GoPro Mount
Discussion in '3rd Gen. Tacomas (2016-2023)' started by mrsr71, Jun 23, 2020.
  1. Feb 11, 2021 at 7:17 AM
    Waynotogo
    Waynotogo Member
    Wayne
    Cabot, Arkansas
    White ‘18 TRD Off Road
    I have the Hero9 GoPro. It has a setting for Superwide, Wide, Normal and Horizon Leveling. Depending on your model of camera, try changing this setting and see if it helps.
  2. Feb 12, 2021 at 8:40 PM
    Tacosha
    Tacosha Well-Known Member
    Andy
    Calgary, AB, Canada
    2019 Black Tacoma TRD OR ACLB 6MT
    minor, TRD skid plate, front recovery points, Regken mud flaps, rear diff breather, AC drain pipe extended. Upgraded sound with active sub woofer, tonneau cover, CB radio.
    I have it on my 2019 TRD OR
  3. Feb 12, 2021 at 10:27 PM
    CoMo Taco
    CoMo Taco Well-Known Member
    Judah
    Columbia, Missouri
    2018 Toyota Tacoma SR Access Cab 4x4
    Alpine stereo replacement, 6x9 Kicker front door speaker upgrade, Kicker tweeter upgrade. 6000k HID upgrade, Running boards installed, Rear seats installed, Pedal Commander, Meso Map Lights, TRD pro grille, Raptor lights, TRD Pro rims, 4600's Bilsteins, Diode Dynamics SAE Yellow Fog lights, Custom fuse box.
    What dash cam do you use?
    OFudge likes this.
  4. Feb 12, 2021 at 11:28 PM
    mrtonyd
    mrtonyd Well-Known Member
    Tony
    Colorado
    2019 TRD OR DCSB cement
    My 2019 off road doesnt have it. Got it a month or so before the 2020s came out. The guy at safelite said the 2017s have it if I remember right. The windshield safelite replaced my factory one doesn't have it either
  5. Feb 13, 2021 at 12:04 AM
    Mister Grey
    Mister Grey The Viking of disapproval looks in your direction
    Hayward Ca
    2017 Tacoma DCLB Sport 4x4
    The Works.
    2017. Use gopro everyday.
  6. Feb 13, 2021 at 12:20 AM
    savin yours
    savin yours Well-Known Member
    Bryan
    SE Tx
    2018 TRD Off Road
    Rexing V1
    OFudge likes this.
  7. Feb 13, 2021 at 4:37 AM
    Barrister
    Barrister Well-Known Member
    Dennis
    Mesa, Arizona
    2023 TRD Pro, Solar Octane, 6 speed Manual
    Predator Steps, OEM Tonneau
    Here in Arizona windshields are replaced often. When the time comes I may replace my 2021 windshield with a 2018, which has the GoPro mount as well as the other electronics (TSS) of the 2021.
  8. Feb 13, 2021 at 4:43 AM
    pltommyo
    pltommyo Well-Known Member
    Tom
    2016 Gray Tacoma TRD Offroad
    SSO hybrid bumper, Warn winch, RCI skid trilogy, RRW sliders, everything in the cheap/free mods thread, and of course the frame recall work.
    Hitting the trails today and GoPro is already mounted and ready to go. Makes some good video mounted at that point. Doesn't obstruct passengers even.
  9. Feb 13, 2021 at 5:49 AM
    MikeyMcFly
    MikeyMcFly This is heavy, Doc.
    I'm a Masshole
    2016 TRD Off-Road 6MT / 2021 WRX STI
    Building a Broja
    [​IMG]IMG_4531 by Mike M, on Flickr
    Not a GoPro (though I've mounted mine there once before) but my dashcam works perfect there. I just cut one of the GoPro mounts I had in my bag of parts and glued it to the camera mount. I've found the video to be quite decent in terms of view.
    Foster Imposter likes this.
  10. Feb 13, 2021 at 7:17 AM
    eggs
    eggs Well-Known Member
    Beersconsin
    2017 TRD O/R
    When I called Safelite for windshield replacement, they asked whether I had the GoPro mount or not. Same price with or without.
    gsubioguy likes this.
  11. Feb 13, 2021 at 9:15 AM
    '16goingon'17
    '16goingon'17 Well-Known Member
    Trailslayer
    NoVA by way of NWA
    2017 TRDOR 4x4 DCSB MT
    JBA STD UCAs. 6112/5160 @6/5. Wheelers 1.5" 3AAL with Superbumps. BROG molle headrest covers. GMRS & Ham radios with roof-mounted NMO Laird Phantom antenna. Thinkware front/rear dashcams, FreshMexicanTaco's DMM, Meso's dome/map LEDs & Flipfob, Swingcase on driver side. Accumulator Delete Mod (ADM). Two-wheel drive Low Range Mod (2LM). Overland Tailor Tune (OTT) 7.0. Extra juicy oil spill on the bed mat.
    wait what’s the other cool stuff hanging there?
  12. Feb 13, 2021 at 9:32 AM
    MikeyMcFly
    I'm a Masshole
    Building a Broja
    Let's see...
    • Rear view mirror. This is a shiny object that lets you see what's going on behind you, sometimes useful while reversing. Although, per Raul Julia in epic film The Gumball Rally what is behind you doesn't matter, so I'm violating some rule there.
    • A ScanGauge II on a BlendMount. I recently had it updated so I can monitor engine oil temperature and front differential temperature in addition to the standard options of voltage and coolant temperature
    • The other block is the motion sensor for my dash camera. I used an Aukey OBDII power port to power my camera. That black box is a motion sensor which detects motion and then turns the camera on for a set period of time. It would be useful in a parking lot or to see if anyone's snooping around your vehicles at night. I had to run an OBDII splitter to run it with the ScanGauge II.
    Nothing too exciting, but a lot of useful data in a small area.
  13. Feb 13, 2021 at 5:49 PM
    Waynotogo
    Waynotogo Member
    Wayne
    Cabot, Arkansas
    No need to buy a new windshield. The flat (female) adhesive mount can be bought from Best Buy (or similar), the internet for less than $20. Park truck in the sun, clean window with alcohol, slap it on and wait 24 hours.
  14. Feb 13, 2021 at 6:07 PM
    Poke Tako
    Poke Tako Mall CRAWLer.
    2017 TRD Offroad 4x4
    Up country Maui, correct? Maui No Ka Oi!
    9th[QUOTED] likes this.
  15. Feb 13, 2021 at 7:50 PM
    #35
    9th
    9th Not a Civil Engineer
    Smitty
    Tropic of Cancer
    2017 Unicorn Silver Sky
    lubricated fuel door hinge
    Dat eez it!
  16. Feb 13, 2021 at 8:11 PM
    #36
    playdixie
    playdixie Miss'ippi fella
    Mississippi
    2019 Cavalry Blue TRD Sport 4WD
    @mrsr71
    This is a video I took the other morning. As a preamble: windows on my truck are illegal as sh*t as far as tint goes and there is a dark stripe across the front windshield. So it's gonna look really dark in the beginning, but you can at least see what a GoPro records.
    https://www.youtube.com/watch?v=P3PeTjoueEc
    Surfcowboy likes this.
  17. Feb 14, 2021 at 3:56 PM
    #37
    BT17
    BT17 Well-Known Member
    B
    17 Tacoma TRDORDCSB 4x4 AT KDmax SLT/Reg
    a few...
    Same for my dash cam.
  18. Feb 14, 2021 at 4:32 PM
    #38
    NikonBiologist
    NikonBiologist Well-Known Member
    Boise
    2019 Silver Tacoma TRD OR 4x4 DCSB
    My 2019 did not come with the mount. But when a rock destroyed my windshield and I got it replaced, I got the GoPro mount. No difference in cost. Haven’t used it yet but will soon.
  19. Feb 15, 2021 at 1:15 PM
    #39
    CoMo Taco
    Judah
    Columbia, Missouri
    do you have any pictures of it on?
  20. May 4, 2021 at 5:26 PM
    #40
    Frogger10231985
    Frogger10231985 Member
    Rob
    Washington, Pennsylvania
    2017 Toyota Tacoma SR5
    My 2017 SR5 has it and i wish i could remove it cause i don't even own a gopro and don't plan on it...
