got my allpro bumper today please help
Discussion in '1st Gen. Tacomas (1995-2004)' started by greenscreener, Jun 11, 2011.
  1. Jun 11, 2011 at 10:29 AM
    greenscreener
    greenscreener [OP] Well-Known Member
    luis
    Norwalk, ca
    04 prerunner
    procomp aal, Saw 2.0 coilovers, Allpro bumper, Yakima roof rack, Method racing wheels, mostly debadged eeyore plush on the dash adds about 7hp so im told
    hey i got my allpro bumper today and i have a question how exactly do i get the metal piece off the long one i guess its the factory bumper i took off the two bolts underneath each one but it wont come off do i need to cut this off or am i doing sumthing wrong here look at the pics please help
    this is what i cant get off bolts already removed
  2. Jun 11, 2011 at 10:36 AM
    newskooler
    newskooler Well-Known Member
    Nick
    Lake Shastina,ca
    03 Tacoma x-cab TRD SR5
    881/5100 front, 5100 rear, AAL, K&N intake, Diff breather, grey wire mod, tg Low pro and sliders, Custom tube bumper, pinch weld mod, and more... smoked taillights, fabtech tire carrier, sony headunit, 12v always power mod, #70 unhappy clutch spring mod,
    this might help:)
    the green hoop shows you where to go but its mounted to the frame at the base so use and extension
  3. Jun 11, 2011 at 10:50 AM
    greenscreener
    luis
    Norwalk, ca
    04 prerunner
    thank you very much i was close to just cutting that thing off lol
  4. Jun 11, 2011 at 10:57 AM
    newskooler
    Nick
    Lake Shastina,ca
    no worries dont forget to post some pics
  5. Jun 11, 2011 at 11:00 AM
    Matic
    Matic Locked and Lifted "02" DC TRD.
    Rich
    Greenville,sc
    1 owner 2002 TRD, SR5, DC, 2.7. Full OME suspension, STT pro's.
    OME 881 coils with OME nitrochargers shocks up front. TC UCA's OME Dakars with extra leaf in the rear. Warn 8000 winch with 80ft custom braided synth line. Custom 60ft synth extension. All pro tube bumper, Hi-lift jack, Safari Snorkel, Wilco tiregate.
    Also. If they have not fixed the problem with the fitment here, you might have to trim a little bit to get it to fit properly.
    I have the 1st gen tube bumper and not the baja like yours but just check the fitment real well. Install all the bolts loosely before you tighten them up.
    I had to trim 1/2-3/4 of an inch in the location shown and I believe tacomorroto had to do the same.
    I think you will also have to remove your hook or tow loop. And niether may bolt back up in the same spot. Hence the shackles on mine.
  6. Jun 11, 2011 at 11:05 AM
    atvlifestyle
    atvlifestyle Well-Known Member
    Michigan
    01 trd tacoma
    supercharged with lots of midtravel bling.
    I had to trim the same spot as mentioned above.
  7. Jun 11, 2011 at 11:55 AM
    greenscreener
    luis
    Norwalk, ca
    04 prerunner
    well i guess allpro made my bumper just about 1/4 to 1/8 of an inch to narrow and i cant for the life of get it inbetween the frame rail dang it should i grind it just a bit
  8. Jun 11, 2011 at 12:10 PM
    BFA
    BFA Nuttier than squirrel shit.
    Brian
    Phoenix, AZ
    2003 3.4 4x4 5spd
    its supposed to fit tight.. anyone around you to lend an extra hand?
  9. Jun 11, 2011 at 12:42 PM
    newskooler
    Nick
    Lake Shastina,ca
    x2 my trail gear bumper was a PITA a second set of hands make a world of difference
  10. Jun 11, 2011 at 12:44 PM
    BFA
    Brian
    Phoenix, AZ
    2003 3.4 4x4 5spd
    yeah mcjosh was a big help when i put mine on.. i still couldnt get one side of the bolts to line up and now its way out of alignment lol
  11. Jun 11, 2011 at 1:50 PM
    greenscreener
    luis
    Norwalk, ca
    04 prerunner
    It's still too tight about 1/4 off what should I do
  12. Jun 11, 2011 at 3:22 PM
    Matic
    Rich
    Greenville,sc
    Beat the shit out of the bumper and make it fit.
    Is there anyway you can get a hi-lift jack inbetween the 2 mounting brackets and spread them ever so slightly?
  13. Jun 11, 2011 at 3:30 PM
    newskooler
    Nick
    Lake Shastina,ca
    Are your mounting brackets painted? If so you may have to take the paint down to primer then mount it. My tg bumper took alot of persuading to fit. so keep trying before taking it down
  14. Jun 11, 2011 at 3:59 PM
    greenscreener
    luis
    Norwalk, ca
    04 prerunner
    its done gentlemen thank you very much for all ur help 6 pack on me :) here are the pics need to paint it later its just got sum spotty primer on it for now used a sledge hammer to persuade it into place and my two brothers let me know what you think
  15. Jun 11, 2011 at 4:01 PM
    greenscreener
    luis
    Norwalk, ca
    04 prerunner
    my grill needs to go who sells better looking ones
  16. Jun 11, 2011 at 4:24 PM
    newskooler
    Nick
    Lake Shastina,ca
    looks good as for the grille id paint it or satoshi it. street scenes or Autoanything
  17. Jun 11, 2011 at 4:27 PM
    jeff b
    jeff b Well-Known Member
    Beast mode! Looks good leave the chrome!
  18. Jun 12, 2011 at 12:14 AM
    BFA
    Brian
    Phoenix, AZ
    2003 3.4 4x4 5spd
    looks good not a fan of the baja headlight hoops but good none the less
  19. Jun 13, 2011 at 8:56 AM
    Box Rocket
    Box Rocket Well-Known Member
    Adam
    Syracuse, Utah
    1995 FZJ80 Land Cruiser
    3xLocked, lifted, well used
    x2. I like the AP bumper for many reasons (almost bought one), but DANG the Baja hoops are stupid looking. The only time they seem to look appropriate is on a fully decked out LT desert truck, and even then it's too much IMO.
    Nice job either way.
