Got a ceramic coating!!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Collinmcd99, Oct 29, 2017.
  1. Oct 30, 2017 at 12:03 PM
    #41
    amalik
    amalik Well-Known Member
    Denver
    Super rich folks PPF their whole ride I believe.
  2. Oct 30, 2017 at 12:08 PM
    #42
    BVita
    BVita Mall Cruiser
    Some ceramic coat then ppf the entire car, and then coat the film
    LTDSC and amalik[QUOTED] like this.
  3. Oct 30, 2017 at 12:09 PM
    #43
    PackCon
    PackCon Well-Known Member
    Connor
    2017 Subaru Forester Limited
    I have had different experiences.
    I applied Jet Seal in April. Water still beads on my hood. I was going to reapply before winter but I’ve decided to see how long it lasts and wait till my spring detail.
    Now you do have to maintain a sealant. It needs to be applied to a clayed surface, maintained with pH balanced soaps, and you can’t be aggressive with washes. You will scrub the sealer off.
    The only places I have had to reapply the sealer have been my front bumper and headlights. Scrubbing the bugs off over the summer kind of wore the sealer off but that is to be expected.
    I dig the stuff.
    If your sealers come off that easy you aren’t maintaining them.
    An auto wash or non pH balanced soap will strip them in a heartbeat.
    DriftingPanda18 likes this.
  4. Oct 30, 2017 at 12:11 PM
    #44
    DriftingPanda18
    DriftingPanda18 Well-Known Member
    Patel
    Florida
    2013 Spruce Green Prerunner
    33s
    Chemical guys hybrid v7 is pretty good, I apply it after every wash and last a good bit.
  5. Oct 30, 2017 at 12:12 PM
    #45
    PackCon
    Connor
    You don’t have to have faith in good products.
  6. Oct 30, 2017 at 12:13 PM
    #46
    amalik
    Denver
    Fuckers, lets take their moneys.
  7. Oct 30, 2017 at 12:15 PM
    #47
    DriftingPanda18
    Patel
    Florida
    33s
    You can also clear bra the truck and not worry about scratching the paint at all.
    Collinmcd99[OP] likes this.
  8. Oct 30, 2017 at 12:21 PM
    #48
    Collinmcd99
    Collinmcd99 [OP] Well-Known Member
    Collin
    Southern California
    2015 gray Tacoma TRD off road
    I know a lot about detailing I tried my best to maintain it I use the right products I just never had good luck with the product
    LTDSC likes this.
  9. Oct 30, 2017 at 2:05 PM
    #49
    Musubi3
    Musubi3 Well-Known Member
    Big Island
    2014 Tacoma DC 4x4 TRD Off Road, Supercharged
    I think light surface scratching may only scratch the coating and not the clearcoat.
    I was out exploring yesterday and had quite a few keawe branches (thorny trees) brush up against my paint. So far I haven't noticed any scratches, but the branches were more new shoots and if anything light brush.
    I put two layers of the ceramic coating on. I had made an error on my tailgate with the application and redid it. It was quite hard to take off by hand and tougher than I thought. It's not going to protect from dents or all scratches. My truck is Blue Ribbon Metallic and I just want to make sure I'm taking care of my higher maintenance paint.
    So far I think the coating is a good investment of time and money I (and others) put in. With our Hawaii weather, including the rain, sun, salt, and vog (contributes to acid rain), I wanted to try something different, hopefully better, and less maintenance. I actually like it when it rains now so I can awe at the beading.
    LTDSC and Oreo Cat[QUOTED] like this.
  10. Oct 30, 2017 at 2:07 PM
    #50
    Vereor_Nox
    Vereor_Nox Fumblerooski
    North California
    2010 Tacoma TRD Sport
    Chocolate milk?
    That for sure doesn't look like any mud i've ever seen offroad.
    TegoTaco likes this.
  11. Oct 30, 2017 at 4:06 PM
    #51
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Sounds about right. With a username like Pigpen I would expect nothing less than that sort of work to be done after the OE paint fails.
    :D
    TegoTaco and Pigpen[QUOTED] like this.
  12. Oct 30, 2017 at 4:14 PM
    #52
    forana
    forana Well-Known Member
    Kaneohe, Hawaii
    2022 DCSB OR Lunar Rock
    No money, all went to truck...
    Been using ceramic on 3 cars in the family. I apply myself, lots of prep work, takes me about a day to complete whole process. The actual coating costs ~$80 for the kit. I wash well, clay, polish then apply the coating. Suppose to last 2-3 years. So far my wife's car is one year out and water still beads pretty well. So for a year+ of solid coating, totally worth it.
    Collinmcd99[OP] and Musubi3 like this.
  13. Oct 30, 2017 at 4:32 PM
    #53
    Pigpen
    Dan
    Northwest Montana
    I also still haven't loosened my body mount bolts and torqued to spec. They're somewhere around 85 ft/ lbs still.
    But yeah, I don't treat my stuff too well :anonymous:
  14. Oct 30, 2017 at 4:44 PM
    #54
    batacoma
    batacoma Truck Wars
    2012 Regular Cab 4spd
    I made sure to buy a truck the same color as dirt and it still looks good clean.
  15. Oct 30, 2017 at 4:46 PM
    #55
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Well yeah. I haven't torqued a thing on my truck. For sure not the body mount bolts. I just set them guttentite. Done. Lol.
  16. Oct 30, 2017 at 5:05 PM
    #56
    Collinmcd99
    Collin
    Southern California
    Nice I hear it’s all about how you prep it
  17. Oct 30, 2017 at 5:14 PM
    #57
    DANGERMONEY
    DANGERMONEY Well-Known Member
    I never used a clay bar before waxing until a few years ago and never marred my paint. I am also lucky that my waxing lasted 6 months plus. Also, waxing is not labor intensive.
    There is science behind ceramic coatings but you don't have to have a high IQ or super secret tools to apply it. It's a process you can learn and do yourself.
    It's a labor of love for some folks whether you laugh at us who use wax or invest 1k into the next best thing.
    808leo and Collinmcd99[OP] like this.
  18. Oct 31, 2017 at 7:27 AM
    #58
    TacomaJay09
    TacomaJay09 Well-Known Member
    Central MA
    09 TRD Sport Dbl Cab
    None Yet
    I hear ya. I would do it myself but don't have the time. I used to enjoy detailing my car, and now I rush through it.
    Vereor_Nox likes this.
  19. Oct 31, 2017 at 7:54 AM
    #59
    LEXICON
    LEXICON born where the prairies meet the rockies
    Courtney
    Canada
    2016DCLBBLACKTACOMATRDSPORT4X4PREMIUM
    Nothing worthy
    Looking to get Restore FX done to our truck.
    Local shop tells us it's superior to ceramic coating..
    Anyone with experience?
    http://www.restorfx.com
  20. Oct 31, 2017 at 7:59 AM
    #60
    LTDSC
    LTDSC 32oz of fun
    Sam
    NorCal
    you cant win with CG fanboys. Its apparent thats all he knows.
    Those that have extensive experience with detailing and several products know, CG is crap.
