Got an Ultra Guage for Xmas
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BigMac, Dec 26, 2010.
  1. Dec 26, 2010 at 2:39 PM
    BigMac
    BigMac [OP] Active Member
    Dave
    So Cal
    Standard regular Cab
    Alarm, power door locks, , Cruse control, intermitten wiper upgrade, trailer hitch, XM radio. Chrome rear bumper, Ultra Guage. Alpine Stereo
    It was an easy hook up and seems to work very well. Only thing is I don't know which MPH is correct. I put 235/75/15 on my Reg cab 2wd. At 60 mph my GPS says I'm doing 63mph and the Ultra says I'm doing around 57 to 58mph. To get the correct mpg the Ultra needs to know the correct distance from the odometer so I'll have to find a mile marker somewhere to calibrate. I mounted mine on the upper left windshield corner. You have to mount it somewhere were you can access the buttons on the back to reset fill ups and odo. I don't know about the other models but with the reg cab it doesn't read the fuel level. You have to calibrate it to 21.1 gallons and input 2.7 for the engine size. Looks to be a useful tool.
    Dave
  2. Dec 26, 2010 at 2:45 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    The GPS is going to be the accurate speed reading.
  3. Dec 26, 2010 at 2:50 PM
    90YotaPU
    90YotaPU The Messiah
    Union County, NJ
    1990 Toyota 4x4 (Pre-Taco)
    Aftermarket Stereo, Spidertrax Wheel Spacers, HF Air Horns, 3" Lift
    Got an UltraGuage too. Can't wait to hook it up. With all the snow that's coming down, not sure when I'll get to it. Glad to hear it works good.
  4. Dec 27, 2010 at 4:02 AM
    jhodge83
    jhodge83 They all float down here... Moderator
    SC
    17 XLT Sport
    3rd gen forum caused me to get a Ford
    if you are running a different sized tire than stock, the UG needs to be calibrated to display with the new tire size. If you go to the UG website, you can print off/view the user manual and it tells you how to re-cal the UG for the tires. had to do it to mine and it reads true now for mileage and MPH.
  5. Dec 27, 2010 at 8:46 AM
    BigMac
    Dave
    So Cal
    Is that the part where you have to find a mile marker and roll your tire? I thought I could use my GPS for that.
    Thanks, Dave
  6. Dec 27, 2010 at 8:50 AM
    jhodge83
    SC
    17 XLT Sport
    well...go any predetermined distance and enter it into the UG and it will compensate for it. i did it a couple times creeping down the side of I-95:eek:
    after it is entered, it should shouw you the amount that it is being changed.
