Goofy tire wear
Discussion in '2nd Gen. Tacomas (2005-2015)' started by JeffBoyardee, Mar 22, 2020.
  1. Mar 22, 2020 at 2:49 PM
    Larzzzz
    Larzzzz Grande' Ricardo
    Larry
    MA
    '06 dclb 350+ kmiles
    Aux back up lights, Bed lights, Re-located trailer plug, Good dooby, a.k.a. jumper cable mod, Heated seats, back up camera,
    In my experience, tire cupping had always been shocks. Still though, check everything.
  2. Mar 22, 2020 at 4:44 PM
    JeffBoyardee
    JeffBoyardee [OP] Well-Known Member
    Jeff
    Seminole, FL
    2011 TRD Off-Road Tacoma DCSB
    I did the chalk test, and didn't see good results, so I was basing 30 psi on results from a bunch of other guys with the same tires, who said the chalk test showed 27-30 to be the best results. They also rode much better at 30 than 38. I'll try 40 for awhile though, and see how they wear.
    I've rotated then at every oil change, so 6-7000 miles.
    What could cause the shocks to be bad so soon? According to the bounce test, they seen fine. Could something else be wrong with them?
  3. Mar 22, 2020 at 4:46 PM
    JeffBoyardee
    Jeff
    Seminole, FL
    I'd say probably 10-15,000 miles on it now. Just under a year of normal driving.
  4. Mar 22, 2020 at 4:50 PM
    Novatoy1
    Novatoy1 Well-Known Member
    Jeff
    Pittsburgh
    2017 Tacoma CCOR
    Yep tire cupping. Those tires are toast!
  5. Mar 22, 2020 at 5:15 PM
    JeffBoyardee
    Jeff
    Seminole, FL
    After some reading, it looks like some of those guys running 25-30psi were on load range D tires, of the same model. Doh! I didn't know they made them in both load ranges. Guess I'll pump then up to 40, check everything else, and get whatever life I can out of them. The cupping doesn't seem to have affected the ride in any way at all.
    RyanL likes this.
  6. Mar 22, 2020 at 5:16 PM
    13txtaco
    13txtaco Well-Known Member
    Katy Texas
    2013 Tacoma 4x4
    That is called feathering my friend
  7. Mar 22, 2020 at 5:49 PM
    No Shoes Nation
    No Shoes Nation Well-Known Member
    2008 Taco SR5 Access Cab 4.0 4x4
    Hmm . . . none as yet, that's why i'm here . . .
    Tires with that kind of tread must be rotated at about every 4000 miles. There's ya problem
  8. Mar 22, 2020 at 6:10 PM
    JeffBoyardee
    Jeff
    Seminole, FL
    Well, now I know ¯\_(ツ)_/¯
  9. Mar 22, 2020 at 6:18 PM
    FFBlack
    FFBlack Well-Known Member
    2019 TRD OFF ROAD
    In the business we call that chopped up tires. Many factors cause this, proper inflation, worn suspension components, how fast are you taking those high way off and on ramps, tire brand etc.
  10. Mar 23, 2020 at 7:20 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    pretty typical and no real way around it on a tire with all different beefy lug sizes. Happened to every more aggressive tire i have owned to some extent. Some worse than others. All rotated at regular 5k mile intervals.
  11. Mar 23, 2020 at 7:35 AM
    JeffBoyardee
    Jeff
    Seminole, FL
    Thanks. I'll rotate them more often, and keep them more inflated. My big concern was something bad in the suspension, which, to the best of my ability, I can't find anything.
