got cragars in, lug nut question
Discussion in 'Wheels & Tires' started by Hologram, Jan 2, 2010.
  1. Jan 2, 2010 at 7:35 AM
    Hologram
    Hologram [OP] Go with the flow
    Pensacola-Destin, FL 850
    03 Doublecab PreRunner SR5
    ok so i called a tire shop and asked them if they would be able to mount the new rims, they said yes but the mentioned the lug nuts. ive done alot of reserch and never did that come up. would the stock 6 bolt tacoma lug nuts work on the cragar soft 8's?
    Thanks!!!
  2. Jan 2, 2010 at 7:54 AM
    badguybuster
    badguybuster Well-Known Member
    Michael
    West (by GOD) Virginia
    2016 Tacoma TRD Sport
    New truck....so nothing yet
    I am interested in seeing how this pans out since I am in the process of buying a set of these soft 8's in black.
  3. Jan 2, 2010 at 8:11 AM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    what type of lug nuts are recommended with the cragars
  4. Jan 2, 2010 at 8:12 AM
    Hologram
    dosnt say. nothing on their website links to a specific lug nut. im guessing the stock lug nuts should fit since everything ive searched, no ones mentioned any sort of different lug nut to go with. :confused:
  5. Jan 2, 2010 at 8:14 AM
    HondaGM
    James
    South-Pole, Alabama
    2023 access cab V6
    acorn type maybe?
  6. Jan 2, 2010 at 8:48 AM
    badguybuster
    Michael
    Just out of curiousity, which center cap did you go with? I am thinking of getting the blank ones so I can customize them. I wanna see pics once they are mounted.
  7. Jan 2, 2010 at 2:20 PM
    Hologram
    i didnt get any center caps
  8. Jan 2, 2010 at 5:37 PM
    Hologram
    bump any info bout the lug nuts?
  9. Jan 2, 2010 at 5:40 PM
    08pretaco
    08pretaco Well-Known Member
    az
    2014 Tundra 4x4 CM 5.7L SR5
    i dont see why a tire/wheel shop wouldnt have different lugs for this type of situation. i bought new wheels that required new lugs (different than factory) they took care of that for me cause they had them there. if they do wheels and tires i dont understand why they wouldnt have lugs for different applications...my .02
  10. Jan 3, 2010 at 6:47 AM
    TexasTacoma37
    TexasTacoma37 Well-Known Member
    I would call cragar and see if they recommend acorn style or shank and washer lugs. Most likely it will be acorn.
    What type of lugs to you have on your current wheels?
    The only other issue is that some wheels require skinnier lugs, often called "spline" lugs. Not sure if the cragars do though.
  11. Jan 3, 2010 at 7:20 AM
    afd23a
    afd23a Well-Known Member
    The Dynamo of Dixie
    05 Access Cab 5 Lugger
    Factory Fog Lights, Removed Secondary Air Filter, Metra Ipod Adapter, Int Wiper Stalk, Wet Okole's, URD Short Shifter, Scanguage II w/Blendmount, Fat Bob's 2.75" spacer lift, ARE topper, SP Performance Pads & Slotted Rotors, 4.10 gears
    according to summitracing's website they use 60 degree conical seat
  12. Jan 3, 2010 at 7:43 AM
    badguybuster
    Michael
    I had a photoshop done of my silver taco with the cragar soft 8's. Have a look at it on that thread.
  13. Jan 3, 2010 at 5:40 PM
    Hologram
