SoCal
    '00 Tacoma SR5 4X
    oh... didn't realize.
    how 'bout now ?
  17. Feb 18, 2013 at 2:15 PM
    #197
    jandrews
    That got it. Here's mine:
  18. Feb 18, 2013 at 3:28 PM
    #198
    StAndrew
    StAndrew Wait for it...
    Hampton Roads, Va
    SR5 4x4TRD
    Intake, exhaust, lift. Typical stuff.
    Wouldnt this limit down travel?
  19. Feb 18, 2013 at 3:47 PM
    #199
    jandrews
    Mine won't. I can't see the shackle setup on Dell's example to give it a yes or no. There needs to be a heim, creeper, uniball, or some kind of spherical bearing in there to allow the axle to articulate without binding.
    Here's the attachment:
  20. Feb 18, 2013 at 4:15 PM
    #200
    wolfgang123
    wolfgang123 Well-Known Member
    Skyler
    Charlotte, NC
    1997 TACOMA - 4x4
    you need to re-enforce that cross member, OEM is not built to handle that much force
