Goodyear UltraTerrain AT
Discussion in 'Wheels & Tires' started by bwawuz02, Aug 11, 2018.
  1. Aug 31, 2020 at 6:09 PM
    #521
    CrustyComa
    CrustyComa Well-Known Member
    Michigan
    2020 SR SX TRD Sport love child
    You guys running the 265/75-16 SL load with the automatic tranny, did you notice any power loss or big MPG hit?
  2. Aug 31, 2020 at 6:16 PM
    #522
    LstMinutePanic
    LstMinutePanic Well-Known Member
    Colorado
    2018 Black Tacoma OR DCLB AT
    Not really. I went from stock to 265/75/16 C-load Duratracs and hardly noticed a change. The Ultraterrains are a little lighter and have less aggressive tread, so i get a little better MPGs than I did with the Duratracs. If you're being super picky though, maybe .5 MPG loss compared to stock. Although, I have OVTune as well, which helps a bit with bigger tire sizes.
  3. Aug 31, 2020 at 6:33 PM
    #523
    CrustyComa
    Michigan
    Thanks bud!
  4. Aug 31, 2020 at 10:16 PM
    #524
    XSplicer62
    XSplicer62 Well-Known Member
    Jefferson State
    2005 Tacoma DC TRD OffRoad
    I went from 265/70-16P-metric (stock size & load range) Michelin LTX AT2 to 265/75-16 SL UltraTerrains. No discernible change in power or fuel mileage. Ride was improved slightly with the UTs; the only negative was a downgrade in handling. Steering response was noticeably better with the LTXs, and turning into corners was crisper. You do get used to it but I can still feel the difference. That said, the Michelins are excellent but if I had it to do over again, I would still choose the UTs. They are that good -- and amazingly capable in snow.
    Greg.Brakes.Tacos likes this.
  5. Sep 26, 2020 at 10:00 AM
    #525
    Watacoma
    Watacoma Well-Known Member
    luther
    2019 Cement TRD Offroad
    Does anyone know if running this tire in a 265/75/16 would rub using 16" scs f5's at the 4.5 backspace "0 offset" size?
    OldDjang and aust like this.
  6. Sep 27, 2020 at 12:01 AM
    #526
    aust
    aust Well-Known Member
    Any pictures of your set up?
  7. Sep 27, 2020 at 3:35 AM
    #527
    nparent2147
    nparent2147 Well-Known Member
    Noah
    2016 Tacoma SR5 DCSB
    MLO Sliders TRD Pro Grill
  8. Sep 27, 2020 at 8:41 AM
    #528
    aust
    Thanks, you helped me make my decision. We have the same exact truck.. I like my ST Maxx but they're a little overkill for my needs.
  9. Sep 30, 2020 at 8:01 PM
    #529
    Wolfjesus
    Wolfjesus Member
    Colorado
    2001 Tacoma TRD
    OME 881's with nitro charger shocks and full Dakar leaf pack
    I went way down the rabbit hole on tire choices for my 2001 taco. Waffling hard b/n Wildpeaks, Open Country AT3's, and Duratracs.
    Was running BFG KO2's, which are load range E. Pretty harsh ride and probably way too much tire for that little truck. I loved the KO2's otherwise. Handled great in the snow, on highway, and off road and was never concerned about puncture. But I wanted to go with a lower load rating for ride quality, as this truck is also my DD. Also, the BFG's were scalloped on the shoulders. (The DT guy said this was due to not rotating enough. The tire guy at my mechanic said this happens running an E load tire on a light truck like the 1st gens...not sure I understand the physics behind this train of thought).
    I settled on Duratrac C load, and much to my dismay, they did not fit without trimming and messing with a pinch weld. I was running 265/75/16 on stock rims with a 2" OME lift. I was getting rubbing on my frame rails with the KO2's, so decided to get new wheels with more negative offset to deal with it. Well, I got a set of American Racing Bajas for pretty cheap on CL; 16X8 with 0 offset (compared to +15 on stock wheels). They where fine with the kevlars (265/70/16) on them, but the 265 75 Duratracs wouldn't work with out messing with the plastic and likely the pinch weld.
    The DT guy said he had the UT's in stock in a 265/70/16. Mounted one up and they fit. I wasn't stoked on going back to 70's, but I decided to give them a shot. I had only looked into them a little bit and they were not really in my final list (WP's and DT's). After reading this thread (damn near all of it), I am feeling pretty good about what I ended up with. They look pretty sweet and I am psyched to try them out. Heading out elk hunting next weekend. About 18 miles of somewhat rough NF roads. Drove the same route two weeks ago with the KO2's and stock wheels, so should be able to have a good comparison.
  10. Sep 30, 2020 at 8:29 PM
    #530
    XSplicer62
    Jefferson State
    Good writeup Wolf, welcome aboard. Looking forward to your update, with pics of your rig, your tires, and your elk!
  11. Oct 4, 2020 at 6:08 AM
    #531
    mmblue4x
    mmblue4x Well-Known Member
    '19 TRDOR
    265/75/16 SL. DTD through eBay, shipped to local Firestone. No rubbing. Handling a bit muted when compared with the OEM goodyears. A little bit of noise, as can be expected. Yes, they pick up rocks. Added 5100s to the front at 1.1" last week. Got just under and inch of lift after things settled. Toe was a bit off, but caster/camber wasn't out of spec (after the shocks).
    update 10/19/20: I lost MPG. Lose more the faster I go. Better MPG on backroads at 50 mph than highway at 70 mph.
  12. Oct 5, 2020 at 8:23 AM
    #532
    Hattr1ck
    Hattr1ck Well-Known Member
    Josh
    2017 DCSB TRDOR 4x4
    None yet
    I have a complete setup available with methods and 265/75/16 if anyone’s interested. Located in East Texas (Tyler).
    Maticuno and WVTacoma08 like this.
  13. Oct 5, 2020 at 9:02 AM
    #533
    WVTacoma08
    WVTacoma08 Well-Known Member
    West Virginia
    '20 TRD PRO Super White
    How many miles did you have on them? How much is left?
  14. Oct 5, 2020 at 10:38 AM
    #534
    Hattr1ck
    Josh
    2017 DCSB TRDOR 4x4
    None yet
    One is at 12 others at 13/32nds. New is 14. Had over 15k on them if I recall. Have to dig up the receipt to check. So to answer you’re second question, Tons of miles left!!
    WVTacoma08[QUOTED] likes this.
  15. Oct 5, 2020 at 3:34 PM
    #535
    skee
    skee Well-Known Member
    North Coast, CA
    2006 Tacoma TRD 4x4 Access Cab
    4DB32A5A-64FA-41E0-8909-EB37C6D0DC78.jpg 9E8C125B-B8A3-4B26-9FE9-9FBB3662E97C.jpg D5BAE084-7570-4BD5-8286-54CF942C4156.jpg 4B8F7365-B996-41EF-89A5-9CF7728A448F.jpg
    265/75r16 SL Ultraterrains on 16x7 Road Ready steel wheels (“sparies”)
  16. Oct 7, 2020 at 9:40 AM
    #536
    skee
    North Coast, CA
  17. Oct 8, 2020 at 3:25 PM
    #537
    txgibson1
    txgibson1 New Member
    2020 Silver Tacoma TRD OR
    Goodyear UT 265/75r16 on RRW RR5s 16x8 -12
  18. Oct 14, 2020 at 9:27 AM
    #538
    LstMinutePanic
    Colorado
  19. Oct 14, 2020 at 2:20 PM
    #539
    Discount Tire
    Discount Tire Tire & Wheel Specialists Vendor
    Arizona, USA
    Yes indeed! Great opportunity to save some money, but it ends this evening. If anyone has any questions or is looking to get a set, feel free to reach out, we will make sure you are taken care of.
    Thank you for the tag @LstMinutePanic
  20. Oct 20, 2020 at 5:50 AM
    #540
    Krogers128
    Krogers128 Well-Known Member
    Kyle
    WA
    1995.5 Paradise Blue Tacoma SR5 V6
    OME complete kit. 881 coils. Dakar Leafs. JBA UCA. 265/75-16 Goodyear Ultraterrain.
    Just missed out on this deal :( Maybe there will be a rebate when I go in to pay. I ordered a set for the truck a few days ago to get put on this week, in 265/75-16. Looking forward to it.
