Got my Billys and springs...next up...
Discussion in 'Suspension' started by Smoove06, Dec 15, 2010.
  1. Dec 15, 2010 at 11:13 PM
    Smoove06
    Smoove06 [OP] Well-Known Member
    Alex
    North Phoenix
    05 SSM DCSB PreRunner
    Starting From Scratch....again
    So UPS just dropped off a box which contained 2-5100's, 2-eibach springs and and 2 aal's (Thanks toddt!)
    I 've read around that people have been setting their billys to 0.85 when using the eibach springs and having 2" aal in the rear. Seems very common and seems like they have no complaints either. The only thing i noticed is that the trucks running that setup seem their rear ends just a tad bit higher than the front.
    My questions are:
    1. Is anybody running billys set at 1.75 and eibach springs?
    2. Does it give your truck any kind of rake or does it level it out?
    Thanks in advance...
  2. Dec 15, 2010 at 11:24 PM
    KodiakToyTRD
    KodiakToyTRD Well-Known Member
    CO
    2013 Scion FR-S Whiteout
    I would say it would put the front higher being as most people set them at .85 with stock springs for a level. Either that or 0 with the Eibach springs. The springs give 1.6in of lift so your looking at what...1.75+1.6....3.3 in of lift. I guess if your running AAL's you will prolly be fine.
  3. Dec 16, 2010 at 5:02 AM
    WNYTACOMA
    WNYTACOMA Well-Known Member
    Clarence, New York
    09 Metalic Grey TRD OFF ROAD
    Toyota Nerf steps Bugflector 2 Tool box Weathertech floor liners Wet Okole F/R - Bk/Char
    I'm pretty sure .85 is the max setting you can use when used with the Eibachs.
  4. Dec 16, 2010 at 6:11 AM
    Smoove06
    Alex
    North Phoenix
    Even if i run 2" aal's in the rear?
  5. Dec 16, 2010 at 6:21 AM
    WNYTACOMA
    Clarence, New York
    I'm reasonably sure that what you run in the rear has no bearing on the limitations when using both the 5100's and Eibachs on the front.
    If my understanding is solid, i believe those in the know recommend the 5100's be set at '0', (or 'stock' height) when used in conjunction with the Eibachs, though off the record, a max setting of .85 is doable.
    I wouldn't go beyond the .85 under any circumstance, based on my understanding. If you are looking for more lift than that up front, i'd look at other options.
  6. Dec 16, 2010 at 6:49 AM
    outlaw7
    outlaw7 Well-Known Member
    Brandon
    PacNorWest
    2010 trd sport
    I would not go above the. 85 setting, I have mine at. 85 with a. 50 inch spacer on the drivers side and. 25 inch space on the pass side with the tsb aal and I have about a 2.5 inch rake you can see a pic in my gallery
  7. Dec 16, 2010 at 7:29 AM
    Fabulous
    Fabulous Well-Known Member
    Fabian
    Calgary, AB
    2017 Tacoma double-cab TRD Sport
    TRD Pro grill and fog lights, Toytec Boss lift, 265/70-17 Duratracs on 17 x 8.5 FN Verge wheels, LEER canopy, 30% tinted front windows.
    Do not put the eibachs any higher then 0.85...I talked to Toytec, and eibach about this, and it is a very bad idea to go any higher! The springs are much longer, and have a lot more force in them. The 0.85 setting works fine...it's what I have, along with the 2" AAL and there is some rake, but not a lot...maybe a bit more then 1.25". Also keep in mind that the arch of the rear fender is approx. 0.5-0.75" higher then the front, so take that into account. I got 2.6" of lift in front on my d-cab short box 4x4, and 2.25" in the back. Measures before were 35" in front, and 37" in back...now it's 37.6" and 39.25" measured through the hub to the wheel arch. If you minus that 0.5-0.75" off the back then it's not much of a difference.
  8. Dec 16, 2010 at 7:32 AM
    Smoove06
    Alex
    North Phoenix
    Ok so dont go higher than 0.85 setting. got it.
    Now, will i need a 1/4" spacer to compensate for the taco lean effect?
  9. Dec 16, 2010 at 7:43 AM
    Fabulous
    Fabian
    Calgary, AB
    I needed it...worked great! Truck is completly level now.
  10. Dec 16, 2010 at 8:00 AM
    Smoove06
    Alex
    North Phoenix
    One more question...Where can i find the torque specs for when i re-install everything???
  11. Dec 16, 2010 at 9:06 AM
    Fabulous
    Fabian
    Calgary, AB
  12. Dec 16, 2010 at 9:10 AM
    Smoove06
    Alex
    North Phoenix
    Thanks for all the responses! Wish me luck as i try to conquer this over the holiday break! Merry Christmas everyone!
  13. Dec 16, 2010 at 9:13 AM
    Hipster
    Hipster Nothing beats a Butter Shave..
    Tom
    Tucson
    '10 DC trd 4x4
    Billy's @ .85 w/ Eibachs front, TSB w/ 5100's rear + 1.5" AAL & shims, Debadged, Avid Bolt On Sliders, NFab Light Bar w/ (2) Lightforce 170's. Weathertechs, ATO bed bars.
    yes, .85 is the max you can go with the Billy/Eibach setup. That info came from Toytec as well. You will Love the ride difference. I have the TSB and I have 1.5" springs sitting right behind my desk...I need to get them installed...
  14. Dec 16, 2010 at 9:22 AM
    Fabulous
    Fabian
    Calgary, AB
    Enjoy the set up...I'm very, very happy with mine. Make sure after you install it, give it 3-4 days to settle (if possible) and get an experienced alignment shop to do your alignment...it's imparative to get a good alignment, not just to "spec". If you have any ? just PM me.
  15. Dec 16, 2010 at 9:47 AM
    Smoove06
    Alex
    North Phoenix
    I will definately get it aligned when everything is said and done. Thanks again Fabulous for all the info. I'll definately PM u with more ?'s.
