Goodyear Adventure
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BCBUD, Jul 20, 2014.
  1. Jul 20, 2014 at 4:41 PM
    BCBUD
    BCBUD [OP] Member
    BC
    13 Tacoma TRD Sport
    I have a 2013 TRD sport that doesn't haul or tow. The Goodyear dealer said to go this tire in an E rating because of stronger side walls and more tread. We off road about 15% mostly rough forestry roads so the stronger tire is attractive.
    Is 10 ply over kill and will it noticeably affect the ride? If anyone has tried this what tire pressure do you run?
    And yes I used search.
  2. Jul 20, 2014 at 4:47 PM
    ckeene9
    ckeene9 Well-Known Member
    Chesterfield, VA
    '12 DCSB Supercharged 4x4 TRD Sport
    See Build Thread
    E's are definitely going to ride harder but with that being said, they do have a stronger sidewall.
    As far as tire pressures go, you need to do a chalk test since everyone's rigs weigh differently.
  3. Jul 20, 2014 at 4:53 PM
    bambooshoots
    bambooshoots Be a fountain, not a drain.
    Kevin
    College Station, TX
    2015 Honda Accord Sport
    I did it again. Got tired of paying truck payments and gas and traded in for a 2015 Honda Accord Sport since I enjoyed my 2013 Sport so much.
    I've got these tires and yes the ride does become harsher. Also as heavy as they are the fuel economy will go down.
  4. Jul 20, 2014 at 5:29 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    if you dont tow at max rating or off road hard, stick with P rated / load range c tires. Your mpg and overall ride will be MUCH better.
  5. Jul 20, 2014 at 6:29 PM
    BCBUD
    BCBUD [OP] Member
    BC
    13 Tacoma TRD Sport
    Thanx for confirming what I suspected, guess i'm more of a P than an E.
  6. Jul 21, 2014 at 3:06 PM
    BCBUD
    BCBUD [OP] Member
    BC
    13 Tacoma TRD Sport
    Off to install the Adventures tomorrow, fingers crossed they arrive with the mountain/flake.
  7. Jul 21, 2014 at 3:47 PM
    schwarthog
    schwarthog Well-Known Member
    Ian
    Tacoma, WA
    2014 DCSB 4x4 TRD Offroad MGM
    Ultragauge, Weathertechs, Plasti-dip rims/grille surround, Access Tonneau
    I'm not sure but I thought only the LT tires for the Adventure ATs came with the ms.
  8. Jul 21, 2014 at 5:02 PM
    nd4spdbh
    SoCal
    thats what i thought.... might want to double check that you got the right tire.
  9. Jul 21, 2014 at 5:05 PM
    schwarthog
    Ian
    Tacoma, WA
    The P's probably better anyway, I doubt you're giving up that much winter performance by using it instead of the LT, it should be the same tire after all.
  10. Jul 21, 2014 at 6:37 PM
    Wheelspinner
    Wheelspinner Coco Customs
    Northern NJ
    '13 4x4x4cyl
    The ms rates tires are a different rubber that stays flexible in colder weather to help with traction. Other than that yes there the same tire.
  11. Jul 21, 2014 at 6:45 PM
    BCBUD
    BCBUD [OP] Member
    BC
    13 Tacoma TRD Sport
    I live in British Columbia where the mountain/flake or carrying chains is mandatory for six months so this is the first thing I will check, the dealers ordering book shows the P tire with the flake so wish me luck. We get lots of snow and mild temperatures, therefore not as easy as cold dry snow to drive on.
  12. Jul 21, 2014 at 8:08 PM
    MagneticTaco79
    MagneticTaco79 COLD ASS HONKY
    AARON
    WV
    Mag Grey 2012 Tacoma AC TRD Sport 4x4
    ALL KINDS OF SHIT
    10 ply is over kill for these trucks. It will ride rougher and it will affect your mileage a bit because of the added weight. That being said, they are use full if you wheel a lot due to the added plys making the tire much more durable. Also a lot of the most popular "mud"/ rougher tread tires in the most popular sizes unfortunately are only available in 10 ply. It's all in what you need or want. Sounds like you don't need a 10 ply, if your just running rough forestry roads than a 6 ply is all you really need.
  13. Jul 24, 2014 at 7:23 PM
    BCBUD
    BCBUD [OP] Member
    BC
    13 Tacoma TRD Sport
    Epic fail, tires arrived but no mountain/snowflake on regular Adventure tires. I have no second choice so I'll make due until someone starts manufacturing what I need or just buy chains to stay legal.
  14. Jul 24, 2014 at 7:36 PM
    schwarthog
    Ian
    Tacoma, WA
    Ehh, Idk that it's epic fail. I reckon they'll still do pretty well come winter.
  15. Jul 25, 2014 at 7:01 PM
    BCBUD
    BCBUD [OP] Member
    BC
    13 Tacoma TRD Sport
    It's my thread and I am going to beat it to death. Dealer called back and offered Nokian Rotiva AT with the flake and $80 each for my half worn out cupped tires. I now have Finnish/Russian tires on my US/Japanese truck in Canada, ain't it great. We do much more off roading in the winter so I hope I have chosen well.
    The Russian part doesn't sit well with me either since i am old enough to remember the Cold War all too well, so if you want to hate me, make sure you know where your vodka is produced.
  16. Jul 25, 2014 at 7:13 PM
    schwarthog
    Ian
    Tacoma, WA
    Hmm. I'll have to look at those. My hunting rifle has parts from Finland and Russia, so I guess tires wouldn't be that big a stretch :)
    Did he say what the weight was on those? I assume they're P rated.
  17. Jul 25, 2014 at 7:52 PM
    BCBUD
    BCBUD [OP] Member
    BC
    13 Tacoma TRD Sport
    Yes to P rated and found a tire weight on line of 37 pounds.
  18. Jul 25, 2014 at 8:25 PM
    schwarthog
    Ian
    Tacoma, WA
    Wow! That's even better than the Rugged Trails. Let us know how they ride, I'm very interested.
  19. Jul 27, 2014 at 2:58 PM
    BCBUD
    BCBUD [OP] Member
    BC
    13 Tacoma TRD Sport
    Just did 350 kms with 30# air pressure. Slightly stiffer than expected but completely acceptable, very quiet and in rough parts of highway tracked perfectly and didn't follow grooves in road. So far, completely satisfied. Didn't track mileage because it's always lousy. Unless anything untoward happens next report will be about snow performance in late fall.
  20. Feb 4, 2016 at 9:37 AM
    2big4arunner
    2big4arunner Well-Known Member
    Tyler
    Vernon BC
    2015 tacoma dclb
    3/2 leveling kit, 275/60r20 duratracs on xd128 20x9 rims, AFE stage 2 intake, trd exhaust, duel electric fan w/dakota digital controller
    I know this is an older thread but thought I would ask how you liked the tires over the winter and how they faired whatever part of bc your in. Still stock size?
