Got a new toy need opinions on tires.
Discussion in '1st Gen. Tacomas (1995-2004)' started by 1999tacotrd, Jul 1, 2009.
  1. Jul 1, 2009 at 10:03 PM
    1999tacotrd
    1999tacotrd [OP] 1999 Taco TRD xtracab 3.4 V6 4x4
    I ended up buying a 88 toyota 4x4 pickup with a 6" lift on it :) for $1400 its a 22re motor and pretty rock soild its a great trail turck but it needs new tires bad the tire's on it is 235/50/15 street tires i need some bigger tires and would like to know how big can i go w/o haveing to regear it? and if i didnt regear it and use big tires like 36's what would it do would it tear the truck up? I think its 4.29 ratio on it but im not sure
    just lmk your opinions on what size tires to get i will get some pics of it up tomamrow on here
  2. Jul 8, 2009 at 10:02 PM
    pairodice
    pairodice Well-Known Member
    Jay
    SF NM
    02 DCSB prerunner 4x4 manual
    31/10.5 r15 are about as big as you can go unless you want to stop using 5th gear
  3. Jul 8, 2009 at 10:10 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners, Camper shell, ultimate headlight upgrade. URD -3° exhaust cam gears, .5" XTP Intake spacer. Custom dents.
    Get some 33s as the minumum, to make the 6" lift not look so wild. Maybe 35s.
    Noticing the 22re. Not sure if it will have enough to turn those tires effectively? Maybe just 33s. Others will chime in with their experience.
  4. Jul 8, 2009 at 10:29 PM
    rab89
    rab89 Well-Known Member
    Ross
    Kelowna b.c canada
    2017 DCLB TRD Sport
    33's would be fine, 35's would be a struggle.
  5. Jul 8, 2009 at 10:33 PM
    1999tacotrd
    I ended up getting 33 13.50s and they work fine didnt see much difference in power loss. They just rough driveing on road cause there super swampers. But its mainly a off road truck only on road driveing is to get to the trails
