Got a new (to me) front bumper. How do I paint the center black?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by LeadFootCaliKid, Dec 12, 2011.
  1. Dec 12, 2011 at 9:30 PM
    LeadFootCaliKid
    LeadFootCaliKid [OP] It's a work in progress.
    Blake
    Temecula/North SD
    2005 DC PreRunner TRD Off-Road
    Total Chaos UCA's, Icon coil-overs, Icon gas reservoir rear shocks, Eagle Alloy 17", Nitto Terra Grappler 285/75/17, Flowmaster 40, Kenwood deck, and dual 10" Kicker subs, shorty antenna. There's more...
    Its been over a year since I've been on here. During that time, I crashed my truck 3 times, basically ruining my front bumper. I picked up a used one the other day for pretty cheap that I've decided to paint the lower center section black. My one problem, I don't know how. Haha. What paint should I use? What should I do to prep the bumper? Any info will help.
    And before you tell me to search, I did. I couldn't find much.
    Thanks.
  2. Dec 13, 2011 at 8:05 AM
    LeadFootCaliKid
    Blake
    Temecula/North SD
    Bump. I was hoping to paint it this weekend.
  3. Dec 13, 2011 at 8:08 AM
    RAT PRODUCTS
    RAT PRODUCTS Raw Strength Equipment
    Farmington, MN
    Cummins Coal Rollin SOB
    Smokin with a smarty.
    I've heard vinyl is all the rage these days.
  4. Dec 13, 2011 at 8:10 AM
    Aw9d
    Aw9d That one guy
    Az
    Tape off what you don't want to paint,
    sand down what you want to paint. Wipe it clean
    use primer first, let it dry between coats,
    then use spray paint, follow directions.
    then use clear coat
    then wet sand.
  5. Dec 13, 2011 at 8:14 AM
    hookedontronics
    hookedontronics Well-Known Member
    Jake
    Glenville, NY
    2010 DC Off Road 4x4
    Icon extended travel 3.5" front coilovers, DSM UCAs, TSB leaf pack w/ wheelers AAL, All Pro U-bolt flip kit, Walker Evans 2.0 rear shocks, 18" XD Monster rims, Nitto trail grappler 285/65R18 Tires, Color matched grill, Grillcraft, Kragen HIDs, Carling switches, my bed light mod, diff drop, Alpine IVA-W505, JL Audio C5 componets and coaxials, JL 300/4 and 250/1 amps and JL stealthbox, wheathertechs, avs vent visors, toyota bed x-tender, alcantara center console cover and door pocket covers, console vault, color matched mirrors, heated mirrors, etc etc etc
    i have mine line-x'd for 50 bucks. Just so i don't have to worry about it chipping and repainting it
  6. Dec 13, 2011 at 8:25 AM
    Johns Taco
    Johns Taco I'm not 4x4, and have an open diff. So i'm 4x1
    Albuquerque, NM
    05 DSM Base SR5 Slug Taco
    Full custom stereo, onboard air compressor, train horns, spacer lift, 30" tires, optima yellow top, rear slider window & tailgate anti-theft mod, pop & lock, class 3 tow hitch, lights in bed, Ultra Gauge, Weather Tech mats, yellow fog lights, camper top, air lift rear airbags, rear diff breather mod, soon to be more...
  7. Dec 13, 2011 at 8:28 AM
    Pugga
    Massachusetts
    '13 Ford F-150 SCREW
    F-150 Mod
    Screw plasti-dip, especially if you're prone to hitting things... Tape off what you don't want painted, give it a light sand, clean it well with a lint-free cloth and some rubbing alcohol (light on the alcohol, it's just to remove any oils and waxes), then hit it with Rustoleum Bed Liner. Permanent and will not scratch or chip.
  8. Dec 13, 2011 at 8:30 AM
    chadderkdawg
    chadderkdawg Don't ask questions you don't want the answer to..
    Des Moines, Iowa
    09 FX4 F150
    I'll just leave this here...
  9. Dec 13, 2011 at 8:33 AM
    Pugga
    Massachusetts
    F-150 Mod
    That's the stuff I was talking about. It's good shit! :thumbsup:
  10. Dec 13, 2011 at 8:36 AM
    chadderkdawg
    Des Moines, Iowa
    09 FX4 F150
    It's been tough at nails for me, looks schweet too, did my valance and skid with it.
  11. Dec 13, 2011 at 9:37 AM
    Burns
    Burns Excellent Member
    NJ
    17 DCSB Off-Road
    None!
    X3 I used it on my lower valence good stuff!
  12. Dec 13, 2011 at 3:52 PM
    LeadFootCaliKid
    Blake
    Temecula/North SD
    Does the rustoleum bed liner have a texture to it or is it just like a flat black paint? And what grit sand paper do i prep the bumper with?
  13. Dec 13, 2011 at 8:05 PM
    LeadFootCaliKid
    Blake
    Temecula/North SD
  14. Dec 13, 2011 at 8:17 PM
    GoDeacsWFU23
    GoDeacsWFU23 Well-Known Member
    Jonathan
    Clemmons, NC
    2013 Tacoma PreRunner TRD Sport
    Dupli Color Bed Liner Spray
    You will get this texture:
  15. Dec 15, 2011 at 12:31 PM
    LeadFootCaliKid
    Blake
    Temecula/North SD
    I picked up a can of rustoleum bed liner and one of rustoleum undercoating. Both are rubberized so would I be able to use the undercoating instead of the bed liner just to get an untextured look?
  16. Dec 15, 2011 at 12:47 PM
    Pugga
    Massachusetts
    F-150 Mod
    I don't know what the undercoating comes out like. If you want a flat look, no texture at all, you should just use regular spray paint and a clear coat. Something like Krylon Fusion would work well for the valance. The Rustoleum bed liner is textured but it had a nice look to it in my opinion.
  17. Dec 16, 2011 at 1:12 PM
    LeadFootCaliKid
    Blake
    Temecula/North SD
    Ok so I just did my first coat. I started with the undercoating because I wanted a non-textured look, but it looks like the undercoating has a texture to it too. So now I'm wondering if I should use the bed liner now.
    Does anybody know what the difference between the bedliner and undercoating?
  18. Dec 16, 2011 at 2:06 PM
    GoDeacsWFU23
    Jonathan
    Clemmons, NC
    Test both products on something other than your truck and wait for them to dry to see what they turn out like.
