Got a misc...?
Discussion in '4 Cylinder' started by Wreckless_71, Aug 6, 2009.
  1. Aug 6, 2009 at 9:23 AM
    Wreckless_71
    Wreckless_71 [OP] WRECKLESS for Life...
    Justin
    Pullman, WA.
    98 ext cab Tacoma
    3" Lift via OME 881's, Bilstein 5100's, Dakar OME 3" leaf packs, MBRP custom exhaust, HID headlights, CB, Canopy, aluminum wheels, upgraded sound system, full set of studded snow tires and wheels, auxilary lighting, more to come.
    Hey guys... I have a 1998 2.7L 3RZ and I have a question. It feels to me like the engine has a little miss, and it has a little flutter off the bottom when I rev it from idle, throttle response is lacking because of it. What can I do or what might the problem be? I never seemed to have an issue when I first got it less than a month ago. I put new plugs and wires on it, and it seems to run just fine cruisin down the road, but then I noticed the miss.
  2. Aug 11, 2009 at 8:50 AM
    Wreckless_71
    Justin
    Pullman, WA.
    98 ext cab Tacoma
  3. Aug 11, 2009 at 9:03 AM
    drew02a
    drew02a Rocking your mom's world Since 1997
    San Antonio, TX
    2006 Regular Cab 2.7L 4x4
    Alternator?
  4. Aug 11, 2009 at 9:03 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Are the plugs propperly/correcttly gapped? What kind of wires?
  5. Aug 11, 2009 at 9:07 AM
    drew02a
    San Antonio, TX
    Actually meant Distributor, but I don't even know if your truck has one.
  6. Aug 11, 2009 at 9:20 AM
    Wreckless_71
    Justin
    Pullman, WA.
    98 ext cab Tacoma
    my truck is a 2.7L 1998. It has a distributer obviously, the wires are just OEM replacement, the plugs are NGK platinum's. They should be gapped at .040-.041 correct..?
  7. Aug 11, 2009 at 10:12 AM
    InfidelTaco
    InfidelTaco No better friend,No worse enemy...
    G
    PNW
    Prerunner
    AFE, Fox, Built Rights, Moog, SpiderTrax, Icon progressive, Grabbers
    Major tune up? when was ur last?
  8. Aug 11, 2009 at 11:18 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Make sure the wires are all connected propperly, and check the gap of the plugs. You could have a bad wire, and the spark is jumping the bad part.
  9. Aug 11, 2009 at 11:37 AM
    Wreckless_71
    Justin
    Pullman, WA.
    98 ext cab Tacoma
    well that's why i replaced the wires... I had a couple bad ones. As far as a major tune-up what are you talking..? Lubes, plugs, wires, filters, etc..?
  10. Aug 11, 2009 at 11:41 AM
    Wreckless_71
    Justin
    Pullman, WA.
    98 ext cab Tacoma
    Fuel Filter possibly, that is the one thing I haven't done..? I did all the lubes, filters, plugs and wires about 5,000 miles ago when I got the truck in late June. The truck now has around 198,XXX miles on her...
  11. Aug 11, 2009 at 12:38 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Couldnt hurt to replace the fuel filter, though if its plugged, the issues usually alear when you are under a lload.
  12. Aug 11, 2009 at 12:40 PM
    drew02a
    San Antonio, TX
    So, no second thought about the distributor cap?
  13. Aug 11, 2009 at 4:47 PM
    Wreckless_71
    Justin
    Pullman, WA.
    98 ext cab Tacoma
    Once I thought about it I realized it never had a distributer.... it has electronic ignition... Since I had it I've done new exhaust from the cat back and full service. I don't really know what else to think...
  14. Aug 17, 2009 at 9:56 AM
    Wreckless_71
    Justin
    Pullman, WA.
    98 ext cab Tacoma
    changed the fuel filter... that was a PITA. Still have a miss... I'm leaning towards a vacuum leak now, maybe intake needs to be resealed. I'm going to do the old ether trick and see if I can't find a leak somewhere...
  15. Aug 20, 2009 at 8:25 AM
    Wreckless_71
    Justin
    Pullman, WA.
    98 ext cab Tacoma
    Just so you guys know... it was the damn plugs the guy at the parts house gave me. He gave me some platinum jobbers and I never really thought about it. Changed em out and shes running like a champ...
