Got my first Tacoma, want a tonneau cover! Truxedo or Access Rol up ?
Discussion in 'Tonneau Covers, Caps and Shells' started by reznor, May 7, 2012.
  1. May 7, 2012 at 9:44 AM
    reznor
    reznor [OP] Well-Known Member
    Hi guys,
    Here we are, I jsut got last week my first Tacoma ever! In fact, this is my first truck!
    A 2010 Double Cab SR5. Just great to drive ! Really enjoy it!
    Actually, the truck came with a trifold tonneau cover. Wich I think isn't very usefull. I am looking to replace it with a roll up tonneau cover.
    There is 2 models I was looking for
    Truxedo Lo Pro QT or Access Roll up Lite Rider. I would like to have you guys your comments about these 2 brands!
    One thing important : I don't know if these tonneau are compatible with the bed rail system. I do want a tonneau cover where I can use the actual bed rail system! It means that I want to have a full use of the Tie Down !
    Thank you for your help.
  2. May 7, 2012 at 10:06 AM
    Guess2010
    Guess2010 Well-Known Member
    DAVE
    Saskatchewan
    2010 trd tacoma double cab
    Just a few dont tell the wife!!!
    i bought my truxxedo roll up cover 2yrs ago and is deadly
    would addvise u to go with one.
  3. May 7, 2012 at 10:11 AM
    reznor
    Can you use the entire bed rail system ?
    Do you loose any charging space into your bed ?
  4. May 7, 2012 at 11:28 AM
    Mr_Torque
    Mr_Torque Buy the Ticket take the Ride.....
    Perkasie,PA
    '07 Tacoma SR5 4WD V-6 6 Spd
    MBRP Exhaust, 17" FJ Steelies w/Firestone AT's, Truxedo Lopro ,Timbren SES, Pioneer FH-X720BT HU & TS-C720PRS Component Speakers, TRD Quickshifter, Bilstein 6112/5160, Light Racing UCA, and Icon Progressive add a leaf.
    I've had my Truxedo Lopro for almost 5 years and it's still in great shape. I forgot my truck even has the rail system. I added some front tie downs and only use the bed for strapping stuff down. Never trusted those plastic cleats.
  5. May 8, 2012 at 10:09 AM
    reznor
    Any other suggestions guys ?
  6. May 8, 2012 at 10:15 AM
    StickShifty
    StickShifty Well-Known Member
    New Jersey
    2012 AC 4WD 6SPD
    i have the access roll up and like it a lot. i still have full use of the bed rails, which i do use all the time. my cover bolted up like this: bed, spacer, access rail, bed rail, then a bolt to hold it all together.
  7. May 8, 2012 at 10:18 AM
    reznor
    Wich model of access roll up do you have ?
    Do you lost any space in your bed ?
    Is it a low profile cover or your cover is higher than the top of the bed ?
  8. May 8, 2012 at 10:18 AM
    MMazz365
    MMazz365 Well-Known Member
    Michael
    NY
    TRD Off Road
    -flowmaster dual side exit exhaust -3 inch lift -cb radio -scanner -DTRL's -Fogs Anytime -Truxedo Soft Tonnahu Cover -eyelids -grillcraft upper and lower -fogs behind the grill
    I've got the truxedo lopro like most, and just like them I didn't mind losing the rail system because I would not trust that plastic holding my valuable motorcycles and dirtbikes up lol. But I love it, fast and easy to roll up, and still in great shape after a year and a half
  9. May 8, 2012 at 10:57 AM
    478DblSport
    478DblSport Thermonuclear Protection
    Byron, GA
    07 Silver Streak Mica PreRunner DC TRD Sport
    | EXTERIOR | Access Roll-up Tonneau Cover, Tailgate Hose Clamp Mod, Shortened OEM Antenna, DeeZee Bed Mat ---------------------------- | INTERIOR | Flyzeye V2W (Amber/White/Amber) Audio: Alpine CDA-117, PDX-5 (119Wx4+410W), Polk Audio MM6501 (F) & MM651 (R), JL Audio CP108LG-W3v3 (Sub), w/Monster, Rockford, & Streetwire cabling, Metra Dash Kit.
    I have the Access Roll Up tonneau cover and it allows the use of the bed cleats/rail system. My cover does rise above the bed but my understanding is that anything more low profile than that would prevent the cleats from being used with the rail system... although I came across a thread or post where a fellow TW member with a low profile cover modified his cleats by grinding them down and was still able to use them. I've tried to find the post and for the life of me can't find it? :confused:
    When you decide on a cover check out Truck Alterations. When I was shopping they had the best price anywhere.
    http://www.truckalterations.com/html/tacomaworld.html
  10. May 8, 2012 at 10:58 AM
    WVTacoma08
    WVTacoma08 Well-Known Member
    West Virginia
    '16 TRD Off Road
  11. May 8, 2012 at 11:00 AM
    reznor
    Wich model do you have ? Lite rider, or something else ?
  12. May 8, 2012 at 11:00 AM
    reznor
  13. May 8, 2012 at 11:05 AM
    Chaloots
    Chaloots Well-Known Member
    new owner /poster here.i just installed the access lorado on my 2012 sport dcsb. i can still use the factory cleats. it only takes up 5-6"s of the bed max.
  14. May 8, 2012 at 11:07 AM
    NEAScott
    NEAScott Well-Known Member
    Scott
    Toledo, Oh
    2014 Chevrolet Impala Limited
    The regular Access Roll-up allows you to continue using the rail cleats. My understanding is the other models are lower profile and they will not clear. The cleats are 10x's as big as they need to be anyhow. Toyota needs to shrink the dang things.
    Give me a shout, I'll quote you a price.
  15. May 8, 2012 at 11:13 AM
    478DblSport
    Byron, GA
    Access Original Roll Up. [​IMG]
  16. May 8, 2012 at 11:18 AM
    reznor
    Great! Thank you!
    Did you have to remove the factory bed rail system before installing the access roll-up rail ? And after, you put back the factory bed rail ?
  17. May 8, 2012 at 11:42 AM
    NEAScott
    Scott
    Toledo, Oh
  18. May 8, 2012 at 11:47 AM
    478DblSport
    Byron, GA
    Yep. There are several good YouTube videos showing installations and here's a thread link that a member posted with lots of pic's to give you a better idea of the install. With the supplied instructions, videos, & the thread below installation was simple...
    http://www.tacomaworld.com/forum/detailing/68017-access-le-install-09-tacoma.html
  19. May 8, 2012 at 11:47 AM
    HRDTACO
    HRDTACO Well-Known Member
    Sean
    Long Beach
    '12 Prerunner DCLB
    to come!
    I have the Lite Rider... Absolutely no complaints works great and still have the bed rails
  20. May 8, 2012 at 11:49 AM
    reznor
