google proof trivia
Discussion in 'Off-Topic Discussion' started by aaronatl, Oct 17, 2009.
  1. Oct 17, 2009 at 2:01 PM
    aaronatl
    aaronatl [OP] ©1975
    Aaron Nrsa
    In A Big Country
    it hauls tostitos
    It is a liquid at room temp.
    It has the ability to hold other liquids.
    It is 98.9 % transparent
    It is very brittle at low temp.
  2. Oct 17, 2009 at 2:05 PM
    DanGer
    DanGer Avatar approved by 98tacomav6
    Northern Virginia & Blacksburg
    07 Base 4Cyl 4x4 Manual
    White Head Light mod, White shorty antennae, Doug Thorley Long Tube headers, AFE Drop in air filter, Secondary Air Filter Removed,
    water?
  3. Oct 17, 2009 at 2:09 PM
    aaronatl
    aaronatl [OP] ©1975
    Aaron Nrsa
    In A Big Country
    it hauls tostitos
    wrong, try again
  4. Oct 17, 2009 at 2:16 PM
    wildjerseyfirefighter
    wildjerseyfirefighter I sell fishing and fishing accessories
    Joe
    NJ
    05 Tacoma TRD Sport
    stock, for now
  5. Oct 17, 2009 at 2:17 PM
    AK27
    AK27 Well-Known Member
    glass!
  6. Oct 17, 2009 at 2:18 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    WTF kinda glass to you Canadians have? Liquid at room temp??? :eek:
  7. Oct 17, 2009 at 2:18 PM
    AK27
    search it chris :)
  8. Oct 17, 2009 at 2:20 PM
    AK27
    when glass is solid it becomes opaque.
    if you can find a piece of glass window from an old house, measure the top of the window glass and the bottom for thickness. over time glass will slowly droop down :)
  9. Oct 17, 2009 at 2:22 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I cant find it...Its....GOOGLE proof....:confused:
  10. Oct 17, 2009 at 2:22 PM
    aaronatl
    aaronatl [OP] ©1975
    Aaron Nrsa
    In A Big Country
    it hauls tostitos
    ak, that was quick
  11. Oct 17, 2009 at 2:23 PM
    AK27
    i remember that from school :eek: :)
  12. Oct 17, 2009 at 2:24 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    WOW! Thanks, Brandan...I had no idea. I was thinking you were nuts. :eek:
  13. Oct 17, 2009 at 2:25 PM
    AK27
    :laugh: no worries i am nuts but i remember this one fact :D
  14. Oct 17, 2009 at 2:41 PM
    WATRD
    WATRD Keyser Soze
    Rob
    Duvall, WA
    '01 S/C SAS TRD
    WATRD.com
    http://math.ucr.edu/home/baez/physics/General/Glass/glass.html
    http://dwb.unl.edu/Teacher/NSF/C01/C01Links/www.ualberta.ca/~bderksen/florin.html
    http://expertvoices.nsdl.org/sciencegeekgirl/2009/03/17/is-glass-liquid-no-but-it-is-complicated/
    -more-
    http://www.wisegeek.com/is-glass-a-liquid-or-a-solid.htm
    http://www.sciencedaily.com/releases/2007/08/070809130014.htm
    ...and the perennial debate rages on... ;)
  15. Oct 17, 2009 at 2:58 PM
    aaronatl
    aaronatl [OP] ©1975
    Aaron Nrsa
    In A Big Country
    it hauls tostitos
    glass is defined as an inorganic product of fusion which has been cooled through its glass transition to the solid state without crystallising
  16. Oct 17, 2009 at 2:59 PM
    AK27
    way to rain on my parade!
    :laugh:
  17. Oct 17, 2009 at 3:16 PM
    DIVER_5
    DIVER_5 DIVER_5
    LAWRENCE
    VALDEZ ALASKA
    SILVER WITH A TON OF MONEY IN AND ON IT.
    6" PRO COMP LIFT, PRO COMP SKID PLATE, FABTECH PRERUNNER BAR, 9" PROCOMP LIGHTS, 6000K hid HEADLAMPS WITH BLACK LENS'S, 19" ROCKSTAR WHEELS, 33" GOODYEAR MTR TIRES, DOLBY DIGITAL SURROUND SOUND PIONEER SYSTEM WITH DVD, NAV, BLUE TOOTH & BACK UP CAMERA, 10" CUSTOM SUB BOX BEHIND REAR SEAT, ROCK SLIDER BARS WELDED ON, WITH LINE-X TO MATCH THE LINE-X PRERUNNER BAR
    I would think that the correct answer is "ICE" ?
    It is a liquid at rm temp
    It does have the ability to hold other liquids
    Not sure on the 98.8% thing but it is sometimes quite transparent.
    And it is very brittle at low temps?
    :headbang:
  18. Oct 17, 2009 at 3:24 PM
    WATRD
    WATRD Keyser Soze
    Rob
    Duvall, WA
    '01 S/C SAS TRD
    WATRD.com
    ...and to be clear, the "Observer Effect" is in operation here as well... Just by posting this thread announcing this trivia as "Google Proof", you have rendered it not so.
    So long "Google Proof" :(
  19. Oct 17, 2009 at 4:16 PM
    AK27
    this is a liquid at room temp
    it expands and contracts readily
    used as a conductor
    used in medicine but is also toxic
    :D
  20. Oct 17, 2009 at 4:44 PM
    aaronatl
    aaronatl [OP] ©1975
    Aaron Nrsa
    In A Big Country
    it hauls tostitos
    mercury
