Got a price to install the 5100's...
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Larry, Mar 10, 2011.
  1. Mar 10, 2011 at 3:14 PM
    Larry
    Larry [OP] CARL
    CARL
    One local Indy shop wouldn't do it because I already have the shocks...
    Goodyear tire center will do it for flat rate which = $270.00 for the fronts...$72.00 for the rears...$79.00 for an alignment...
    $421.00 total (plus taxes and any "fees" they can add in)
    Seems high? Is this fair? or should I just make the drive to the Toyota dealership 50 miles away?
  2. Mar 10, 2011 at 3:19 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Thats cheaper than Toyota will charge, but you should see if there are any members nearby that may be able to help you DIY.
  3. Mar 10, 2011 at 3:29 PM
    757southpaw
    757southpaw Well-Known Member
    Jay
    757
    07' DC LB TRD Sport 4x4
    BAK BakFlip Tonneau cover, 30% front tinted windows, AVS vent shades, Black Billet Grill,Pop& Lock, secondary air filter removed, Goodyear Duratrac's, Billies @ 2.5" on front, Billies on back w/ 1.5" AAL, Toytec Diff drop, NOKYA Hyper Yellow fog light bulbs, LaminX Weathertechs, Rear diff breather mod, BHLM
    x2
  4. Mar 10, 2011 at 3:30 PM
    Larry
    Larry [OP] CARL
    CARL
    Thanks Chris. I felt pretty good about the Goodyear shop...the manager seemed like he was wanting to earn my business...
    I'm comfortable with doing the rears myself...but the fronts require more work and a spring press...
    Then there is the alignment...
  5. Mar 10, 2011 at 3:31 PM
    snorola
    snorola Well-Known Member
    Brett
    Canmore Alberta
    06 4x4 Dbl Cab
    SAW 2.0 Coilovers Eibach 14" 650lb springs Camburg UCA's All pro expo springs OME rear shocks All pro front bumper All pro IFS skid All pro sliders SCS f5 matt black rims Lightforce blitz 240's
    you should really consider doing the rears yourself! It is very easy
  6. Mar 10, 2011 at 3:32 PM
    Khaos
    Khaos Big Member
    Bryant
    Jacksonville, Florida
    2005 Prerunner TRD Off Road
    265/75/16 BFG A/T, 18" Magnaflow, K&N Intake Filter, Ultra-Gauge, Kobalt Toolbox, Metal Tail Light Guards, Cobra 19 and 4ft fiberglass antenna, Plasti dipped Badges/lower valance/rear bumper/grill/bullbar/ac controls, black DIN kit, JVC KD-X40, Wet Suit Seat Covers
    Do what I plan on doing. Take your stock coil assembly off the truck and take it with your new shocks to a local place to have them compresses and install your shocks on, then take 'em back home and reinstall them. It will save you a lot of money and then you'll get the satisfaction of doing it yourself.
    Of course you'll have to have an alignment done afterwords, but with the money you save on install that gives you money for beer or more mods.
  7. Mar 10, 2011 at 3:40 PM
    skistoy
    skistoy Make mine a Double!
    Western New York
    09 4X4 SR5 BSP Double Taco
    Rear Spring TSB,Billy 5100@.85,Bull bar,Nerfbar,Painted Grill,Painted Rims,Bed D-rings,Compustar Starter,Goodyear Duratrac's,Transmission TSB,Brake Overide
    its one of those crap shots
    i did the front ones with a buddy who is in the auto biz.
    its not really hard to do the front ones
    compressing the springs to remove and replace shocks can be tricky
    the rear ones are real simple.
    but i always say, if you dont have the knowledge or tools
    its better to let them do it.
    Decided what your going to set them at?
  8. Mar 10, 2011 at 3:45 PM
    pudge151
    pudge151 Well-Known Member
    Sean
    Connecticut
    2015 Tundra Platinum
    this is what i did, then got my TSB rear leafs done. free alignment
  9. Mar 10, 2011 at 3:45 PM
    Larry
    Larry [OP] CARL
    CARL
    Gonna set the fronts @ .85
    my truck is not a rock crawler...and I want to get the front up a little to get back to a factory stance after the rear TSB spring install lifted the rear approx. one inch.
    I decided to get the rears while I was at it.
    I may install the rears myself and save the $70.00 labor.
    The fronts I'm not gonna fool with...and of course I need an alignment done by a shop who knows it correctly.
  10. Mar 10, 2011 at 3:51 PM
    FITTYGRIT
    FITTYGRIT Member
    Kyle
    Missouri
    11 Tacoma DC TRD Off-Road
    Extand Trifold Cover, Husky Floor Liners, Bilstein 5100's @ 2.5" Rear TSB
    Man, that seems really expensive. If you have a competent mechanic that you know I would take it to them. Mine charged me the flat rate for front strut replacement (2 hrs @ $65/hr + alignment $60). It totalled $190 for installation. I supplied the 5100's and to make sure he had no excuses, I printed detailed instructions on the installation. He had no problems and it rides awesome.
    Good Luck!
  11. Mar 10, 2011 at 4:14 PM
    TOYOTA 09
    TOYOTA 09 Kicking Ass Since 1981
    Maine
    2009 SR5 MT 4x4 Access Cab
    Preview 2009 SR5 4x4 MT Black Sand Pearl (Access Cab) SUSPENSION ToyTec 5100 Billstein Coil Overs (3" Lift) Fox 2.0 Remote Res Rear Shocks Total Chaos UCAs Full Dakar Leaf Pack w/Extra AAL TIRES & WHEELS BFG AT KOs 265/75/16 load range E American Rancing AR-23 Wheels Borla CAT back exhaust AFE cold air intake w/custom TRD clear cover Satoshi grill w/Grill Craft insert Hella 500 behind grill lights Rigid Industries Backup lights Interior Custom LEDs and Bed Lights Backup Cam Anytime MOD Leather armrest and rear seat MOD Weathertech floor liners Custom rear gear/dog platform Cobra CB and Garmin GPS Bed Mat UWS low pro tool box with Custom LED lights Diff breather MOD Custom painted engine cover Wet Okole seat covers
    my local off road show wanted 640 to install the OME full kit!!!!
  12. Mar 10, 2011 at 5:10 PM
    skistoy
    Western New York
    sounds like a good call to me
  13. Mar 10, 2011 at 6:46 PM
    O6trd4x4
    O6trd4x4 Active Member
    Frontera Arizona
    06 access TRD 4x4
    WeatherTech floorliners, Auto Dimming rearview mirror with homelink, front mud flaps removed, AZ pin stripes
    Chris4x4....is that a standing offer for when I get my 5100? That would be awesome
  14. Mar 10, 2011 at 6:50 PM
    DWreck
    DWreck Famous Retrieval Vendor
    Derek
    Las Vegas, NV
    2004 Tacoma Smurf Truck
    Plasti-dip paint, TRD S/C, MCM Fab LT kit, bunches of my fab
  15. Mar 10, 2011 at 6:51 PM
    crf69
    crf69 scraping my emblems off my plasti-dip
    Ohio
    06 TRD OR BSP cab'n 1/2
    ummm yeah
    its really easy i mean really easy....
  16. Mar 10, 2011 at 6:54 PM
    DWreck
    Derek
    Las Vegas, NV
    I have an install thread!
  17. Mar 10, 2011 at 6:56 PM
    crf69
    Ohio
    ummm yeah
    yup you do....and it was well done:cool:
  18. Mar 10, 2011 at 6:58 PM
    Sje1124
    Sje1124 Well-Known Member
    Sean
    Louisiana
    2010 DBL Cab TRD OR 4x4
    Just a few
    My local shop also wanted around $600 to install the full OME kit and thats with a 10% discount for military. Im just going to have someone else help me put it on.
  19. Mar 10, 2011 at 7:09 PM
    DWreck
    Derek
    Las Vegas, NV
    Thanks much!
  20. Mar 10, 2011 at 7:13 PM
    DWreck
    Derek
    Las Vegas, NV
