Goodbye Axle Wrap Mod
Discussion in '1st Gen. Tacomas (1995-2004)' started by iDigTulsa, Aug 14, 2010.
  1. Aug 26, 2015 at 6:19 PM
    #261
    Ritchie
    Ritchie Well-Known Member
    San Diego (North County)
    RC Step side Pre-runner
    2.7 w/auto, 4WU 3 link, F & R Diamonds, ARB's F/R w/ Yukon 5.29's, Inchworm 4.7 Lefty, Deavers, ARB OBA, Schrockworks up front.
    Dell,
    Which brand of traction bar is that?
    I put in a call to Bud-built but they never returned my call.
    With the InchWorm Lefty, I get axle wrap bad and need one of these.
    Thanks.
  2. Aug 26, 2015 at 10:23 PM
    #262
    BlackSportD
    BlackSportD Well-Known Member
    Los Angeles
    Icon/TC Mid travel, TRD S/C, PNP Greddy EMU, 625cc injectors, 2.2 pulley, Hayden tranny cooler, AEM wideband, TRD boost gauge.
    x2, sounds just like what I have.
    I have had a bud built sitting around for some time, finally started putting it on and come to find out it won't fit with the stock exhaust- not by a long shot. Pretty bummed with this, I'm at an age where I actually really appreciate my stock air box and exhaust- I like not hearing my truck. But now looks like I need to mod my exhaust... gotta get rid of this axle wrap.
  3. Aug 26, 2015 at 10:43 PM
    #263
    DukesTaco
    DukesTaco Well-Known Member
    AZ
    2nd Gen Double cab Pre Runner
    It was posted on this tread or on a similar tread like this that all you really need to do is put the u clamp about 4 to 5 inches on the front of the axle and torque it down to 50 foot pounds. I remember reading it a couple months ago.
  4. Aug 26, 2015 at 10:59 PM
    #264
    2004TacomaSR5
    2004TacomaSR5 Nemesis Prime
    Jon
    Montana
    2004 Tacoma DCSB & 1980 Toyota Pickup 4WD
    Tacoma is stock and staying that way, Pickup is TBA as of now.
    Saving this for later, great writeup! I am doing this over the weekend without fail. Axle wrap has been a pebble in my shoe for a year since I bought this truck.
  5. Aug 27, 2015 at 6:52 AM
    #265
    this_is_nascar
    this_is_nascar Well-Known Member
    Gloucester City, NJ
    2007 TRD Off-Road
    By doing this mod, how much are you limiting your rear suspension articulation during off-road wheelin'?
  6. Aug 28, 2015 at 12:56 PM
    #266
    VintageFast
    VintageFast Well-Known Member
    Jim
    DFW, Texas
    02 Prerunner 3.4
    I did this a couple of days ago. It seemed to help but I still have some wrap when coming to a hard stop. Thinking of putting ubolts behind the axle to see if that will fix it completely. Has anyone done this?
  7. Aug 28, 2015 at 1:15 PM
    #267
    DukesTaco
    AZ
    I just did the ubolts on the front of the axle. Some tw members have experimented moving the clamp between 4 and 6 inches from the axle. The worst your leafs are the farther you have to go.
  8. Oct 12, 2015 at 7:55 AM
    #268
    PrerunnerVsix
    PrerunnerVsix Well-Known Member
    Ali
    Houston, Tx
    2013 Tacoma TRD Sport
    I tried this mod but it didn't fix my axle wrap (my leaves are frowning pretty bad). Anyone know a good set of leafs that eliminate axle wrap but don't really add any lift?
  9. Oct 12, 2015 at 9:14 AM
    #269
    amati5
    amati5 Well-Known Member
    2010 Prerunner TRD
    Just did this on the weekend and lubed the slip yoke. Car drives smooth with no sign of clunk but during the installation of the clamps, at about 5 in from the axle, I noticed the plate on the driver's side is less than an inch from form the gas tank. Should that be a concern? I decided to grind the corners of the plates and install the clamps with the plates/nuts facing down instead to make more space from the gas tank. I probably didn't need to but figure it doesn't hurt installing them this way, actually easier to torque down the nuts with much more room from below.
    Also, every time I removed the slip yoke, I always lost some trans fluid. I did this twice. Should I refill with just approximately the same amount?
    thx
  10. Oct 12, 2015 at 9:16 AM
    #270
    PrerunnerVsix
    Ali
    Houston, Tx
    I noticed that also, I took them off instead of worrying about puncturing the gas tank because it didn't get rid of the axle wrap on my truck.
  11. Oct 12, 2015 at 9:21 AM
    #271
    amati5
    2010 Prerunner TRD
    As mentioned here, if your leaves are bad, move the clamps closer to the front, and away from the gas tank.
  12. Oct 12, 2015 at 9:24 AM
    #272
    PrerunnerVsix
    Ali
    Houston, Tx
    If I move it more forward it will hit the gas tank hanger/mount.
  13. Oct 12, 2015 at 9:30 AM
    #273
    amati5
    2010 Prerunner TRD
    Oh, I see you have gen 1 Tacoma.
  14. Oct 12, 2015 at 6:38 PM
    #274
    Logger
    Logger out for a rip are ya bud?
    Sam
    '13 TRD OR Double Cab
    I ordered from these guys a couple weeks ago after many hours of exhausting research. They are made with better quality steel compared to the OEM Toyota ones. You can't beat the price either, super helpful, fast shipping. Nothing but good reviews from folks on Tacoma World too!
    http://www.generalspringkc.com/Leaf_Springs_Toyota_Tacoma_1998_1999_2000_s/1931.htm
  15. Oct 12, 2015 at 6:49 PM
    #275
    PrerunnerVsix
    Ali
    Houston, Tx
    Thank you for the recommendation, did those springs stop axle wrap in your truck?
  16. Oct 13, 2015 at 12:55 PM
    #276
    Logger
    Sam
    Oops sorry should've mentioned I have not installed them yet! Too busy with work lately. Everything I researched pointed to them being a great spring. Maybe search general spring, I know a lot of second gen guys are running them.
  17. Oct 13, 2015 at 2:37 PM
    #277
    bldegle2
    bldegle2 OldPhart
    San Francisco, Ca.
    2009 Prerunner TRD AccessCab
    New Navigation DVD/CD/TV/AV/Bluetooth Stereo and seat mod spacers, 1" hubcentric spacers, seat heaters....
    You will always have axle wrap unless you attach traction bars of some sort....however, getting a better spring will mitigate the massive wrap the weak Tacoma springs have...I added theses two spring 'helper's'.... http://shop.advanceautoparts.com/p/...20-11-102/10053624-P?searchTerm=leafs+helpers and http://shop.advanceautoparts.com/p/...30-11-103/10053619-P?searchTerm=leafs+helpers it really helped with the axle wrap and sag on the cheap, someday I will get springs, but for now I am fine...there is a write up on these two mentioned, in the 1st gen archives....
  18. Jan 4, 2016 at 6:56 PM
    #278
    Bubbles
    Bubbles Liquor and Whores
    Sunnyvale Trailer Park
    hmm. sub'd for future reference.
  19. Mar 4, 2016 at 8:53 PM
    #279
    Prerunner punk
    Prerunner punk Member
    02 auto 3.4 trd
    Deck plate
    Do bolt on spring helpers help with axle wrap? They may be an inexpensive fix!
  20. Mar 8, 2016 at 5:26 PM
    #280
    lspacemonkeyl
    lspacemonkeyl Member
    Florida
    2000 tacoma prerunner
    Led headlights, 01-04 tail light lenses, led lights (all lights including dash), SPC upper A-arms, tundra front brakes, tundra swaybar links, tundra carrier bearing, all rubber bushings/mounts replaced with poly, 16x8 matte black procomp rims, bfg 295/75-16 all terrains, led underhood lights and under bed rail, vdo temp oil volt gauges,
    Works like a charm!
