Got it! 2007 Tacoma
Discussion in 'New Members' started by Stelcom66, May 14, 2022.
  1. May 14, 2022 at 12:51 PM
    Stelcom66
    Stelcom66 [OP] Well-Known Member
    2007 2.7L 5MT 4WD
    I posted here last week as a prospective buyer, very glad to say I now have a 2007 SR5 in my driveway! For now one question about the front license plate. The dealer and I didn't see any threads where screws would go. I'm not sure if my state requires the front license plate, but might as well install it since I have 2. Something I never thought about - it should go in a frame, right?
    Not surprisingly - the dealer said while I was at the DMV registering the Tacoma someone came to ask about it. Due to how rare and expensive these used Tacomas are around here (or maybe everywhere), I feel very fortunate to be able to get one.
  2. May 14, 2022 at 12:58 PM
    buckhuntin-tacoma
    buckhuntin-tacoma Shed hunter
    Dennis
    Quincy IL
    2014 Spruce Mica Tacoma DCLB
    Welcome to TW…You can use self tapping screws into the plastic bumper, not the frame.
    Stelcom66[OP] likes this.
  3. May 14, 2022 at 1:06 PM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    Welcome to TacomaWorld
    Is there a pair of square or rectangular holes where the plate goes?
    If so there are threaded plastic inserts available which receive license plate screws.
  4. May 14, 2022 at 1:10 PM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    Scotch extreme double sided tape.
  5. May 14, 2022 at 1:35 PM
    Stelcom66
    2007 2.7L 5MT 4WD
    Thanks for the welcome and suggestions - I'll double check to see if there's any existing holes. If not, made note new holes would go in the plastic bumper. Another good idea is the tape.
    This is the kind of vehicle I'm going to have to drive again this evening even though I don't need to go anywhere! Can't say I did that with my Honda CR-V.
    ToyoTaco25 likes this.
  6. May 14, 2022 at 1:58 PM
    OffroadToy
    OffroadToy kokanee smoker
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    Welcome! Another 2007 here. :thumbsup: Need a picture of your new ride! :woot:
  7. May 14, 2022 at 2:19 PM
    Stelcom66
    2007 2.7L 5MT 4WD
    Here you go -
    Yeah now I have 2 trucks. Will probably keep the Silverado as a backup for a while, but the reason for trading in a CR-V for the Tacoma was to consolidate to 1 vehicle at some point. The Tacoma will be my D.D.
    44-16 Taco and Chuy like this.
  8. May 15, 2022 at 6:40 AM
    OffroadToy
    Nice looking truck ya got there! Be sure to take some time and go over the underside with some rust proofing like Fluid Film.
  9. May 15, 2022 at 6:54 AM
    AXL
    AXL Well-Known Member
    Axl
    Maryland
    Grumpy Old Veteran
    Congrats!
  10. May 15, 2022 at 7:01 AM
    Stelcom66
    2007 2.7L 5MT 4WD
    Thank you - yes rust proofing is where I live. What 2007 model do you have and how many miles? Maybe someday I'll get alloy wheels. The grill is new (or replaced) as the original plastic was broken.
    The frame looks pretty good, and there's some suspension components that appear to have been replaced, such as the rear leaf springs. Several new looking bolts, U brackets. an other components with manufacturer's stickers on them. I'll try to get a picture later because I'm wondering about this.
    There was some surface rust on the hitch (nice having one since I don't on my Silverado) but I realize this is a 15 year old truck. Doesn't have any rust that I can see around the wheel wells.
  11. May 15, 2022 at 7:02 AM
    Stelcom66
    2007 2.7L 5MT 4WD
    Thank you - and thank you for your service.
  12. May 15, 2022 at 7:10 AM
    OffroadToy
    Mine is a Offroad double cab short bed with 33,120 miles.
  13. May 15, 2022 at 8:14 AM
    Stelcom66
    2007 2.7L 5MT 4WD
    Holy smokes, only 33,120 miles!
  14. May 15, 2022 at 4:57 PM
    Stelcom66
    2007 2.7L 5MT 4WD
    Here's some shots of what appears to be new leaf springs and a few other components. There's a couple of other areas, such as the shocks, that appear to have new bolts. Is it common for the leaf springs to need replacement? Seems like a good job, rides decent and no objectionable noises over bumps and road imperfections. I chose 'Insert Thumbnail" for the images, but they ended up as full images.
  15. May 18, 2022 at 1:11 PM
    OffroadToy
    Not positive but thinking your leaf packs/hardware got replaced under the recall. What's going on with the top of the driver side rear shock? :eek:
  16. May 18, 2022 at 1:12 PM
    tdram
    tdram Member
    2020 Tacoma Trd OR
    Congrats! Many enjoyable years to come
  17. May 18, 2022 at 1:16 PM
    ppham444
    ppham444 Well-Known Member
    Phuong
    Portland, OR
    2023 White TRD Off-Road doublecab
    Man, you need to replace those rear shocks!
  18. May 18, 2022 at 1:21 PM
    Woofer2609
    Woofer2609 Getting better all the time.
    Clancy
    Vancouver Canada
    2009 AC 4X4 2.7 5M
    Underside looks relatively nice, yes, shocks could stand to be replaced, looks like you got your leaf springs replaced with the 4 pack. Right on!
    4wd? 4 cylinder? A/T or M/T?
  19. May 18, 2022 at 1:22 PM
    ToyoTaco25
    ToyoTaco25 Well-Known Member
    North Carolina
    09 Super-White DCSB 6-Speed
    ProComp 4" D-Bag, I mean Drop Bracket Lift, AMP Research Powersteps, 285/70-R17’s, Magnaflow, AFE CAI, Dipped Badges
    Toyota tech replacing leaf springs & sees rear shock is non-existent :
    OP, nice truck! But get that thing some new rear shocks asap & have someone inspect the rest of the truck!
  20. May 18, 2022 at 1:28 PM
    tdram
    tdram Member
    2020 Tacoma Trd OR
    I second that....if nothing else for the piece of mind
    ToyoTaco25[QUOTED] likes this.
