got a problem with my frame
Discussion in 'Technical Chat' started by trac447, Mar 19, 2013.
  1. Mar 19, 2013 at 4:18 PM
    trac447
    trac447 [OP] Member
    south otselic
    06 tacoma sr5 2.7l
    i have a 2006 tacoma with 170,000 miles on i was servicing it & found that my frame rails are all rotted away over the rear axle & cracked around the spring stops. the cross member over the axle is rotted as well.
    i called toyota & they said there is nothing they can do for me. has anyone else had this rust problem i even had it undercoated from the dealer when i bought it
  2. Mar 19, 2013 at 4:19 PM
    Justus
    Justus fucks not given
    Nabisco the kid
    In ur toolbox
    stockish
    subbed
  3. Mar 19, 2013 at 4:28 PM
    XXXX
    XXXX Well-Known Member
    sKiP
    05 Prius
  4. Mar 19, 2013 at 4:48 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Well, ain't that an eye popper.
  5. Mar 19, 2013 at 4:49 PM
    XXXX
    sKiP
    05 Prius
    that's the front silly
    he said rear
  6. Mar 19, 2013 at 4:51 PM
    mick478
    mick478 He is The STig
    Bott
    Stockton, CACA
    2011 White TRD Sport, 4x4 doublemint cab
    Ome 885 coils Ome n9000 front shocks Ome n182 rear shocks K&n drop in filter Duratracs Kenwood kac 90210d Kicker 12" Alpine 800 watt 4 channel Pioneer 430w 6x9 Firestone ride rite air springs
    take it to them and show em, face to face is always better... dude that sux!
  7. Mar 19, 2013 at 4:52 PM
    jjew18
    jjew18 the Nightman cometh!
    Alliance Airport
    05 PreRunner SR5
    Added extra awesomeness to its original awesomeness.
    Subbed
  8. Mar 19, 2013 at 5:01 PM
    thebrick
    thebrick Well-Known Member
    Frontrange
    06 2.7L Base
    fox 2.0 remote res toytec UCA all pro add a leaf bilstein 5100 all pro standard bumper hid kit
    This might be a good opportunity to check my 06. Got me worried.
  9. Mar 19, 2013 at 5:04 PM
    tacomalimited
    tacomalimited Well-Known Member
    Northern NJ
    2018 tacoma limited double cab Short bed 4x4.
    I'm starting to regret getting my Tacoma,I bought it because I heard you can't kill a Toyota,now, I'm not so sure,very disheartening, is this what I have to look forward too?
  10. Mar 19, 2013 at 5:07 PM
    S.B.
    S.B. Well-Known Member
    Sean
    San Diego
    15 Taco
    LT, Glass, CBI Front bumper, NWTI Rear bumper, 35s
    Keep your frame clean and touch up little rust spots before they become large, and that will prevent most of it.
  11. Mar 19, 2013 at 5:09 PM
    tacomalimited
    Northern NJ
    Why is Toyota still having these problems?
  12. Mar 19, 2013 at 5:09 PM
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
  13. Mar 19, 2013 at 5:20 PM
    BradyT88
    BradyT88 Well-Known Member
    x2! My 05 frame is still pretty rust free, but it appears to have been treating at some point into the owning process. The aftermarket 5100's are also coated in whatever they used to treat the frame.
  14. Mar 19, 2013 at 5:27 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    That's me for sure , salt water , salt water fog , salt water rain , salt water snow
  15. Mar 19, 2013 at 5:30 PM
    TacoCat
    TacoCat These pretzels are making me thirsty
    Johnny-5
    Chantilly, VA
    25 Crosstrek Premium CVT (first ever automatic!)
    You could run it through salt water car washes too :notsure:
  16. Mar 19, 2013 at 5:31 PM
    OZ-T
    Peter North
    British Columbia
    I do that to rinse off the road salt
  17. Mar 19, 2013 at 5:37 PM
    BradyT88
    We have a lot of salt on the roads in the winter too but I don't know that my Tacoma saw much of that prior to me owning it. I bought it in 2011 with 11,800 miles on it and the frame has been treated at least once after the factory so it is probably not the trend setter for how the frames will last for 2nd gens.
  18. Mar 19, 2013 at 6:47 PM
    trac447
    trac447 [OP] Member
    south otselic
    06 tacoma sr5 2.7l
    i had a 1992 with 350,000 miles on it & the frame didnt rot out on that one. this truck hasnt been no where as good as that one.
  19. Mar 19, 2013 at 6:51 PM
    XXXX
    sKiP
    05 Prius
    so you missed the fun days hu?
    it's nothing new for toyota trucks.
  20. Mar 19, 2013 at 6:53 PM
    OZ-T
    Peter North
    British Columbia
    Is that bad ?
