Got a 'new' 1986 Invader 17' I/O- The Journey to Refresh
Discussion in 'Boating & Fishing' started by AFMurse2014, May 1, 2019.
  1. Jun 10, 2019 at 6:11 AM
    #101
    AFMurse2014
    AFMurse2014 [OP] Death Can Wait
    Devin
    San Antonio
    2016 MGM Double Cab TRD OFF ROAD 6 Speed MANUAL
    Freedom, American flags and ISIS blood Morimoto 35w 5500k HID/ LED highs from TRS. RCI expo rack Core Short throw shifter, hypertech speedo recalibrator. Rear seat molle panel. OVT. PnP 2LM. C4 Hybrid Bumper w/ amber BD squadron pods. 33 pizza cutters. T9 radio
    Filters are clean.
  2. Jun 10, 2019 at 7:23 AM
    #102
    Old Marine Cal
    Old Marine Cal Well-Known Member
    2015 MGM DBLCAB
    then youtube university learn how to adjust the carburetor and timing the old school way...…………….slow
    methodical
    and soon you will truly appreciate the simplicity of Fuel Injection...……...
  3. Jun 10, 2019 at 7:33 AM
    #103
    AFMurse2014
    Devin
    San Antonio
    It's only got two screws, so it can't be that hard lol
  4. Jun 10, 2019 at 7:50 AM
    #104
    Old Marine Cal
    2015 MGM DBLCAB
    Get back to me when you have actually done it.
    I have made a ton of money back in the day from guys who said something similar.
  5. Jun 10, 2019 at 10:33 AM
    #105
    AFMurse2014
    Devin
    San Antonio
    You doubt my persistence. I'm going to probably go out today and dick with it. Charging the battery now. It died on my last trip so I ran it off the trucks AGM lol
  6. Jun 11, 2019 at 9:51 PM
    #106
    AFMurse2014
    Devin
    San Antonio
    Well. Now it starts and idles like a champ. But it's back to bogging when I give it gas....
  7. Jun 12, 2019 at 5:26 AM
    #107
    Old Marine Cal
    2015 MGM DBLCAB
    Might be something to do with those 2 screws..........
  8. Jun 12, 2019 at 6:05 AM
    #108
    AFMurse2014
    Devin
    San Antonio
    Ya don't say? Lol.
    I bumped the idle screw up so it idles at 6-700 rpms and it seems to like that. The idle air screw is backed out 1 1/4 turn as specified in the manual. Not sure which one to mess with. More than likely it's probably getting too much air I assume.
  9. Jun 12, 2019 at 9:09 AM
    #109
    Old Marine Cal
    2015 MGM DBLCAB
    I am thinking, without benefit of being there, it's starving for fuel when you romp on it, general cause of falling on it's face...………….
    but I can see you learning to fully appreciate fuel injection...…………..
  10. Jun 13, 2019 at 6:26 AM
    #110
    AFMurse2014
    Devin
    San Antonio
    Not sure how to give it more fuel. All new jets,a accelerator pump and internals float is measured to spec. Only adjustments I can make are idle and idle air. I have it idling at 6-700rpm it seems to love that for start up and idling. Runs pretty smooth. But it's back to when I give it gas it falls on it's face.. the last run it barely idled and had difficulty starting, but it jumped outta the holeshot great
  11. Jun 13, 2019 at 8:45 AM
    #111
    JL8Jeff
    JL8Jeff Well-Known Member
    Jeff
    Ewing, NJ
    2013 Tacoma reg cab
    OME 885/nitros, SPC UCA, 305/65/17, AAL
    Carbs can be a pain to get set right. You might have the throttle open too much with the idle adjustment. Can you back off the idle screw and then get the idle back up with adjusting the idle air screw?
    Old Marine Cal likes this.
  12. Jun 13, 2019 at 11:09 AM
    #112
    AFMurse2014
    Devin
    San Antonio
    Idle air screw doesn't affect RPMs at all on this thing unfortunately. It either runs smooth, or it'll stumble when messing with idle air haha
  13. Jun 13, 2019 at 11:25 AM
    #113
    JL8Jeff
    Jeff
    Ewing, NJ
    2013 Tacoma reg cab
    Maybe you need more timing to get the idle up and then you can back off the idle screw.
  14. Jun 13, 2019 at 4:24 PM
    #114
    Old Marine Cal
    2015 MGM DBLCAB
    or maybe you need to go back a few post
    grab a timinglight.. tach dwell meter
    visit a youtube channel
    get the specs for your boat engine
    and walk through it
    one step at a time
    as I suggested...………….....
  15. Jun 13, 2019 at 5:24 PM
    #115
    JL8Jeff
    Jeff
    Ewing, NJ
    2013 Tacoma reg cab
    Yeah, it can be fun doing the fine tuning for your combination. Add to that the difference between a prop motor setup vs jet setup and car engine vs boat engine. I found that on my old jersey speed skiff the distributor had the 2 spring loaded hold down clamp and that still allowed for too much movement when the boat was bouncing off the waves and it ate up a new rotor in 1 day. I had to switch to a cap with screws to hold everything tight in place. Boat stuff does not translate to car stuff in a lot of situations.
  16. Jun 13, 2019 at 8:36 PM
    #116
    AFMurse2014
    Devin
    San Antonio
    Yea... Not everyone can just "grab a timing light and tach meter"
  17. Jun 13, 2019 at 9:17 PM
    #117
    Old Marine Cal
    2015 MGM DBLCAB
    Autozone loans them out
    Posting for a friend
  18. Jun 16, 2019 at 10:31 AM
    #118
    AFMurse2014
    Devin
    San Antonio
    Everything checks out. I think it's due to the improper prop size. Once I get the prop spinning I can give it throttle agressively. But if I try from idle it definitely tries to stall out the engine. I can rev it by hand in neutral in the water with absolutely no issues. It's getting good sprays of fuel, accelerator pumps working as it should, it starts and idles like a dream.
    No timing issues. It'll just have to be a quirk that I work around for now. It still runs and boats.
  19. Jun 16, 2019 at 11:28 AM
    #119
    Old Marine Cal
    2015 MGM DBLCAB
    Good to know you have isolated the issue.
    Have fun with it
    And keep showing the progress.
  20. Jun 16, 2019 at 1:59 PM
    #120
    AFMurse2014
    Devin
    San Antonio
    I'm going to reach out to the local boat pick n pull and see what they recommend for a prop. Maybe I can do a trade.
    Next up I'm going to start rebuilding the lounge seats. I have a group of people I'm taking out on the 29th and I want my main seats to be in good order.
    I also want to wire up my switch gang, fix the radio and speakers and throw in some lights/get some night time spot lights so I can run easier at night.
    I just am trying to decide where to put the switch gang that won't look tacky...
    Also... My trim gauge doesn't read properly/backwards and my fuel gauge is everywhere and the temp gauge doesn't ever move.
    Unfortunately I am also prepping for some field training and a deployment so I am running out of time to work on this thing.
