GoPro vid Off-roading [DubStep Warning]
Discussion in 'Off-Roading & Trails' started by CaptMorgan, Feb 27, 2011.
  1. Feb 27, 2011 at 9:21 AM
    CaptMorgan
    CaptMorgan [OP] Well-Known Member
    Tempe
    Lift, tires, aux-in, LED Taillights, Flowmaster
  2. Feb 27, 2011 at 10:12 AM
    elblako91
    elblako91 Well-Known Member
    Blake
    Lubbock/Houston/Katy
    1992 Toyo Pickup
    lol i swear dubstep is taking over. awsome vid!
  3. Feb 27, 2011 at 10:20 AM
    NoMallCrawlTaco
    NoMallCrawlTaco © "HELL FUCK YEAH!" © COPYRIGHT FOR MY PROTECTION!
    Arizona
    4" Camburgs Icon AAL 3 Pac BLHM Tacoshi Grill More to come...
    I bet it's nice up there today with all the SNOW!
    Nice vid. Cam works awesome...
  4. Feb 27, 2011 at 10:24 AM
    CaptMorgan
    Tempe
    Love the camera, best investment ever :)
    Dubstep is taking over, Swear we will be hearing it on the radio soon
  5. Feb 27, 2011 at 10:37 AM
    Special_K
    Special_K o_o
    Eddie
    Alameda, CA
    2014 Subaru STI hatchback
    Tuned by Snail Performance, 305WHP/350TQ on E85, Corsa Pro Series black tip CBE, Perrin CAI, Perrin ELH, Invidia catless DP, ID1000 injectors, Turbosmart Dual Port BOV, Turbosmart IWG Actuator, Cobb FPR, Perrin motor and tranny mounts, Moroso dual catch cans, Cobb AP V3, Grimmspeed turbo heatshield, Grimmspeed EBCS, Perrin pitchstop mount, Kartboy bushings, battery tiedown, oil cap, Perrin reverse lockout leaver, Hella Supertones horns, GT-Spec flat bottom steering wheel, Rally Armor mudflaps, Pioneer 4600BT HU, JL Audio door speakers, sub, and amp, Weathertech floormats, Grimmspeed LWCP, Perrin front license plate delete and relocator, Perrin alternator and radiator shrouds, Grimmspeed master cylinder brace, TWM Gunmetal M1 Abrams shift knob, Defi boost and oil pressure gauges, SMY Clustermaker dual gaugepod, JDM black side badges, Greddy magnetic oil drain plug
    Great video, I liked the water crossings! I did a similar shorter video with my GoPro as well, what an amazing camera!
    Dubstep is the shit :cool:
  6. Feb 27, 2011 at 1:40 PM
    malander
    malander Well-Known Member
    max
    01 limited trd 4x4
    deck plate mod,jba cat back,bilstein 5100's,ome 883 springs, Allpro expos, allpro U-bolt flip kit, 10" Bilstien 5150 shocks, custom lower shock mounts
    nice vid man....bassnectar will be in missouri soon :)
  7. Feb 27, 2011 at 4:37 PM
    DEEVON911
    DEEVON911 Semi-Pro
    Dave
    Bethel Park, PA. Burb of da Burgh.
    2010 MGM Mostly Stock Off-Road 4x4
    TRD Cat-back Exhaust. Semi-Debadged. Trimmed down stock Antenna. Weathertech vent visors. TRD FJ Cruiser Center Cap Wheel Mod. 265/75/16 Firestone Destination A/T,s . Inverter tapped into for outlet in cab. Tacomaworld sticker which adds 5 hp.
    WTF is Dubstep? Anyway cool video.
  8. Feb 27, 2011 at 8:37 PM
    chaz834
    chaz834 Tacoma 4 Life.
    Chase
    Kendrick, Idaho
    2012 Sport MGM
    3'' Tuff Counrty Lift, Moromoto Mini H1 Projectors 5000K 35W, BHLM, 30'' LED Light Bar, Black TOYOTA Emblem, Excelon Touch Screen Deck, Hertz Speakers,Excelon AMP, 2 10'' JL Audio Subs, Wet Okle seat covers, Weather Tech Floor Mats.
    Cool video. :D
  9. Feb 27, 2011 at 8:40 PM
    AsianAnts
    AsianAnts just an AnT
    AnT
    Southern California (San Diego County)
    2011 PreRunner TRD Sport L/B Grey Metallic
    -Satoshi Grille Upper/Lower/Triangles -LED Map Lights, LED Dome Light, LED License Plate Lights -No front license -Wet Okole -Weather Techs (digi) -Running Boards -Bed Extender -AFE Cold Air Intake 2SI Dry Filter -Tailgate Hose-Clamp Mod, Tailgate washer Mod -Combi chain lock on bed extender -no chime w/ key in ignition & open door -Fog Light anytime -Slim Cubby's 3kHID fog -bumper plugs -keyhole plug -TRD license plate frame -combi-lock storage -rear TSB -window tint -camera mod -Painted radiator/engine covers -LS460 RetroFit -Bed Tie-Downs -LED Gauge Cluster, radio, clock and AC -Bed Mat -Extra DRings -Painted center console, radio unit, ac panel, overhead console.
    nice and +1 dubstep, DJ UMB!
  10. Feb 27, 2011 at 8:57 PM
    maxamillion2345
    maxamillion2345 Make Nevada Great Again, build the wall
    Max
    Nevada
    80 series LC
    Tons and 40s
    Cool man.
    Next time gotta put that cam under the truck as you drive through the water :D
    Maybe change up the camera position a couple times too.
  11. Feb 27, 2011 at 10:02 PM
    Sublime
    Sublime Well-Known Member
    Phoenix, AZ
    08 TRD 4x4
    Icon/All Pro.....chopped for 35's
    Was that the back side of 4 peaks? It looks smoother than I remerber? How are you liking those leepers?
  12. Feb 28, 2011 at 3:56 PM
    Infra
    Infra Well-Known Member
    Az
    2010 MGM DCSB 4x4 TRD OR 6spd
    CBI Bushmaster 2.0 rear bumper with swing out tire carrier & fold down camp table, CBI Moab 2.0 front bumper, Warn M8000-S, Icon 2.5 RR CDC Extended travel CO's with 700lb springs, Icon 2.5 RR CDC rear shocks, Icon hydro bumps, Total Chaos uniball UCA's, All Pro Expo leafs, U-bolt flip kit, Softopper, diff breather mod, extended rear brake lines, Grillecraft mesh grille, Elusive Elements behind grille light bar with B.A.M.F. LED light bar brackets, okLEDlightbars.com 20" double row LED light bar, Relentless Fabrication hood cb antenna mount, Wilson Silver Load CB antenna, Uniden 520 Pro XL CB radio, Wet okole seat covers, Weather tech floor liners, Weather tech in channel window deflectors, trasharoo spare tire trash bag carrier, Box Rocket 2nd gen bed rack with (2) 2 gallon gas rotopax mounted on drivers side, (2) 2 gallon water rotopax mounted on passenger side, (1) 3 gallon gas rotopax & (1) 2 gallon gas rotopax mounted on CBI swing out, Avid weld on sliders, Mattgecko LED bed light
    what program are you using to edit and make videos?
  13. Feb 28, 2011 at 5:53 PM
    CaptMorgan
    Tempe
    Yeah this time was a learning experience for sure, I did got some other angels. I took some from the hood which turned out to be a spring so that footage was shot. Got some from the side but the mirror got in the way (never thought it would have been in the shot but the lens is deceiving.
    I'm just using Windows Live Movie Maker to edit the vid's
    (open to suggestions)
    Sublime,
    Yeah, I was just on the other side of the 87 from 4 Peaks. Loving the leepers so far, been great to me.
  14. Mar 1, 2011 at 12:17 AM
    06rubi
    06rubi Well-Known Member
    Kenney
    Pueblo West, CO
    10 MGM (wife's truck)
    Debadged, tinted windows, 7 pin relocated, bed lights, 12 volt socket in bed of truck, on board air, auxiliary fuse box, grill craft, hella 500's, t-rex eyelids, pink budbuilt skids, icon remote resi coil over, camburg uca, alcan rear springs, ubolt flip, icon 2.5 remote rear resi shocks
    Desert wheelin sure looks fun! Are these typical looking trails or do they get a lot rougher? Do yall use 4wd or just keep it in 2wd?
  15. Mar 1, 2011 at 12:21 AM
    yotamikez
    yotamikez Street glide or die
    Valrico
    04 civic & 08 Street glide
    love videos like that! needs to be more!
  16. Mar 1, 2011 at 7:52 AM
    CaptMorgan
    Tempe
    This was more or less just a service road I guess. I do have some footage of much more aggressive terrain but I didnt like the mounting point so I didnt use it in the edit. My truck is only a 2 wheel squealer so that should answer your question ;-)
    Depending on what is going on this weekend I may be posting in the AZ thread to see if anyone wants to go out and get some footage with the GoPro this weekend.
  17. Mar 1, 2011 at 11:05 AM
    Infra
    Az
    Weird....when I use windows movie maker to try and edit any of videos it gives me an error message that says it cannot import a mpeg-4 file because it is not a supported file type.
  18. Mar 1, 2011 at 11:58 AM
    CaptMorgan
    Tempe
    Make sure you have Windows Live Movie Maker, the old just "Movie Maker" wouldn't accept MP4 files. I like Windows Live Movie Maker, works well, my only gripe is that it only exports to .wmv
    To be honest with you, looking at the site I think I might be due for an upgrade myself
    http://explore.live.com/windows-live-movie-maker?os=other
  19. Mar 1, 2011 at 12:01 PM
    Infra
    Az
    ok maybe a dumb question...but if it only exports to .wmv will the video still have excellent quality if shot in HD?
  20. Mar 1, 2011 at 12:24 PM
    CaptMorgan
    Tempe
    yeah the video does actually come out pretty good looking on my PC. The only reason I am opposed to .wmv is cause its Windows. As a linux fan/userI have a fondness for open none proprietary formats. Also, I think there may be better compression with .avi's, these files are pretty large for a 9 minute clip.
    I am interested in other editing software that is cheap/free and pretty easy on the resources. I have only on-board graphics (Intel 4500MHD) in my laptop and the other editing software I tried to use seemed to kill my laptop.
