Got fire but want start with starting fluid
Discussion in '1st Gen. Tacomas (1995-2004)' started by Foxdog33, Jan 12, 2024.
  1. Jan 12, 2024 at 9:31 PM
    Foxdog33
    Foxdog33 [OP] Member
    Got fire but want start with starting fluid just spits and backfires
  2. Jan 12, 2024 at 9:31 PM
    Foxdog33
    Can anybody help please
  3. Jan 12, 2024 at 9:39 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Would help to know what you have (Year and engine size) but it sounds like a possible timing issue.
  4. Jan 12, 2024 at 9:42 PM
    Foxdog33
    I'm sorry its a 96 Tacoma 3.4
  5. Jan 12, 2024 at 9:46 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Have you checked that your timing belt is intact and the cams are in time?
    Kbar likes this.
  6. Jan 12, 2024 at 9:48 PM
    Foxdog33
    No I haven't checked timing
  7. Jan 12, 2024 at 9:50 PM
    Bishop84
    Bishop84 Well-Known Member
    It's a timing belt engine and if it skips a tooth it can result in this.
    Definitely stop using starter fluid. It won't help and can only cause issues. Thankfully you have a metal intake plenum.
    Dm93 likes this.
  8. Jan 12, 2024 at 9:52 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    I'd start there, it's pretty easy to check the timing on the 3.4.
  9. Jan 13, 2024 at 7:11 AM
    CD20H
    CD20H Well-Known Member
    Ben
    North Texas
    2004 Double Cab TRD 4x4 Limited
    Magnuson Kompressor, OME lift kit, JBA Headers, junky Sony radio.
    Fuel pump.
  10. Jan 19, 2024 at 3:13 PM
    Tac4lyfe
    Tac4lyfe Member
    Malachi
    1999 Tacoma sr5 TRD 4x4 Mystic Purple Mica
    Few as possible, I really enjoy stock Tacoma's! Except small things, and maybe someday a supercharger.
    Engine Coolant Temperature sensor is a common criminal in this kind of espionage. 14$ off of Amazon and 1 day shipping in my area.
    Honestly I would invest in a code reader. An easy one to use is is Bluedriver, it's cheap and you use an app on your cellphone to read the codes. It's worked for me in the last 10 years I've been using them. It's better to invest in a reader and eliminate 90% of the tinkering involved in trying to diagnose it yourself.
    I can't remeber if 96 had the OBDI or OBDII, so make sure you are getting the right reader for your ride. it's in all honesty the best tool investment you can get.
