Got Air?
Discussion in 'Off-Roading & Trails' started by TireFlate, Jan 29, 2024.
  1. Jan 29, 2024 at 4:41 PM
    TireFlate
    TireFlate [OP] Well-Known Member
    Steven
    Introducing our 300LPM (10.6CFM) 12V Twin Cylinder Heavy Duty Air Compressor with 60mm heads, and is the ultimate air compressor for heavy duty applications. It comes equipped with an American Pneumatic Air Chuck for easy inflation, and its cylinders are greased with high quality grease for smooth operation. With its powerful performance, this compressor can air up all four 35" tires from 15PSI to 32PSI in less than 5 minutes. It will air up to what ever PSI you need up to 150PSI. Please note that this compressor does not come with any hose. Purchase with confidence, as this product comes with a 1 year warranty. Plus you can add on our 4 Tire Inflation/Deflation System - the ultimate solution for all your tire needs!
  2. Jan 29, 2024 at 4:53 PM
    TireFlate
    Steven
    Use promo code Taco to get 10% off your setup at TireFlate.com
  3. Jan 29, 2024 at 4:56 PM
    bagleboy
    bagleboy Well-Known Member
    Scott
    Norcal, Santa Rosa
    2014 5-lug AC 2.7L VVTI
    Snug top Rebel, Thule tracks, ditch tracks, Bagged rear suspension, F/R anytime camera, intermittent wiper switch...
    You left out a link.
    https://www.tireflate.com/product-page/300lpm-12v-twin-cylinder-heavy-duty-air-compressor
    90A max current is serious(though likely at high pressure only). How is it cooled and with a 1-year warrantee, how long can it be expected to last. A lot of members build in OBA and the site gives little info on what it would take to install. Some of these units are literally disposable. What makes yours better? Filling 4 tires in 5 minutes will almost certainly burn it up rather quicker but though you claim the capability you specifically deny coverage for the one thing most likely to cause failure.
    koditten and TireFlate[OP] like this.
  4. Jan 29, 2024 at 5:00 PM
    TireFlate
    Steven
    Thaks for your help!
  5. Jan 29, 2024 at 5:03 PM
    TireFlate
    Steven
    It is just air cooled like the others. It does come with a 1 year warranty. That is the best in the industry! I have been selling them for over a year now with no returns, no complaints. You will need to 4 tire air hose setup to inflate in 5 minutes or less.
  6. Mar 18, 2024 at 8:41 AM
    lit_taco4x4
    lit_taco4x4 IG and YT: @2a_crawlcamper
    Louie
    2018 Tacoma TRD Pro
    JD fab LT, Archive and Deavers, King shocks, Dual locked, Dual T case, Tundra steering rack, 39’s
    Do you make one with the auto mode or plan on making one?
  7. Mar 18, 2024 at 8:58 AM
    TireFlate
    Steven
    Yes my next order will have the digital pressure gauge for setting a tire pressure and it will hit the targeted pressure and auto turn off. I should have them end of May.
  8. Sep 25, 2024 at 6:23 PM
    TyBud850
    TyBud850 Well-Known Member
    Tyler
    Defuniak Springs, Florida (NWFL)
    2012 Black Tacoma DC TRD-OR
    3” lift Icon 2.5 shocks king 650 coils, ALCAN LP W/Sumo springs & FOX 2.0, CBI MOAB 2.0 Front Bumper w/Smittybilt X20 10K winch, CBI Rock Sliders, Mobtown Reinforced Steel Skids & Bed Bars, CBI rear bumper,
    Whats the duty cycle and do you use standard NPT thread to use for an onboard air system to fill tanks?
  9. Sep 25, 2024 at 6:28 PM
    TireFlate
    Steven
    15 minutes, and yes it is 1/4 NPT thread.
