Got any tips on making strut spacer install as smooth as possible?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Marksgrampa153, Mar 23, 2010.
  1. Mar 23, 2010 at 4:02 PM
    Marksgrampa153
    Marksgrampa153 [OP] Joe Pac
    Joe
    South Jersey
    08 TRD Sport
    K&N air filter, Helix Throttle Body spacer, led lights in the bed
    so i just got a 3" spacer for the front/ add-a-leaf for the back/front diff drop and im pretty sure the leaf and front diff are gonna be easy...i feel like that strut tho, is gonna be a biatch...any tips on easing the install???:confused:
  2. Mar 23, 2010 at 4:06 PM
    toyotadude5
    toyotadude5 Breazeale- Pronounced Brazil
    chris
    Flagstaff, az
    2006 Subaru wrx sti (white)
    haha i did it. Jackstands, floor jack and a buddy to help it should go by pretty smooth. I actually had a harder time doing the ad a leaf then the front spacers.
  3. Mar 23, 2010 at 4:20 PM
    Marksgrampa153
    Joe
    South Jersey
    08 TRD Sport
    what made the leaf installation difficult?
  4. Mar 23, 2010 at 4:23 PM
    toyotadude5
    chris
    Flagstaff, az
    well i didnt have the correct tools i guess. I couldnt get them all lined up perfectly, and i was the only one doing it. It was a pain in the ass.
    The thing thats difficult about the front is actually getting the spacer on the top. Thats why 2 people are needed to make it easier.
  5. Mar 23, 2010 at 4:25 PM
    Tacofanatic05'
    Tacofanatic05' #1 Member
    Hunter
    Waynesville/Charlotte,NC
    05' Tacoma 4x4 sr5, 3 Inch lift
    16'' American Racing wheels, 285/75/16 Cooper Discoverer St tires, Bilstein 5100 w/eibach coils, K&N Cold Air Intake, Flowmaster Super 44, 1 in 2 out exhaust. Tractor Supply Tool Box, No Mud Flaps, Mossy Oak Seat Covers, Oakley Decals, Hoyt Decal, Window tint 20% on sides 5% on top front windshield, Uniden Cb, and Window Deflectors.
    yea same here the struts were the easy part! The add a leaf is a B*tch
  6. Mar 23, 2010 at 4:25 PM
    PreRunnerSeth
    PreRunnerSeth Well-Known Member
    Apex, NC
    15 Black DC OR Prerunner
    Drop the Sway bar completely. Gives you a lot more flexibility to move it out of the way to get the strut assembly out.
  7. Mar 23, 2010 at 4:31 PM
    toyotadude5
    chris
    Flagstaff, az
    i took my sway bar off anyways haha. adds a little more flex to the truck.
  8. Mar 23, 2010 at 4:35 PM
    Marksgrampa153
    Joe
    South Jersey
    08 TRD Sport
    my fear with the leaf spring part is the break lines gettin stretched or yanked, etc. etc. ......i got a bunch of c clamps and jack stands
    definatly takin the sway bar out while i do the front
  9. Mar 23, 2010 at 6:45 PM
    aficianado
    aficianado Well-Known Member
    bay area, california
    2006 access cab. 4x4, TRD-OR
    back to bone stock.
    AAL. use those c-clamps and locked those two top leafs together. that way the holes for the centering pin do not move. way easier to line up two holes. load leaf, and new AAL, to the ONE hole of the two top leafs. you let them all come apart without the c-clamps and you will be lining up 4 holes. it is hell. we didnt lower the axle that low. just enough. we lifted the top two leafs with a strategically placed ratchet strap. no danger to the brake lines.
  10. Mar 23, 2010 at 6:52 PM
    tacobo670
    tacobo670 if you have to ask, u can't afford it
    Ray
    Las Vegas
    Tacoma Sport 4x4 AC 6spd
    Super cherry n some champion stuff on the side
    for the struts -a really strong/long pry bar will help alot. disconnect the sway bar end links. loosen the lca bolts. should slide out. might have to disconnect the tie rod.
    the AAL, if u have a few jacks its better, like a standing one and a floor jack (nascar style). use the standing one for the chassis and the floor jack - use it under the axle. get it high enough so the axle can hang freely (be careful of lines). after removing ubolts loosen center pin leaf nut --be very careful will spring back. i think u can get the idea. as u lower the jack on the axle the spring should start to hang free and u can proceed.
  11. Mar 26, 2010 at 10:29 AM
    Marksgrampa153
    Joe
    South Jersey
    08 TRD Sport
    thank you all for the excellent advice...think il use this forum instead of the instructions haha
  12. Mar 26, 2010 at 10:38 AM
    Tacofanatic05'
    Hunter
    just use a coil compressor!
  13. Apr 7, 2010 at 3:28 PM
    Marksgrampa153
    Joe
    South Jersey
    08 TRD Sport
    thank you all for the tips and tricks...lift is in and looks hot. been installed for a few weeks, just havent had a chance to get on here and tell yall...Pry bar for the lower control arm and a small jack stand to hold up the rotor. A few C-clamps for the leafs...the biggest pain in the ass for me the WHOLE assembly process was something stupid(as always) , re-connecting the lower ball joint bracket/housing because of the new distance away it was, other than that it was a breeze!!
  14. Apr 7, 2010 at 3:54 PM
    nvdeserted
    nvdeserted Well-Known Member
    Reno, NV
    2009 Tacoma TRD OR Access Cab
    Electric Dynolock tailgate, TrailGear Slides, , 285/75-16 Yoko Geolanders on Wheelers Type B, SAW 2.0 front and back, Camburg b/j UCA, 1.5" AAL, Ubolt flip, ARB bump.
    Best advice ever. It makes moving that coilover around so much easier.
  15. Apr 7, 2010 at 4:00 PM
    Tacofanatic05'
    Hunter
    I also did this! It isn't hard to do this at all! 4 bolts and it swings down
  16. Apr 7, 2010 at 4:02 PM
    TacoNut
    TacoNut IgnoringChrisWatchingEdLi veVicariouslyThroughMJP2
    Adam
    Denver, Co
    16 TRD OR DCSB Quicksand
    take how ever long you think it will take you, then add an hour or two. Just go slow and make sure everything gets done right.
    Make sure you follow torque specs too.
