Got a 1st gen tacoma as my first truck!!!
Discussion in 'New Members' started by DCoyle516, May 8, 2022.
  1. May 9, 2022 at 6:09 PM
    jimtoyota
    jimtoyota Well-Known Member
    Jim
    Maryland
    2004 Tacoma; 2018 4Runner
    Welcome aboard! That is a great first vehicle and you're in the midst of many knowledgeable enthusiasts and friends. We're glad to have you.
  2. May 9, 2022 at 6:25 PM
    6P4
    6P4 Well-Known Member
    Colorado Springs
    98/2.7L/Regular Cab/4x4/5spd/Open diff
    The standard bolt-on lift is an Old Man Emu kit, like this one: It's a proper, performance-oriented lift, where the ride height is gained through taller springs.
    Similar lifts are available using Bilstein 5100 shocks. Some people prefer Bilstein over OME. I have no opinion myself, but you'll find plenty if you search the forum. Many people have been in the same position as you and had the same questions--the lift options for these trucks haven't changed much over the past 10 years.
    Cheaper lifts use blocks or spacers to gain height. They won't look any different from 10 feet away, but they won't ride or flex as well as a spring lift. Block/spacer lifts can also cause problems--the front shocks may bottom out during aggressive driving and the rear axle may wrap (google "axle wrap").
    The kit I linked to gives you the choice of new leaf packs or an add-a-leaf. Given the age of the truck, it's probably worthwhile to spend the money on new leaf packs. Make sure the packs you get are specifically labeled for 95-97 Tacomas. The early trucks use a different (shorter) leaf spring than 98-04.
  3. May 9, 2022 at 6:35 PM
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    Welcome aboard David..,. nice ride ya got there!! :thumbsup:
  4. May 10, 2022 at 5:07 AM
    DCoyle516
    DCoyle516 [OP] New Member
    David
    1996 Toyota Tacoma
    Ok yeah I have definitely heard good things about OME… How difficult is it to install? My dad works with cars a lot and has fixed the issues on my truck with me so far (alternator, power steering, etc.) Is it something we could do ourselves? Also what is the difference when it says assembled v unassembled about the front coilovers and shocks? Thanks
  5. May 10, 2022 at 6:39 AM
    DCoyle516
    David
    1996 Toyota Tacoma
    Also under rear lifts both options say Add-a-Leaf, but one says toytec progressive 3 add a leaf pack (pair) (+$189), and the other just says toytec rear add a leafs. Which did you say I should get? Sorry for my lack of knowledge…
  6. May 10, 2022 at 6:49 AM
    aficianado
    aficianado Well-Known Member
    bay area, california
    2006 access cab. 4x4, TRD-OR + 2023 TRD off-road.
    back to bone stock.
    nice truck!! if i could write my 16 year old self a note by sending it back in a time machine:
    calm the hell down!! i would drive it as is for awhile. save some money up. you started off gobs better than my first car. learn the typical preventative maintenence stuff and really decide what you want to do. my note to my 16 yr old self would be to focus on school and take all that money i spent on my 1971 camaro and buy Google and Apple stock. :) i would be retired at 40.hahaha...
    then i can go crazy. that first car is long long gone, and so is the money i pooped into it.
  7. May 28, 2022 at 11:01 PM
    SecureIT2021
    SecureIT2021 Well-Known Member
    06 Tundra SR5 LTD CC 4.7 V8 AT 2WD
    You should be able to find exactly what you need on this site. Master mechanics and endless resources are available. Work on it in stages and you'll eventually get it where you want it.
