Goodies
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Huck89, Oct 17, 2022.
  1. Oct 17, 2022 at 8:55 PM
    Huck89
    Huck89 [OP] Well-Known Member
    Phillip
    2019 Toyota Tacoma TRD Off Road 6 Speed Manual
    Over the past few weeks I have been fortunate enough to add some goodies to the Taco and I must say I’m loving the way she’s running. I was tossing up the idea of doing an LS swap (Which I still plan to do but far into the future now). It’s hard to justify pulling out such a reliable engine so “young” (Only 23,000 miles). Goodies include:
    URD Spec - U Exhaust
    URD Power Extractor Pipes
    URD Short Throw Shift
    URD Oil Catch Can
    Injen Intake
    CSF Performance Radiator
    RIPP Coil Packs
    Also, below is a website that has turn key LS crate motors with tranny packages that I plan to look more into when the time comes to pull the trigger on the swap. Link sends you directly to trans & engine package section.
    LS Trans & Engine Packages
    LS Engine and Transmission Connect & Cruise Packages.
    [​IMG] paceperformance.com
  2. Oct 17, 2022 at 9:18 PM
    MGMDesertTaco
    Several companies sell LS crate motors and trans packages. You could even have a performance shop build you an LSX for cheaper. I'm not aware of any company that makes motor mounts for 3rd gens though. You'll need to upgrade the fuel and cooling system too. I saw this a while back...
    https://www.youtube.com/watch?v=SsyR2BynqFM
    Finn-2187 likes this.
  3. Oct 17, 2022 at 9:32 PM
    kona61
    kona61 Well-Known Member
    J
    LR 2022 Tacoma TRD OR
    RCI Skids
    I would highly recommend you swap back to OEM coil packs. The aftermarket ones don’t do anything and have very questionable reliability most of the time.
  4. Oct 17, 2022 at 9:49 PM
    530Taco
    530Taco Gone fishin'
    Adam
    Old Hangtown, CA
    '21 DCSB OR MT Cement
    That truck is actually a 2nd gen with a 3rd gen front clip, not that it makes much difference, I don't believe anyone makes a 2nd gen LS swap either...
    MGMDesertTaco[QUOTED] likes this.
