Got my 60K done by the stealership
Discussion in '2nd Gen. Tacomas (2005-2015)' started by LocoTaco, Feb 20, 2014.
  1. Feb 20, 2014 at 9:44 PM
    LocoTaco
    LocoTaco [OP] Well-Known Member
    Don
    Central Washington
    09 SR5 TRD Sport
    I had my 60K done by the stealership for a little over $800.00. The quotes from private garages ranged from $725 to $850.00. I told the private garages I would provide my own Mobil 1 5-30, Mobile gear oil, crush washer and filter, and plugs The low cost garage had never heard of crusher washers and said providing my own oils, filters, plugs etc. would not lower the cost. The high bid garage offered a discount if I brought my own parts and oil, the price came to equal the stealership bid. I went with the stealership and they were wiling to provide driver runs to work, to lunch and then to the stealershipafter work.
  2. Feb 20, 2014 at 10:02 PM
    egres
    egres Well-Known Member
    DELCO PA
    13 singel cab - 2WD - manual - 17K before tax:)
    Bench-seat covers $180 (Can't believe its not leather),Bed Liner $375 (Bed rug), Roof rack $180 (Rhino-rack 2500 Series, plus DK clamps and pads), Modified Bed extender $85 (Extend-A-Truck 944 Truck Bed Extender), Hood lift assist $80 (RedlineTuning), Hood light $53 (tacomaworld.com âtacodaneâ), Hitch receiver $120 (Curt Manufacturing 13323 Class III Receiver), T connector for trailer $43 (CURT Manufacturing 55513 T-Connector), Manuel tailgate lock $30 (gatekeeper tailgate lock), Tailgate assist $28 (Sachs SG329900EZ Lift Support), Tailgate lock $67 (Pop & Lock Tailgate Lock Tailgate Lock PL5301), Spare tire lock $12 (Trimax ST30 Trimaflex Spare Tire Cable Lock), Hardwired battery float charger $20 (Schumacher SE-1-12S-CA Fully Automatic Onboard Battery Charger - 1.5 Amps) , Vin # Glass etching $33 (vinguard.org), Easy oil drain plug $30 (Fumoto Engine Oil Drain Valve), Floor mats $80 (Husky Liners 2-Piece Front Liner 2-Piece Front Liner), out of space :)
    800 for this!!!
    Air Filter Element
    Cabin Air Filter
    Engine Oil and Filter,
    Fluid - Differential
    Spark plugs and wires
    Rotate Tires
    Tighten/Torque Drive/Propeller Shaft
    Inspect: I'm honestly believe that NO mechanic will actually do this but this what it calls for. (they sure will tell you they did)
    Ball Joint, Brake Hose/Line, Condenser HVAC, Coolant, Disc Brake System, Drive Belt, Drum Brake System, Evaporative Emissions Hose, Exhaust System, Fluid - A/T, Fluid - M/T, Fluids, Fuel Filler Cap, Fuel Supply Line, Fuel Tank Mounting Straps, Interior Moulding / Trim, Radiator, Steering,
    Reset Oil Change Reminder Lamp
  3. Feb 20, 2014 at 10:07 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    +1
    Pleasant Saturday afternoon job and can be done without a lift.
    $400 is a ripoff... much less $800.
    Take it to Discount Tire/America's Tire and pay the $40 to buy the lifetime rotation/rebalance.
  4. Feb 21, 2014 at 5:28 AM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Auto parts store, oil,plugs,filters,syn gear oil etc. $214
  5. Feb 21, 2014 at 7:24 AM
    spencer44306
    spencer44306 Well-Known Member
    Spencer
    Upstate Ny
    13 TRD Sport 4x4
    How did your buttock feel this morning when you got up?
  6. Feb 21, 2014 at 7:26 AM
    Mademan925
    Mademan925 Senor Taco
    Nick
    Discovery Bay, CA
    2014 4x4 TRD OFFROAD DCSB
    enough to go over stuff
    OUCH... I paid like 1700 for 100,000 miles or 8 years of maintanance.
  7. Feb 21, 2014 at 7:37 AM
    TacoBrah
    TacoBrah Well-Known Member
    Sean
    Icon stage 1, 255/85/16 KM2
    So $800 and they didnt even flush the tranny?
  8. Feb 21, 2014 at 7:57 AM
    Jrahn0822
    Jrahn0822 Well-Known Member
    Jake
    Iowa
    07 DCLB
    I would think with the vast knowledge and DIY threads you would want to attempt to tackle this by yourself unless you are not mechanically competent. And even then some of the stuff you could still easily have done.
  9. Feb 21, 2014 at 8:46 AM
    Sig45
    Sig45 Well-Known Member
    Mark
    Maine
    I had my 60K (2011 V6 DCSB TRD OR) performed at the dealership for $320. I just didn't have the time to do it myself.
    Replaced Spark Plugs
    Tire Rotation
    Oil & Filter change (I supplied the oil)
    Front & Rear Diff and Transfer Case fluid change (I supplied the gear oil)
    Tranny Flush
    Regular inspections - like someone mentioned....who knows if they really do this....but everything on the form was checked on the green box.
    Although not cheap.....pretty reasonable I think.
  10. Feb 21, 2014 at 8:56 AM
    Chris24
    Chris24 Well-Known Member
    Greensboro, NC
    09 Black DCSB TRD Sport, V6, 6sp
    They should have provided a lot more for $800.
  11. Feb 21, 2014 at 10:14 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    100,000 miles
    20 oil changes
    20 * 30 + $20 * $5 = 700 for oil and filters (Mobil-1 synthetic and Toyota filters, those numbers are padded by as much as $6 so it could be as little as $600)
    Two air filters, that's $40.
    3 sets of copper plus for a V6, or one set of Iridium plugs for a 4-banger, that's $70-80.
    Your brakes are not going to be included in that when you need pads at 90k.
    If they follow the maintenance schedule, they probably aren't going to flush the trans, or even drain and refill.
    I've never seen a tech "torque the propellor shaft"
    100k/8 years, you MIGHT get one coolant flush out of them.
    You still got ripped off... but not as bad as the OP.
  12. Feb 21, 2014 at 11:07 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Yes. A reach around at the very least!
  13. Feb 25, 2014 at 9:14 PM
    LocoTaco
    Don
    Central Washington
    09 SR5 TRD Sport
    They did; they followed what the owners manual requires and/or at least signed off on a statement of work. I have no idea if they cut corners or even gave me back my own used spark plugs. You guys need to know that I can do a lot of these tasks myself but I have a bum left shoulder that keeps me from crawling around underneath, on or around the truck too much. I can't even pull my bow back right now because of my left shoulder.
    I installed/mounted my own winch a few months prior to the shoulder taking a dump on me, so please give me a break here.
  14. Feb 25, 2014 at 9:29 PM
    worthywads
    worthywads Well-Known Member
    Peoples Republic of Boulder
    05 5-lug access I4 Stick, 70 Challenger Vert
    Did you get a list of what they did?
    Here's what is called for.
    Replace oil/filter.
    Replace air filter.
    Replace Cabin air filter.
    Rotate Tires
    Replace limited slip Diff oil (if equipped)
    Replace spark plugs
    Inspect a lot of things
    A few more things if they asked if you tow.
  15. Feb 25, 2014 at 9:48 PM
    SilverSurfer
    SilverSurfer Well-Known Member
    Mark
    Los Angeles
    2013 4X4 LT
  16. Feb 26, 2014 at 7:49 AM
    kb1jop
    kb1jop kb1jop
    Rick
    Webster, MA
    2020 Magnetic Gray Metallic SR5 Double Cab
    Factory Towing Package OEM Bed Mat Hard Tonneau Tacoma All-Weather Floor Mats
    Yah, that's about what it was for my 30k which is virtually the same as 60k except for a few less "inspections." $800 yikes!
  17. Feb 26, 2014 at 8:54 AM
    mbrogz3000
    mbrogz3000 Well-Known Member
    Northern NJ
    2020 Toyota 4Runner Limited
    Ripoff! But when you add up the pre-defined amount of time to do each task multiplied by the dealer labor rate, + 15% markup on the materials, it works out $800 or so. I think materials from auto zone would add up to about $100-$150, if you were using irdium tipped spark plugs.
    It always comes back to whether 1. you are mechanically capable of doing the work 2. you have the place to comfortably do the work, and 3. you have the tools and a convienent place to store them. If you any yes to all 3 of those, then it doesn't make sense to spend $800 on the work. If you answer no to one or more, then it may make sense....but you probably need to look for a reputable local shop or indepentent guy rather than a dealer to save some money.
  18. Feb 26, 2014 at 9:26 AM
    nextfriday
    nextfriday Well-Known Member
    Indianapolis, IN
    13 SR5 Double Cab
    5100s@2.5", 2" aal Leer 100 XR w/ Yakima rails and towers 18x9 Pro Comp Rockwells Cooper Discoverer AT3 275 65 18
    There went some nice aftermarket wheels.
  19. Feb 26, 2014 at 9:34 AM
    Amo-cat3
    Amo-cat3 Wizard Sleeve Master
    Maui, Hawaii
    07 TRD Blown dubcab
    TRD Supercharged 4.0 w/ 2.5" Quick change Pulley, UCON EMS, URD 7th injector, AFE Stage II intake, DT Longtubes, MBRP 2.5" dual exhaust w/ Vibrant Ultra resonator, URD Y-pipe w/ vibrant v-bands (Cat free), Walboro 255 fuel pump, SS Oil catch can, Aeroforce gauges, Icon CDC 2.5 coilover set at 3", 1.5" Wleelers Progressive aal, Light racing uca, 17x8.5 Fuel Anza 4.5" backspace/-6 mm offset, Kelly Safari a/t 265/70/17, scanguage 2, AMP electric steps, bed extender, Low-pro tonneau cover, 20% tinted windows/headlights/taillights, tacoma seat covers, Image dynamic sound system w/ Pinoneer avh3200 head, assrtd stickers................
    Hey OP, sorry your getting so much flak for paying that much for the service. That is a pretty penny you spent but you still are staying on top of your maintenance schedule which is most important.
  20. Feb 26, 2014 at 9:37 AM
    2ski4life7
    2ski4life7 Well-Known Member
    Seattle WA
    17 DCLB 4x4 TRD Off Road Previously '12 DCLB 4x4 SR5
    Don't hate on the OP so much. Yes it could have been done cheaper by yourself but I think if someone can afford to pay for something and is willing let them. But in this case OP is hurt, but OP there are plenty of people pry willing to help out with a case of beer and lunch.
    I can do most of the work on any truck/car/motorcycle. This past weekend I flushed my radiator, changed spark plugs, did an oil change, inspected my valve clearance, changed my rear brakes, cleaned/oiled my air filter on my motorcycle. Granted this took around 8-9 hours to do myself after stopping and having to get some parts. But its almost worth it to me to spend the money to have someone else do it just since I wasted a day after I worked over 60 hours in the week. Hardly anytime to do fun stuff.
