Goodyear Duratrac 265/70/17 + XD Revolvers fit 2010 Stock TRD Tacoma?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by VeNoMiZeD, Mar 1, 2010.
  1. Mar 1, 2010 at 3:21 PM
    VeNoMiZeD
    VeNoMiZeD [OP] Well-Known Member
    Will Goodyear Duratrac 265/70/17 + 17x9 XD Revolvers fit 2010 Stock TRD Tacoma? I was all set to get my stock Tacoma rims powdercoated and the set wheels that I was going to borrow in the meantime didn't fit. So that ruined my whole plan and I'm giving up because it's just becoming a hassle. So I think I'm going to settle with the 17x9 XD revolvers. I don't have my 5100s yet but will when DSM gets some more in. So with the Duratracs and Revolvers on my Stock setup will there be any rubbing issues or anything I should worry about. I was reading another thread regarding the revolvers of some offset issue. I don't know if that person was getting bigger tires than I am or not. Anyhow 4 wheel parts said they will fit, but I wanted to ask here for confirmation. The other thread also mentioned spacers? Is that needed here with my application? Thanks!
  2. Mar 1, 2010 at 4:33 PM
    SpaceMonkey
    SpaceMonkey Well-Known Member
    Houston, Tx
    06 PreRunner
    It depends on the backspacing of the wheel. 4.5 and should be good. you may have to temporarily remove the front flaps until you get the bilsteins in.
  3. Mar 1, 2010 at 4:37 PM
    Dellosa89
    Dellosa89 Love peace and Taco Grease
    Brian
    Murrieta CA
    07 Prerunner TRD Off Road
    Fox 2.5 Coilovers, Camburg 1.25" UCA's, Icon RR, Icon aal,EVS foam bump stops, Borla Catback, HID Headlights and fogs, Defiant light bar, 3 hella 700 hid, Satellite Radio, Sony hu with 10'' sub, custom jetski rack, TRD seat covers, secondary air filter removed.
    265/70s will fit with stock height with no rubbing.
  4. Mar 1, 2010 at 4:50 PM
    Simon2150
    Simon2150 Well-Known Member
    Austin, TX
    06 Tacoma DoubleCab V6 SR5
    Get 4.5 bs and u should be fine. Check my setup out in my gallery. I got revolvers 17x9 with 285/70/17 and 2.5" lift
  5. Mar 1, 2010 at 5:25 PM
    VeNoMiZeD
    Well I just completed the transaction with 4 wheels part. He didn't mention backspacing. But I placed the order with the duratrac tires in 265/70/17 and XD revolvers and mention my 2010 Tacoma TRD stock. So I'm assuming the person knew the correct specs. Can't wait to get them!
  6. Mar 1, 2010 at 5:43 PM
    SpaceMonkey
    Houston, Tx
    06 PreRunner
    Ummm...never assume! Ask them for the backspacing to make sure and then when you get the wheels, test fit on your truck and then get the tires mounted.
  7. Mar 1, 2010 at 5:50 PM
    VeNoMiZeD
    They're doing all that, it's being shipped to my local 4 wheels part and they're doing the mount and balancing and install. So if it's wrong it's all on them.
  8. Jun 30, 2010 at 8:28 PM
    Tech
    Tech New Member
    How did this work out, venomized? Any rubbing problems? I've been wanting to get the 17" revolvers in bronze but don't want to have to lift my truck.
  9. Jun 30, 2010 at 8:33 PM
    Oskie_78
    Oskie_78 Everything's BIGGER in TX!
    Oscar
    Corpus Christi, TX
    2010 DC TRD Sport 4x4
    Nice set up man! That's the best wheel and tire set up I've every seen! ;)
