Goodbye Axle Wrap Mod
Discussion in '1st Gen. Tacomas (1995-2004)' started by iDigTulsa, Aug 14, 2010.
  1. Feb 18, 2013 at 4:51 PM
    #201
    jandrews
    '09 FourDubDee TRD OR
    No you don't. It's not that much force.
  2. Feb 18, 2013 at 7:13 PM
    #202
    TacoDell
    TacoDell Truck ~n~ Tow
    SoCal
    '00 Tacoma SR5 4X
    Donahoe CO's, Deaver leaf paks, Lockright Locker, All Pro body armor ( sliders, front and rear bumpers ), All Pro under belly skids, Warn M8K w/Masterpull synthetic line, Dual Optima battery system, 4 ea LightForce Striker 170 offroad lights, 8 ea wired rock lights, and plenty more I'm sure
    yeah the picture I posted is an inferior example.
    that forward shackle/bushing thang looks no bueno.
    yours is superior in design and a much better example :thumbsup:
  3. Feb 18, 2013 at 9:28 PM
    #203
    SpeedoJosh
    SpeedoJosh Well-Known Member
    Florida
    2010 Access cab, Base, 4x4
    Bet those don't cost only $15 though :stirthepot:
  4. Feb 19, 2013 at 4:42 AM
    #204
    jandrews
    I used spring clips a bit before I got the bar. They help...for a bit. They wear your leafs out quicker (due to creating a cyclic flexion point in the leafs) and eventually the floppy point just moves to where the clamp is, and the problem re-emerges.
    Over the life of the truck, I'll bet the traction bar costs less, because I'm sure it'll save me at least one leaf spring replacement. And they (traction bars) aren't as expensive as you might think.
  5. Feb 19, 2013 at 12:49 PM
    #205
    StAndrew
    StAndrew Wait for it...
    Hampton Roads, Va
    SR5 4x4TRD
    Intake, exhaust, lift. Typical stuff.
    I got that, but what about the length diff as the axel articluates. The drive shaft has a slip joint to accomodate, does the traction bar?
    Edit, Nvmd, I see it.
  6. Feb 20, 2013 at 9:00 AM
    #206
    wolfgang123
    wolfgang123 Well-Known Member
    Skyler
    Charlotte, NC
    1997 TACOMA - 4x4
    maybe on your 09 that cross member is stronger...on my 97 that cross member looks WAY to thin and has way too many holes in it for me to trust it.
  7. Feb 20, 2013 at 9:24 AM
    #207
    jandrews
    All its resisting is whatever amount of tractive force allows the truck to move. In neutral, an able human being can push one of these trucks by hand. Unless you can bend the crossmember by hand, you really don't have to worry about it. Traction bars don't typically resist great forces, its just in stock form, there's nothing there to resist that force at all. Axle wrap wouldnt be a problem but for the possibility of binding u joints, ring and pinion deflection, and wheel hop. Wheel hop especially can be very damaging to driveline components...its basically like hitting the rear axle with a giant impact hammer. With a traction bar, the wheels either break loose and spin on the ground or the vehicle moves. There's no hop to wreck your gears .
    That crossmember is made of thin steel, but its c channel with rolled lips. You might be surprised how much strength that adds.
  8. Feb 20, 2013 at 5:15 PM
    #208
    pickuptruckguy
    pickuptruckguy Well-Known Member
    SoCal
    04 Doublecab 4x4
    ...Back to the axle rap U bolt mod, what would the advantages and disadvantages be of installing the U bolt around the 2 leafs and the overload leaf instead of just around the 2 leafs?
  9. Feb 20, 2013 at 5:29 PM
    #209
    wolfgang123
    Skyler
    Charlotte, NC
    1997 TACOMA - 4x4
    Im not talking about under normal driving conditions, im talking about on the trail flex, when the trac bars heim joints max out and your suspension still has room for more flex all of that force is being transferred and held in that traction bar, which is now in a sense holding "up" the weight of your rear axle or the force of the leaf springs and gravity attempting to flex the axle (really bad description but the best one i can think of at the moment) this flex i am worried will tweak and twist your cross member.
    My cross member does not have rolled lips but straight up holes like you'd make with a hole saw. So +1 to you :cool:
    if you clamped the overload to the rest of the springs i imagine it would stiffin the hell out of your ride considering the overload bar is so thick and is only there to support the leaf springs when LARGE amounts of weight are in the bed/being towed
  10. Feb 20, 2013 at 6:11 PM
    #210
    SpeedoJosh
    Florida
    Ok, so picked up the u-bolt pack yesterday.
    So I installed them about a fist length from the axle mount on each side. Tightened them down a pretty decent amount
    Passenger side
    Driver side
    Problem is, it feels like my truck is more stiff/bouncy on bumps. Did I put them in the right place, or maybe tighten them too much?
    I didn't have any problems when stopping like most complain of, but it did feel like when I would go over bumps, usually in the lower speed acceleration, my rear end would bounce around, almost like it was skipping. Which is the reason I installed these.
    Haven't hit many big bumps to see if that bump is still there.
    Fullsendcf likes this.
  11. Feb 20, 2013 at 6:49 PM
    #211
    jandrews
    Stiffer ride, more resistance to wrap.
    If the trac bar is designed properly, that should never happen. Mine doesn't bind at all at full suspension travel. The misalignment spacers on the heim joint allow for 34 degrees of articulation. That's...a lot. With my shackle flip and relocation shock mounts plus 15in travel shocks, my rear axle flexes a little over 20 degrees. To get over 30 on these trucks you're going to have to seriously re-engineer the rear end, probably with a coil-link suspension, and remove the bed.
    You can see here the delta between frame and axle is nowhere close to 30 degrees...I'm not at full flex in this picture (close, but not quite) so this is probably somewhere in the high teens in terms of angle...
    If a trac bar binds at full flex, it was mocked or installed wrong, or both. It should never carry the weight of the vehicle, just locate the axle within the rotational plane of the wheels.
    Clamping the springs effectively combines all the leafs into one in the area behind the clamp. This effectively stiffens spring rate in that area. That's why it decreases axle wrap, but yes, it will also result in a rougher ride.
    Including the overload leaf will also worsen this issue. It's made for extremely heavy loads and has an extremely stiff rate.
  12. Mar 23, 2013 at 5:49 PM
    #212
    03taco88
    03taco88 Well-Known Member
    South MS
    Stock for now Mods to come 6" w/35's HID's 5% tint
    Would an AAL fix the springs back to have an arch and solve axle wrap?
  13. Mar 27, 2013 at 9:15 PM
    #213
    payrow
    payrow Well-Known Member
    Los Santos
    '18 DCSB Sport
    Subbed.
  14. Mar 27, 2013 at 10:44 PM
    #214
    Geosh
    Geosh Why yes, I AM a rocket scientist.
    Chandler, AZ
    '03 PreRunner DC, 3.4L
    So looking at my rear leafs today, they are pretty flat across. Should they have a bit of upward bow (U shape) without any additional load? Wondering if my leafs are worn out and I should just replace them before trying any clamp fixes. Also, what springs should I replace them with if need be? It is a 03 TRD DC Prerunner.
  15. Mar 28, 2013 at 10:23 AM
    #215
    wolfgang123
    Skyler
    Charlotte, NC
    1997 TACOMA - 4x4
    Depends on how flat they are now and what kind of AAL you buy. But any AAL will help relieve some weight from the spring pack and return the arch probably not as good as new but it helps.
    Solve...no
    Help a little?...Maybe
  16. Mar 28, 2013 at 10:32 AM
    #216
    03taco88
    South MS
    Good deal might do the 3pack leaf spring before I save up for Dakar's
  17. Mar 28, 2013 at 10:46 AM
    #217
    wolfgang123
    Skyler
    Charlotte, NC
    1997 TACOMA - 4x4
    A progress AAL like that would be perfect if you spring for the extra $
  18. Apr 10, 2013 at 10:18 PM
    #218
    payrow
    Los Santos
    '18 DCSB Sport
    Picked up my spring clamps from Autozone today, gonna get some washers and install them this weekend. I really hope you guys are right and this gets rid of the f-ing bump! I'll let you guys know the results.
  19. Apr 14, 2013 at 9:02 PM
    #219
    payrow
    Los Santos
    '18 DCSB Sport
    Well, completed the install and after driving around yesterday and today....NO MORE BUMP!!!!
    Thanks for your help guys!
    Installed the 2.5 in wide (Autozone Part Number: 13-1401A) clamps about 4in in front of the axle and torqued them down to 50ft lbs. That did the trick!
    I am happy happy happy. :D :D :D
    Fullsendcf and Mickmoss like this.
  20. May 10, 2013 at 3:20 AM
    #220
    bldegle2
    bldegle2 OldPhart
    San Francisco, Ca.
    2009 Prerunner TRD AccessCab
    New Navigation DVD/CD/TV/AV/Bluetooth Stereo and seat mod spacers, 1" hubcentric spacers, seat heaters....
    Applied two separate Advance Auto discount coupons, one for 20% and another for 30% (total cost came to $60 @today's prices) at two different stores:woot:, so I got the under leaf fix axle wrap
    fix for the front and the Helwig 550 equivalent for the rear...
    First, if you are not hauling heavy loads, you may find the front underleaf fix enough for the wrap and the bump....
    Instantly got rid of axle wrap, especially nice not to have the "bump" when first releasing brakes after coming to a complete stop, totally kool!!
    The 550 clone I will test in a few days with a huge load of wood..
    Impressions, probably the best $60 I sent on the truck so far, tracks better, actually is smoother feeling, especially on freeway, handles uneven bumps better, the whole rear suspension just feels much tighter and smoother...
    Recommendation, for $60 it is a cheap fix that works with sagging springs....the axle wrap is very disruptive to the driveline as a whole on these trucks, and the CB, rear universal and leafs take the brunt of the abuse, dang truck rides like new, I swear...and smooth from stopped to full speed floored, no driveline shimmy, no axle wrap thump, drives like it is supposed to....
    Update, to OP, I installed with the button in furthest hole, working just fine, will keep an eye on it...
